DIY: Removing Door Panels On A 2006 Honda Civic - 8th Generation Honda Civic Forum
Go Back   8th Generation Honda Civic Forum > Civic Technical > Do It Yourself Articles > Interior Style Mods
Old 12-19-2009, 01:02 AM   3 links from elsewhere to this Post. Click to view. #1 (permalink)
darrman25's Avatar
David
Remove Car Door Panels On A 2006 Honda Civic & http://www.honda-tech.com/showpost.p...87&postcount=1
Gaining Access To Repair Power
Windows, Door Locks, Side Mirrors Etc.
(Covers Model Years 2006 To Present)
Skill Level: 2-3 (Basic to Intermediate)
Time Taken: About 15 Minutes
I found only two screws and one push clip holding the 2006 Honda Civic
left front door panel on.
With a small screwdriver I removed the cover panel on the inside door latch.
First I removed the Phillips screw from the latch assembly.
With a small screwdriver I pushed in the center of the button clip slightly until the clip broke free, then I just pulled it out.
With a pry tool or small screwdriver I pried upwards at the slots in the switch panel (red arrows).
By pressing on the tabs of the wire connectors
, I was able disconnect the wire harness from the switch panel.
Next I removed the Philips screw from the pull handle area.
Then with a rigid putty knife I pried the plastic panel from the metal door shell.
With an upward push, the panel unhooked from the lip of the door.
But... the door panel is still connected by the inside door handle cables.
Disconnecting The Door Handle:
In the past, most cars
have used metal linkage rods to connect the door release handle and lock button to the door latch. This Honda
uses a pair of sheathed cables, similar to those used on bicycle or motorcycle brakes.
Lock Button Connector:
First I unhooked the securing clip on the end of the inner wire (arrow). Then I disconnected the plastic end of the outer cable sheath.
Door Release Connector:
The end of the outer cable sheath was different than the lock button cable. I used a small screwdriver to pry open the plastic retainer, and the cable came out.
View of back of plastic door panel
View of metal door shell with dust cover on.
darrman25 is offline
Old 12-19-2009, 01:11 AM   #2 (permalink)
sick-k20z3's Avatar
Rusty Shackleford.
nice write up. thank you
sick-k20z3 is offline   Reply With Quote
Old 12-19-2009, 01:24 AM   #3 (permalink)
darrman25's Avatar
David
i tried to put it in the DIY thread area, but you must have to be a mod. to do that (it wouldn't let me)
This write up looks to be for a sedan. My coupe looks different inside.
darrman25 is offline   Reply With Quote
Old 12-19-2009, 01:24 AM   #4 (permalink)
sick-k20z3's Avatar
Rusty Shackleford.
meh they will move it there when they see it.
Old 12-20-2009, 04:03 AM   #5 (permalink)
www.yospeed.com
Yospeed's Avatar
David Yonehara
Great write up. I've taken off my door panels a billion times, but this definitely would've been helpful a few years ago!
The coupe door panels are pretty much the same. Pop out a few clips, remove a few screws, more clips, don't forget the door pull and wiring, and you're good to go!
Yospeed is offline   Reply With Quote
Old 12-20-2009, 04:06 AM   #6 (permalink)
great write up
moved to diy area
Originally Posted by webby
you're awesome - I'm about to probably call it a night as well.thanks for the help .
iluvmycsx is offline   Reply With Quote
Old 02-21-2010, 10:23 PM   #7 (permalink)
Albrecq'sSI's Avatar
Seanzie
is there a tip to unhooking the cables?? I can't do it
Albrecq'sSI is offline   Reply With Quote
Old 05-12-2011, 01:04 PM   #8 (permalink)
osohormiguerro's Avatar
hey, is there any DIY for this on the coupe? i know it is similar, but i'm not much of a whiz and dont want ot take the risk of screwing up
osohormiguerro is offline   Reply With Quote
Old 02-01-2012, 03:22 AM   #9 (permalink)
disfoo's Avatar
subd ty for post
disfoo is online now   Reply With Quote
Old 02-04-2012, 07:03 PM   #10 (permalink)
Shinhyeon/r18's Avatar
alan hamilton
someone has frostbitten fingers !
Shinhyeon/r18 is offline   Reply With Quote
Old 02-07-2012, 05:55 PM   #11 (permalink)
Extremely helpful, tyvm!!
Schumacher86 is offline   Reply With Quote
LinkBack to this Thread: http://www.8thcivic.com/forums/interior-style-mods/189428-diy-removing-door-panels-2006-honda-civic.html
2007 Civic Speaker Removal - Honda Civic Forum This thread Refback 08-31-2011 10:02 AM
2007 Civic Speaker Removal - Honda Civic Forum This thread Refback 07-06-2011 02:44 AM
Need Help On What Speakers will Fit Civic 2012 - Page 2 - 9th Gen Civic Forum : 2012 Honda Civic Forums - 9th Generation This thread Pingback 07-02-2011 01:13 PM
Finally did the DIY door panels and more simomo Introduction & Pictures 22 03-25-2009 02:06 PM
Removing door Panels on a 4 door Si CapnCrunch926 Mechanical Problems & Technical Chat 3 12-17-2007 08:26 PM
2006 Civic EX sedan door panels CREAKING 85CRX Mechanical Problems & Technical Chat 6 06-10-2006 06:51 PM
