DIY: Installing Autodimming Homelink Mirror (No A-Pillar) - 8th Generation Honda Civic Forum
Go Back   8th Generation Honda Civic Forum > Civic Technical > Do It Yourself Articles > Interior Style Mods
Old 10-27-2006, 07:08 PM   1 links from elsewhere to this Post. Click to view. #1 (permalink)
The following DIY works with any 8th Gen CIVIC that has a moonroof.
My wife loves her new Civic EX sedan but she really misses the homelink capability she had in her Pilot.
The Honda Autodimming mirror dealer option does NOT have Homelink capability (guess that would make too much sense). I purchased the Homelink autodimming mirror made by Gentex for LESS than the Honda kit (50-GENK40). Gentex seems to have an exclusive deal with the Johnson Controls folks. You can even get it with map lights an/or a compass/temp. You can also find these on E-Bay pulled from cars with new wire harnesses. Looks legit, but you never know......
Suggested site (no connection with said site. Just a happy customer): -Auto Dimming Mirrors-
Tell them you are a RAV4world member (I know, blasphemy. But it saves you some bucks). Tell them this is an "Autoclub" purchase
You WILL need the foreign vehicle bracket and wire cover.
I wanted to do this install without messing with the A pillar (and the enclosed Air Bag). I figured there had to be the power needed in the maplight/moonroof controller. Use the existing Honda autodimming mirror instructions to remove the maplight/controller module. After the module is removed you will have two wire harnesses. One with a white connector and one with a green connector.
The light blue wire on the white connector is +12V Battery. The purple wire with the silver stripe on the green connector is +12V Accessory. Finding that was a real challenge. The accessory line stays high up to 10 minutes after the ignition is turned off or until the door opens.
The wire harness for the mirror:
White striped wire is +12V accessory
The middle wire is Grnd
The black wire is +12V Battery.
The attached picture shows the wires before soldering:
After soldering everything, tape everything up good with electrical tape. I used one of the mounting bolts on the map light for the ground.
Doug
Originally Posted by MellowGato View Post
I got the auto mirror that does not have homelink, nor compass, nor any lights. Nothing fancy, just the auto mirror. That one just has two wires, + and ground.
Simple enough installation, except the wire shown in dhouse's DIY is a different color on the 06 SI. Mine was a green wire with a silver stripe. It is in the same location as the one shown in dhouse's picture above. Looking at the non clip side of the green connector, it is the 4th wire from the right.
http://static.flickr.com/109/2909027...cdaf04.jpg?v=0
dhouse, I hope you don't mind that I used your picture.
Hope this helps.
DIY: Installing Autodimming Homelink Mirror (No A-Pillar)-img_0432.jpg
dhowse is offline
Old 10-27-2006, 08:27 PM   #2 (permalink)
MellowGato's Avatar
Cool.
MellowGato is offline   Reply With Quote
Old 10-27-2006, 09:48 PM   #3 (permalink)
Garrison's Avatar
Garrison
Any more pics like the finished product???
Garrison is offline   Reply With Quote
Old 10-30-2006, 05:35 PM   #4 (permalink)
blanz's Avatar
Geezer Squad member #72
Thanks Doug.
I thought I was the only one lost without the Homelink Visor/Mirror. I called the guys you used and they hooked me up. Should ship out tomorrow.
Thanks again for the link and writeup.
One step closer to perfection.
Bill.
blanz is offline   Reply With Quote
Old 11-06-2006, 05:00 PM   #5 (permalink)
Garrison's Avatar
Garrison
Hey blanz would you post some pictures of the finished product and how the wire harness cover looks on the windshield?
Old 11-06-2006, 05:51 PM   #6 (permalink)
MellowGato's Avatar
Hope this helps.
Old 11-06-2006, 05:54 PM   #7 (permalink)
Civic4u's Avatar
Good post and Good work! Sound so simple and easy to do. Anymore picture
Civic4u is offline   Reply With Quote
Old 11-06-2006, 06:01 PM   #8 (permalink)
MellowGato's Avatar
No, I did not take any pictures - left my camera at work, and just couldn't wait.
It really was a simple install, all in all, took about 1 hour - but that is because I connected to the wrong wire the first time.
As soon as I figured out which was the correct accessory wire it was simple.
I could probably do it again in 30 minutes - but 20 of those minutes would be locating my tools...
Old 11-06-2006, 06:19 PM   #9 (permalink)
Garrison's Avatar
Garrison
Any chance you would post some of the finished product?
Old 11-06-2006, 07:07 PM   #10 (permalink)
MellowGato's Avatar
With the mirror adjusted, you cannot see the mount to the window or the wire coming out of the wire cover. As far as the wire cover - order the short one. I ordered the long one, which is about 1/2 inch too long, so I will have to shave a bit off. It is plastic so not a big deal.
If anyone is planning on doing this, I will be happy to help.
Links to Pics:
http://static.flickr.com/122/2909424...3e46d4.jpg?v=0
http://static.flickr.com/108/2909424...2f513b.jpg?v=0
http://static.flickr.com/100/2909424...676dd7.jpg?v=0
http://static.flickr.com/121/2909424...e94ede.jpg?v=0
http://static.flickr.com/103/2909424...d6a8ba.jpg?v=0
http://static.flickr.com/120/2909424...a510f0.jpg?v=0
http://static.flickr.com/111/2909503...0597ec.jpg?v=0
http://static.flickr.com/117/2909503...813345.jpg?v=0
Old 11-06-2006, 07:21 PM   #11 (permalink)
Garrison's Avatar
Garrison
Looks great ..Thanks!!!! I gave you some rep points for posting.
Old 11-09-2006, 07:41 PM   #12 (permalink)
blanz's Avatar
Hope this helps.
Did my Gentex mirror with Homelink after work today. As stated above, my '07was also the green/stripe wire as Mellow stated. With the information from dhause and Mellow, I ripped through the install in about 40 minutes.
If anyone wants to do this, order the shorter wire cover. I had to Dremmel off about a 1/2" from the long one.
All in all, it was a piece of cake. REAL happy that I can toss that clunky gararge door opener in the trash.
Thanks for the info...
Bill.
Old 11-09-2006, 07:50 PM   #13 (permalink)
Garrison's Avatar
Garrison
shorter wire cover check.
Old 11-10-2006, 09:39 PM   #14 (permalink)
MellowGato's Avatar
I have a custom homelink idea, just need to gather all parts, and I will post a DIY
Old 11-11-2006, 07:00 PM   #15 (permalink)
blanz's Avatar
What we need to do is fiqure out how to wire in automatic headlights. The Gentex mirror job was too easy, and well worth it. Wish we could use a system from an Accord or something to get the automatic headlight functionality. Gotta work on that one...
Bill.
Old 11-12-2006, 10:30 PM   #16 (permalink)
Civic4u's Avatar
Nice Job and pic This is not Honda OEM mirror, right? I assume to make sure.
Old 11-12-2006, 10:32 PM   #17 (permalink)
MellowGato's Avatar
Bill.
Not too worried about auto headlights. Too much work for too little payoff. I can switch on the lights when it gets dark...
Old 11-13-2006, 01:15 AM   #18 (permalink)
Garrison's Avatar
Garrison
Is it not an oem Honda Mirror.
Old 01-25-2007, 03:40 PM   #19 (permalink)
Garrison's Avatar
Garrison
Did you guys order the foreign vehicle bracket? Also, did you guys tuck the rest of gentex wire harness under the the headliner or did you cut it down and add the fuses back?
Old 01-25-2007, 07:16 PM   #20 (permalink)
blanz's Avatar
You will need the foreign car bracket and the short wire cover.
I had cut the excess wire and tacked on the fuse.
Bill.
LinkBack to this Thread: http://www.8thcivic.com/forums/interior-style-mods/18461-diy-installing-autodimming-homelink-mirror-no-pillar.html
Interior Style Mods on 8th Generation Honda Civic Forum | BoardReader This thread Refback 08-03-2011 12:29 PM
DIY: Installing Autodimming Homelink Mirror (No A-Pillar) - Page 3 - 8th Generation Honda Civic Forum This thread Refback 02-20-2008 03:19 AM
DIY: Installing Autodimming Homelink Mirror (No A-Pillar) - Page 4 - 8th Generation Honda Civic Forum This thread Refback 12-13-2007 07:21 PM
DIY: Installing Aftermarket Subs w/ Stock HU ( and Premium Sound System) GulfCoastGhostHunters Audio 503 01-23-2012 12:21 AM
Can someone please make a DIY installing an Injen CAI For the SI type-si Do It Yourself Articles 3 06-29-2008 02:02 AM
Installing autodimming mirror seaman Do It Yourself Articles 7 12-03-2006 03:49 AM
