Go Back   8th Generation Honda Civic Forum > Civic Technical > Do It Yourself Articles > Interior Style Mods
Old 01-25-2007, 06:18 PM   #21 (permalink)
Garrison's Avatar
Garrison
Originally Posted by blanz
You will need the foreign car bracket and the short wire cover.
I had cut the excess wire and tacked on the fuse.
Bill.
Did you stuff the remaining wire under the headliner? Also, did you cut before the brown adapter or after?
Garrison is offline   Reply With Quote
Old 01-25-2007, 07:20 PM   #22 (permalink)
gbae007's Avatar
Subbed for later.
Old 01-25-2007, 07:23 PM   #23 (permalink)
blanz's Avatar
Geezer Squad member #72
Stuffed it in the forward part of the headliner. It's been a while but I think I cut the brown adapter out and used T-taps to tie into the cars wire harness.
blanz is offline   Reply With Quote
Old 01-25-2007, 07:34 PM   #24 (permalink)
Garrison's Avatar
Garrison
Very nice tip. I left you rep sir. Thanks. I am doing this this weekend. I will post my pics as well.
Old 01-26-2007, 11:46 PM   #25 (permalink)
Garrison's Avatar
Garrison
OK I must have gotten a different harness. Mine had two greens, One yellow with a fuse, one red with a fuse, a brown,a white, and a ground. How you guys got three wire one is beyond me. So I think I screwed up. I have the red going to the light blue wire with the white adapter and the white wire going to the purple with silver stripe and the black to the screw whole as the ground. Any Ideas? Cause it won't operate my garage door?
Old 01-27-2007, 12:47 AM   #26 (permalink)
Garrison's Avatar
Garrison
Ok i think I figured it out. The yellow is the battery +12V goes to the baby blue. The accessory +12v was red and it goes to the purple with silver.
Old 03-02-2007, 01:23 PM   #27 (permalink)
ccarbajal08's Avatar
Chris
Garrison, what kind of Civic? I have the 07 SI and was wondering if wire colors are the same as yours?
ccarbajal08 is offline   Reply With Quote
Old 03-03-2007, 09:54 PM   #28 (permalink)
How do you remove the existing mirror mount?
This is probably an easy question but here goes. . . .
How do you remove the existing mirror mount that is currently glued to the windshield from the factory? I'm looking at the foreign mounting bracket and it says I need to glue it to the windshield
vphan13 is offline   Reply With Quote
Old 03-04-2007, 04:31 AM   #29 (permalink)
Chris
Nope. The foreign vehicle mount attaches on to the existing mount. I just did it and it's great!
Old 03-04-2007, 10:15 PM   #30 (permalink)
thanks
That makes this a whole lot easier!
Old 03-06-2007, 01:31 PM   #31 (permalink)
Chris
FYI, the foreign vehicle bracket doesn't sit flush with the windshield. I was trying to force it. Then, I realized that it wasn't contured for the 2007 Civic SI. There should be a little space between the bracket and windshield.
Old 03-09-2007, 12:27 AM   #32 (permalink)
Chris
Originally Posted by dhowse
The accessory line stays high up to 10 minutes after the ignition is turned off or until the door opens.
Do I need to worry about draining the battery when I shut the car off? How does this work?
Old 03-09-2007, 09:56 AM   #33 (permalink)
MellowGato's Avatar
If installed correctly, the mirror looses power when the car is shut off. It is designed this way - and that is the correct way to install it. Even if you connected it so it was always on, it draws such little power that you would not have to worry about battery drain unless you leave your car for weeks at a time...
MellowGato is offline   Reply With Quote
Old 04-03-2007, 10:03 AM   #34 (permalink)
Popinjay's Avatar
Anyone know how much current this thing draws? I just purchased it but don't see any electrical specs in the documentation.
Popinjay is offline   Reply With Quote
Old 04-03-2007, 10:37 AM   #35 (permalink)
kicker_jace's Avatar
Jayson
i did the same thing...
my mirror/homelink/compass came from my dads 04 maxima lol
kicker_jace is offline   Reply With Quote
Old 05-22-2007, 05:20 PM   #36 (permalink)
So What did you guys paid for the mirror with homelink, compass, temperature, autodime features ? Good DIY tip !
Thanks.
oris98 is offline   Reply With Quote
Old 05-22-2007, 05:36 PM   #37 (permalink)
RJJensen's Avatar
http://www.autodimmingmirrors.com/dealerpricing/index.php?cat_id=1&catname='Gentex%20Auto%20Dimmin g%20Mirrors'
RJJensen is offline   Reply With Quote
Old 07-15-2007, 11:15 PM   #38 (permalink)
Another successful installation. Thanks to everyone who provided instructions. I have 2007 Civic EX sedan. I connected mirror and Valentine 1 radar detector to purple/silver wire (+12v) and to a screw supporting map light/moonroof pod (ground). Works great.
Odessa is offline   Reply With Quote
Old 07-30-2007, 09:06 PM   #39 (permalink)
Sweet, I have an EX sedan and nice to hear the mirror fit properly. I can't wait to get one.
Kid Red is offline   Reply With Quote
Old 07-30-2007, 09:14 PM   #40 (permalink)
Jeremy
so is homelink just a garage opener?
jeremy0203 is offline   Reply With Quote
LinkBack to this Thread: http://www.8thcivic.com/forums/interior-style-mods/18461-diy-installing-autodimming-homelink-mirror-no-pillar.html
DIY: Installing Autodimming Homelink Mirror (No A-Pillar) - Page 3 - 8th Generation Honda Civic Forum This thread Refback 02-20-2008 02:19 AM
DIY: Installing Autodimming Homelink Mirror (No A-Pillar) - Page 4 - 8th Generation Honda Civic Forum This thread Refback 12-13-2007 06:21 PM
DIY: Installing Aftermarket Subs w/ Stock HU ( and Premium Sound System) GulfCoastGhostHunters Audio 300 07-04-2009 07:18 AM
Can someone please make a DIY installing an Injen CAI For the SI type-si Do It Yourself Articles 3 06-29-2008 01:02 AM
Installing autodimming mirror seaman Do It Yourself Articles 7 12-03-2006 02:49 AM
