Go Back   8th Generation Honda Civic Forum > Civic Technical > Do It Yourself Articles > Interior Style Mods
Old 05-04-2007, 03:02 PM   #41 (permalink)
e60.deluxe's Avatar
Originally Posted by ace_civic
im not sure but in california i think is mandatory to carry a spare tire
the E46 M3 has no spare tire, and now that BMW has switched to runflats, no BMW has a spare tire.
e60.deluxe is offline   Reply With Quote
Old 05-21-2007, 07:15 PM   #42 (permalink)
The runflats are crazy expensive tires though
Cliflyri is offline   Reply With Quote
Old 05-21-2007, 07:46 PM   #43 (permalink)
e60.deluxe's Avatar
yeah, you douynt have to use them to replace the OEMs though. just buy an electric pump and a temporary punture repair kit (~$30) like the one given in the M3 and buy normal tires.
Old 05-22-2007, 04:13 AM   #44 (permalink)
Bubble Gum Jr.'s Avatar
Dave
No offense but this seems like a pretty useless mod especially in your case since you have your entire car lined with dynamat. What's next ripping off your side and rear view mirror for weight reduction. Why not just gut the whole console along with the airbags.
Bubble Gum Jr. is offline   Reply With Quote
Old 05-22-2007, 04:49 PM   #45 (permalink)
mishima8's Avatar
If you actually read the entire thread you would note the reasoning and the explanation. Read and understand first. As noted before, the weight of the dynamat is more than offset by the removal of the tire etc.
Removing the mirrors would be illegal and useless. The reduction would be maybe 5lbs total versus 30lbs for the tire and another 16lbs for the battery and 10lbs for the wheel swap. IF this was a race car then I would do that, however since it's not, I wanted to drop some weight, without losing its DD functionality. In addition, I have lost about 20lbs myself since buying it, so losing weight is a good thing.
mishima8 is offline   Reply With Quote
Old 05-22-2007, 05:18 PM   #46 (permalink)
audiophile's Avatar
Ben
...dynamat is pretty damn heavy...
audiophile is offline   Reply With Quote
Old 05-22-2007, 05:58 PM   #47 (permalink)
mishima8's Avatar
Yes it can be, but still not nearly as much as the tire, etc.
Old 05-22-2007, 06:57 PM   #48 (permalink)
audiophile's Avatar
Ben
depends on how much dynamat is used.
I know I put at least 30lbs in my old single cab truck...
Is it just used in the trunk, or all over the car?
Old 05-22-2007, 09:24 PM   #49 (permalink)
mishima8's Avatar
Just the trunk.
Old 05-24-2007, 11:33 PM   #50 (permalink)
this is stupid
joenguyen is offline   Reply With Quote
Old 05-25-2007, 12:25 AM   #51 (permalink)
mishima8's Avatar
Originally Posted by joenguyen
this is stupid
And some noobies have no clue what tongue in cheek is ...
Old 05-25-2007, 12:44 AM   #52 (permalink)
huh..ok
Old 06-02-2007, 05:41 AM   #53 (permalink)
I will never remove the spare, so long as the freaking Michelin factor z's are gone. They are so undependable.
Zaxx81 is offline   Reply With Quote
Old 06-04-2007, 06:13 PM   #54 (permalink)
i don't know about all that dynamat and other stuff, but good idea with the foam. i'm gonna have to do that.
flipnautiq is offline   Reply With Quote
Old 06-29-2007, 10:20 PM   #55 (permalink)
looks good.. but i wouldnt do it
ugination87 is offline   Reply With Quote
Old 08-11-2007, 08:56 PM   #56 (permalink)
FG207Si's Avatar
Originally Posted by *007*civic
wont the dynamat be the same weight as the spare... and the wrench and jack arent needed if thers no longer a spare in there :P
dynamat is'nt something light it has a good amount of weight to it especially when you have the hole trunck covered in it, all that dynamat probobly weights just as much as the spare.
hope you have some bad asss subs in the trunk......
FG207Si is offline   Reply With Quote
Old 08-16-2007, 04:31 PM   #57 (permalink)
bueno4x4's Avatar
Bueno
To each his own, but I wouldn't do it. Like everyone said, IMO it's not worth it
Bueno
bueno4x4 is offline   Reply With Quote
Old 11-03-2007, 01:15 AM   #58 (permalink)
27IVTEC's Avatar
Jones
I buoght a bulk pack of original (39sq.ft.) and did most of my trunk and just got tired of working with it. I plan on finishing it soon so I just left the rest in the trunk to see if I could tell any difference, I have 2 amps, x over, custom flush mounted amp rack and 2 Rockford P2 10's and I dont really notice that much of a difference with them in/out. Nor could I tell a difference with the Dynamat being in the trunk.
27IVTEC is offline   Reply With Quote
Old 11-19-2007, 01:43 PM   #59 (permalink)
Originally Posted by mishima8 View Post
I like fa1's response, but I have my Sigs for protection ;-)
I kept them so if I end up needing to jack it, I have it at hand. That way when I have someone bring the spare (if God forbid) I can do a quick swap.
WOW.
david2613d is offline   Reply With Quote
Old 11-19-2007, 02:10 PM   #60 (permalink)
rbsjnh's Avatar
WARNING: Honda Zealot
just buy fix a flat...weighs less than 1lb...thats my spare
rbsjnh is offline   Reply With Quote
