DIY: OEM Cargo net and Trunk Tray
I know this seems like a lame DIY, but I have to say that the cargo net has turned out to be one of the most annoying mods I’ve performed thus far, so I figured you should all know what you are getting into if you purchase one.
Honda’s list of tools required:
Cargo net install kit comes with:
![]() First, you remove your trunk fabric. All of the clips will be simple except for two closest to the spare tire compartment. You will need to pry these off gently with screwdrivers. ![]() Next, you widen the two upper holes in the trunk sides. You are supposed to use a 9mm drill bit for this, but you can use one of these if you are careful: ![]() Paint the holes with touch-up paint, then install the rivnuts using the "proper" tool, or Gone's invention. ![]() Now, you place the trunk lining back and lay the template out to mark your holes. ![]() You can use a nail to poke through the fabric and mark the metal beneath. lift the fabric and use a 1/8th drill bit to start your four holes. Move up to a 7/32 bit. Place all the fabric back and screw in your six anchors: ![]() Put all the trunk brackets back into the fabric. Cut four holes in your tray. ![]() Attach the net vertically or horizontally and you are ready to buy groceries and .
Last edited by r3v; 12-01-2008 at 01:55 PM. Reason: ooops--apparently I need to learn to type |
#8 (permalink) | |
The Addiction Returns...
Gotta love honda, lol. I remember my Jetta had preinstalled hooks in the trunk to latch the cargo net to. I guess since the Si is only 20k instead of 21k they decided not to go that route, lol.
#11 (permalink) |
most of the honda accessories come with instructions. sometimes it is easier to hop on here and see actual pics and a write up/walkthrough. indeed, she kind of did re-post the instructions. but if it helps one other person out there do their install then it was a success.
#12 (permalink) | |
Plus, the instructions don't mention anything about removing the trunk lining.
| DIY : Cheap Cargo Net | djpaw | Inside and Out | 14 | 03-18-2009 06:58 PM |
| DIY: Rivnut puller for install of trunk Cargo Net | Gone | Do It Yourself Articles | 12 | 12-11-2008 09:37 AM |
| Cargo net and Trunk Tray | poorguy | Civic Coupe And Sedan | 1 | 11-28-2008 03:43 PM |
