IMG install?!? - 8th Generation Honda Civic Forum
Go Back   8th Generation Honda Civic Forum > Civic Technical > Bolt-Ons And All-Motor > Intake & Spacer Discussion
Closed Thread
Old 06-21-2006, 05:34 PM   #1 (permalink)
SonicK20Z's Avatar
Rob
IMG install?!?
so who here has done the Hondata IMG install... I got mine in, and planned on doing it with my intake install last night, and then discovered after referring to the Helm's that it invovled draining all the coolant from the car, disconnecting the fuel rail, etc. Is this true? Also, how exactly is the IM itself held on there? I see the 2 nuts holding it onto the stud along the top, and then there are several bolts along the top and bottom of the IM flange... how in the world do you get to the ones below it?
I really want to do this IMG install, but I haven't the foggiest on removing the IM to get going. Can anyone give me any advice or a writeup or pics or anything. I need to know exactly what is required for me to do this install. Thanks a ton!
- Rob
SonicK20Z is offline
Old 06-21-2006, 06:45 PM   #2 (permalink)
Tuna Fiddle
twistedframe's Avatar
Dave
this has been discussed a few times before
Hondata heat shield installed (pics)
How to install heat shield intake gasket and bypass TB coolant on 06 si.
twistedframe is offline
Closed Thread
install aftermarket radio on DX sedan jamieZ Civic Coupe And Sedan 12 01-17-2007 10:08 PM
How to install heat shield intake gasket and bypass TB coolant on 06 si. 06redsi Civic SI 30 08-16-2006 11:20 PM
DIY install of new head unit in sedan UK/AUS aussiebuddha I.C.E., Electrical, Security, & Navigation 4 04-04-2006 03:30 PM
Does anyone know how to install CAR PCS!!! gaspar2411 I.C.E., Electrical, Security, & Navigation 21 03-14-2006 09:09 AM
