Intake FAQ - Page 6 - 8th Generation Honda Civic Forum
Go Back   8th Generation Honda Civic Forum > Civic Technical > Bolt-Ons And All-Motor > Intake & Spacer Discussion
Old 01-07-2008, 10:20 AM   #101 (permalink)
Emmanuel
the fujita will produce higher numbers than the injen everytime. sorry but its the truth
xfactorwrx is offline   Reply With Quote
Old 01-07-2008, 10:25 AM   #102 (permalink)
Emmanuel
Originally Posted by Tom View Post
actually cost of the oe parts are alot less then that, 07-08 cr-v tube is $20.71 at retail list, and the upper air filter housing is $24.14 at retail list, so that is only $44.84 plus tax maybe, rest my guess is for research and development.
did the CRV tubes come down in price? cause last time i checked the retail on it is over 35 and the cost is around 27, i get the cover for 17 though
Old 01-10-2008, 03:58 PM   #103 (permalink)
Originally Posted by BTRobertson View Post
That's an even better point. I was actually wondering why no one has designed an intake system combining BOTH the CAI and SRI because that's technically what's in the stock system. There's an engine compartment air box plus the air box in the bumper, so you have a Y connection. Why not do that with a high flow intake?
you mean this?
its not out for our cars yet but comptech is working on it.
this is pic of there icebox for a diff car.
doesnt gain as much as other intakes but its a good option if you want to avoid heat soak.
it draws air from the same area as CAI and the filter is located in the engine bay. no idea is new remember it just gets rethought after a while.
vtecmike1 is offline   Reply With Quote
Old 01-10-2008, 04:14 PM   #104 (permalink)
BTRobertson's Avatar
B.T. Robertson
Well, true, but a "new" idea would be a high-flow air filter on both ends with high-flow plumbing - heat soak, maybe...but between the CAI's "colder" air and the "heat-soaked" warmer air from the SRI, the combination would have to produce a median air temperature which would be a) warmer than the CAI alone, but b) cooler than the SRI alone. Right? I mean, I'm no physics expert, but isn't that the point of the stock system now? It's just restrictive with the plumbing and the filters, but the concept of a median cooler temperature must be the point of making a Y-connected air intake system.
And that picture doesn't look anything like a Y-connected filter system. It looks like the stock air box in the engine compartment?
BTRobertson is offline   Reply With Quote
Old 01-10-2008, 04:19 PM   #105 (permalink)
it does connect draw its air from below its just not showing everything. and your saying run 2 air filters? lol im sorry but if thats what your saying its 1. poitnless. and 2. going to reduce hp from restriction.
to sum it up the ice box is basically run the way the stock system is. only larger less restricted plastic piping for much less heat soak then after market aluminum systems.
its exactly what your looking for when you describe what you want. but its not out yet
enclosing the filter is also a way to shield it from the engine. unless you wanted to replace the lower box completly. but if i remember correctly comptech connects the ice box to the factory lower box.
Old 01-10-2008, 04:30 PM   #106 (permalink)
B.T. Robertson
Bud, there are two air filters in the STOCK system now, fact. The cold air box in your bumper has a filter in it, draws air in, then plumbs it up to the engine air box, which has a filter in it - I disconnected it all myself when I installed my SRI, so I know this is the case. What is the point of having this system if not to draw a lower median temperature using air from the bumper air box and the engine air box? Am I missing something here? It wouldn't surprise me, just clear it up if I am.
I do see what you're saying about the icebox, but can the icebox produce the same gains as even an SRI system alone with heat soak. Maybe? Maybe not? We don't know because it's not out yet, so we'll have to see.
Either way, I was just saying that there must be an engineer out there who could combine the CAI and SRI aftermarket air intake models into one combination model, which would produce a median cooler air temperature by allowing air to flow from down in the bumper, unrestricted, and combine it with the engine air box, unrestricted. This Icebox seems to ONLY deal with the upper engine air box, which is only half the battle, in my opinion.
Old 01-10-2008, 04:57 PM   #107 (permalink)
i see what your lookin for. we'll just have to wait and see.
the comptech has a connection on the bottom to connect to your lower factory cold air box if i remember correctly so it draws air from the lower box but has the filter enclosed in the engine bay thats why i thought its what you wanted. its like stock almost except its larger piping on top like a short ram and has a cone filter only its enclosed.
Old 01-16-2008, 12:19 AM   #108 (permalink)
Ainokea_Si's Avatar
Tony
Originally Posted by slesholdofthreep View Post
Air Fuel Ratio
More flow more go
Ainokea_Si is offline   Reply With Quote
Old 01-20-2008, 04:48 PM   #109 (permalink)
bz
i have a injen cai with a aem by pass valve im bout to put on. i looks like it might work. im waitin tilll it gets a lil nicer out tho.
bruzicska is offline   Reply With Quote
Old 01-28-2008, 01:25 AM   #110 (permalink)
huy1224's Avatar
Post pics when you get this done, i'd like to see it! I have an Injen CAI, but have yet to install it. Main concern is hydrolocking. I live in Philadelphia, where rain can be pretty bad at times and those potholes can be deadly. So if it's pouring out and I can't see a pothole, I'm afraid the car would dip in and soak up some water!
My friend with the Injen CAI for the TSX says that his CAI could've also been installed as an SRI if he wanted too. Is this also possible with the 06+ Si CAI? I have the CAI, but it's still New in Box, just in case I change my mind on it. I am weary about installing........
huy1224 is offline   Reply With Quote
Old 01-28-2008, 10:59 AM   #111 (permalink)
B.T. Robertson
Well, we'll see just how much heat soak an SRI takes on because I'll be at a dyno next week getting six total "pulls". I have the Fujita F5 SRI already installed, so the first three pulls on the dyno will be with that installed so we can get a baseline. I'll post the WHP and torque gains over stock. Then, they're installing my Ingalls "Stiffy" torque dampener and my new Skunk2 70mm Mega Power R cat back exhaust - they'll be hooking it up to the dyno again for another three pulls to see what the total power gains are with the exhaust. So, those final numbers will be with three products installed:
1.) Ingalls Stiffy torque dampener
2.) Fujita F5 SRI - claims are between 9 and 11 whp over stock air intake (no aftermarket exhaust)
3.) Skunk2 Mega Power R cat back exhaust system - claims are between 5 and 7 whp over stock with NO intake installed, just replacing the stock exhaust.
The import tuning shop I'm taking this to believes I will see between 18 and 24 whp gains over stock with these mods. I'll be taking pictures and will have video documentation, along with the official numbers from the shop. Skunk and Corsport USA are interested in getting these numbers from me, so stay tuned! If I get good video, I'll post on YouTube and let all of you know.
Old 01-28-2008, 12:01 PM   #112 (permalink)
Yo, guys i just have quick question
i have civic 1,8 A/T
i just want to ask if i can get any intake CAI for it
coz i asked lots of people and they told me that the intakes only fits the M/T
does the injen or aem fit?
thanks
streetballer is offline   Reply With Quote
Old 01-28-2008, 12:08 PM   #113 (permalink)
B.T. Robertson
Hmm, never saw any specification which said anything about the transmission. I'll check around and see. As long as your air box and plumbing is setup the same way, I don't see what the difference is.
Old 01-28-2008, 12:38 PM   #114 (permalink)
it is writtin in injen website and even the installation manual that the intake fits only the M/T
Old 01-28-2008, 12:52 PM   #115 (permalink)
B.T. Robertson
I just received verification that there is indeed a difference between intakes on different transmission types. You'll have to get one that fits the A/T, so if the Injen says M/T only, you're pretty much s.o.l.
Old 01-28-2008, 01:43 PM   #116 (permalink)
kk dude do have any idea about any intake that fits the A/T
please any one can help me find one
anyone have intake on his A/T civic
Old 01-31-2008, 04:49 PM   #117 (permalink)
xrs54's Avatar
has anybody heard of HPS? this guy told me about their intakes, just woundering if anyone knows anything about it.
xrs54 is offline   Reply With Quote
Old 01-31-2008, 05:42 PM   #118 (permalink)
Whocares05050's Avatar
How come noone ever talk about, or has any knowledge, or dyno charts / afr charts of the AEM SHORT RAM INTAKE?
Maybe ive missed it, but some help would be great.
Whocares05050 is offline   Reply With Quote
Old 01-31-2008, 08:39 PM   #119 (permalink)
B.T. Robertson
High Performance Solutions, I've heard of them. But, I don't know much about their reputation for the intake they make - the claim is 15-20hp over stock manifold intakes. I've heard the X-intake is the way to go.
Old 02-04-2008, 10:49 PM   #120 (permalink)
albanz35's Avatar
thanks
i have heard that the in jen does indeed fit in a AT but i deffinatly know that a Fujita f5 does fit in... it says MT only but i have an AT and it fits.... there was a tight squeez between the wheel well and the frame but it fits
albanz35 is offline   Reply With Quote
LinkBack to this Thread: http://www.8thcivic.com/forums/intake-spacer-discussion/30376-intake-faq.html
Intake FAQ - Page 6 - 8th Generation Honda Civic Forum This thread Refback 12-17-2007 12:36 AM
Guide: Installing Injen CAI for R18 Civic tomasro Intake & Spacer Discussion 104 01-10-2012 03:19 AM
K&N Short Ram Intake DIY Install for Si, with Pics! dowNNshift Do It Yourself Articles 88 01-18-2008 01:25 PM
K&N 69 Series Typhoon Intake System??? Proudhalo4 Bolt-Ons And All-Motor 56 10-25-2007 10:36 AM
How to install heat shield intake gasket and bypass TB coolant on 06 si. 06redsi Civic SI 30 08-16-2006 11:20 PM
Help Intake info needed----Dose a Intake Kill your warty? coach2fast Intake & Spacer Discussion 8 06-23-2006 03:51 AM
