3.5" intake running issues - 8th Generation Honda Civic Forum
Go Back   8th Generation Honda Civic Forum > Honda Civic Technical > Bolt-Ons And All-Motor > Intake & Spacer Discussion
Old 07-05-2012, 12:40 AM   #1 (permalink)
b20eg6hatch's Avatar
So I built my intake the last week basing it off of a few threads here on the board. Well got the intake on the other night, went for a test drive and the car is falling on its face if you push more than about 60% throttle. It gets better after third gear but you can definitely tell she's slower pretty bad. Now before anyone says anything, Flashpro is definitely the next mod but is anyone else having this problem? I looked around at a few threads and even the Rick Specd intakes are not saying you have to have Flashpro or a reflash to run their intake, any ideas?
b20eg6hatch is offline
Old 07-05-2012, 12:44 AM   #2 (permalink)
vtecfred's Avatar
Fred
Did you install your MAF sensor in the correct direction?
Sent from my Galaxy Nexus
vtecfred is online now   Reply With Quote
Old 07-05-2012, 12:46 AM   #3 (permalink)
The MAF needs to be tuned or eliminated with flashpro. The car runs open loop until 4k then switches to closed loop. The MAF nubers are extremely skewed with a non stock intake of any type. Look at your stock air box and see how the air is directed onto the maf location. You will eventually get a cel for MAF numbers and possibly some 02 issues. Get that off your vehicle until you get some tuning and/or knowledge of how to tune. I would also reccomend a velocity stack at the end of your intake wiht a filter that will fit it.
sw0ggd0gg is offline   Reply With Quote
Old 07-05-2012, 02:49 PM   #4 (permalink)
that happend to me to all it is its to much air and it leans the car out bad i just got a flashpro and it went away i will find out how to make it work with out a flashpro for you give me in till the weekend
torreto is online now   Reply With Quote
Old 07-05-2012, 03:33 PM   #5 (permalink)
RRFG2DD's Avatar
Stefan
Offcourse you would need a fp, for an intake that big its common sense. Research better next time? I would not run any kind of aftermarket intake without it.
RRFG2DD is offline   Reply With Quote
Old 07-05-2012, 05:09 PM   #6 (permalink)
Drew
I would take that intake off now man. The ECU thinks there is much less air entering the engine then there actually is. The ECU can only compensate so much with the O2 sensor in closed loop (part throttle) When you are getting on your car you probably running a 14-15:1 AFR and your going to be saying bye bye to your motor. Not trying to be a d**k or anything. Just looking out for a fellow 8th member
sexy_rexy is online now   Reply With Quote
Old 07-05-2012, 05:11 PM   #7 (permalink)
Thank you sir.
I would greatly appreciate that. Let me know.
Maf is installed the exact distance from the throttle body, same position, inflow the same direction.
FLMAO. You've stated nothing more than I did. I clearly said I had researched it. Does the rickSpecd state flashpro is needed? Do any of the 3.5" intakes state that? No they don't, thank your your for your .02. That's why I posted the thread.
b20eg6hatch is offline   Reply With Quote
Old 07-05-2012, 05:18 PM   #8 (permalink)
Drew
You may be correct in stating that none of the item description state you need Flashpro to run them but, I don't think you understand how a MAF works. They a calibrated to a certain diameter piping and if you change the diameter of the piping, every reading and calculation it makes is wrong. not to mention open loop (WOT) uses a predetermined fuel table based off the factory MAF piping. Do what you want man and I hope your car makes it until you get your FP
Old 07-05-2012, 05:18 PM   #9 (permalink)
RRFG2DD's Avatar
Stefan
thats why i said its common sense buddy, dont get angry with me now
i was just trying to help not to bash ur thread, but when i didnt know i pm'd Rick and he said yes you would need fp before intake so i bought fp and now saving for intake.
Old 07-05-2012, 05:41 PM   #10 (permalink)
rick spec'd says you need flashpro...
jimmak85 is offline   Reply With Quote
Old 07-05-2012, 06:50 PM   #11 (permalink)
K20Z3allmotor's Avatar
12.423 @ 109 mph No AC jaja
i have no idea why you would think you would not need FP, its practically common sense because you changed the inside dia of the pipe from 3 inch to 3.5, the ECU is reading a ton of un metered air. hopefully you didn't damage anything by running it lean like that.
K20Z3allmotor is offline   Reply With Quote
Old 07-05-2012, 10:08 PM   #12 (permalink)
Rick Spec'd 3.5" Cold Air Intake Systems - $299 Shipped - Now Available!!
Post 8 (with & without tuning). My fault for not reading it more but this and a few others is what I was basing it on. Oh well, just have to be easy on her for till Flashpro arrives.
Old 07-05-2012, 10:11 PM   #13 (permalink)
Drew
He states further in the thread that you need FP and it doesn't specify on his website either. Its kinda one of those things you have to follow their threads for a while or you wouldn't know. No biggie though man. You have an FP ordered so just take it easy on the car until you get it. Best of luck
Old 07-05-2012, 11:48 PM   #14 (permalink)
I would not drive the car like that at all. Go back to stock. Then put it back on when u get FP
Old 07-06-2012, 10:42 AM   #15 (permalink)
K20Z3Addict's Avatar
+1 Take it off ASAP. Go back to OEM or toss on a model specific "tuned" SRI/CAI meant for a stock engine.
K20Z3Addict is offline   Reply With Quote
DIY "k-intake" with HPS silicone intake hose and Intake Air Temps results BLouIsGod Intake & Spacer Discussion 39 06-05-2011 06:23 PM
Important R18 "header/downpipe" fitment issues revealed... sgtmorph Header Discussion 46 02-15-2011 06:21 AM
Anyone Running Eibach Sportlines have Clearance Issues? AutumnOrangeGT Garage 2 01-06-2011 05:54 PM
anyone running this tire/hfp combo without issues? TheTeflonDon Wheel And Tire Upgrades 1 11-30-2010 09:24 AM
