Go Back   8th Generation Honda Civic Forum > Civic Technical > Bolt-Ons And All-Motor > Intake & Spacer Discussion
Old 06-08-2009, 12:27 AM   #1 (permalink)
ihazvtak's Avatar
Jon
PRM intake filter + HPS intake arm
After a couple weeks of emailing back and forth with Gerry of PRM intakes on what filter to use for my custom intake setup, we finally decided to go with the 15" S2000 PRM Filter. Along with the PRM filter, i also purchased a HPS silicone intake arm. I used a 45 degree 3” to 3.5” coupler that was supplied by PRM to angle the filter downwards so that the car could draw in cooler air. Install was easy, only tricky thing was removing the stock lower airbox mounting bracket to make room for the larger filter. Overall i am very happy with the PRM filter, its top notch quality. I noticed a much stronger pull throughout the RPM compared to my K&N filter I had on before. I've had a few other intake setups such as X-styled intake, icebox w/ M&M scoop, and sri w/ K&N universal intake arm w/ M&M scoop and this setup by far has been the best setup (judging from my butt dyno). The sound from the filter is also very nice, its quiet when driving normally but when you get on it, it makes the car sound very deep and aggressive. Big thanks to Gerry of PRM intakes!
Before:
After:
As you can see, the filter extends all the way down like a CAI to get cold air but retains the qualities of a SRI, its the best of both worlds!
ihazvtak is offline   Reply With Quote
Old 06-08-2009, 02:08 PM   #2 (permalink)
Josh
+1 for creativity. this setup looks promising. less heat due to the hose, there are minimal bends in the tubing. an under the car shot would be optimal to see where the filter is pointing. anyway, good job dude.
Turk is offline   Reply With Quote
Old 06-08-2009, 03:57 PM   #3 (permalink)
adam-'s Avatar
awesome
adam- is offline   Reply With Quote
Old 06-08-2009, 03:59 PM   #4 (permalink)
''CA'' All day.
Zeuceone's Avatar
your probably running lean due to how long your sri is.
Originally Posted by Zeuceone View Post
For a good time call 909 418 8773
Old 06-08-2009, 04:02 PM   #5 (permalink)
Si-Onara
JEA86's Avatar
Jeremy
his MAF retains the Divders so his A/F ratios will be in check
JEA86 is online now   Reply With Quote
Old 06-08-2009, 04:04 PM   #6 (permalink)
BioHazard's Avatar
Old Man
still going to get some heat soak off the radiator hose, need to purchase the napa hose #7777 to gain about 3-4 inches of space between the hps tube and the radiator hose
looks very interesting, nice work
BioHazard is offline   Reply With Quote
Old 06-08-2009, 04:26 PM   #7 (permalink)
cuzzybubba1's Avatar
Jason
Nice!
cuzzybubba1 is offline   Reply With Quote
Old 06-08-2009, 05:00 PM   #8 (permalink)
''CA'' All day.
Zeuceone's Avatar
doesnt matter if he has them.
Old 06-08-2009, 05:18 PM   #9 (permalink)
Asif22's Avatar
Asif El-Mubaslat
can you get a pic from under the car? it looks like the filter would be like right in the header..
Asif22 is offline   Reply With Quote
Old 06-09-2009, 01:34 AM   #10 (permalink)
ihazvtak's Avatar
Jon
Can you explain how i may be running lean? i have no idea if it is, all i know is that it pulls harder than my K&N filter lol
ill try to get a pic, the filter is pointed towards the bottom right and isnt that close to the header
Old 06-09-2009, 02:31 AM   #11 (permalink)
spenny's Avatar
Looks... interesting?
I like the HPS arm, but I dont know about the PRM filter. Different is good... but I'd go with the Apexi, or a velocity stack + K&N since they are proven at freeing up power.
spenny is offline   Reply With Quote
HPS Intake Arm, WS2 Vid ihazvtak Intake & Spacer Discussion 1 05-19-2009 10:35 PM
PRM Jet Stream Intake 08R18 Civic Coupe And Sedan 2 05-16-2009 02:07 PM
Prm Racing Intake danndan1 Intake & Spacer Discussion 83 05-11-2009 11:09 AM
