Old 05-12-2008, 10:31 AM   #1 (permalink)
I got a mangina!
"Ridge"Racer's Avatar
Justin
DIY: type R, Mugen Si Snug shiftboot installation
Ok, so i didnt like the ring adapter for the type r knob, and i dont like the way the lock nut looks under the shift knob. Heres a quick fix to make the boot stay flush with the knob, this will also lower the knob a bit and give the shortshifter appearance.
******This can also be done with the stock shift Knob******
First, start by removing the knob and lock nut. then pull up here on both sides of the base, it pops up pretty easy.
Next, stagger two zipties on top of each other below the threads. Position them so that the plastic piece inside the top of the shift boot sits just below the threads.
Now, do a test fit with the shift boot plastic ring, it should rest on the zipties, this will prevent it from moving down, the key is to postion the zipties so that when the knob is on, it will sit flush with the top of the boot and wont move around.
Finally, screw on your type R or Mugen Si shift knob, without the locknut, it should stop at the end of the threads and the numbers 1-6 should have a perfect north and south position. voila! now you have the appearance of a shortshifter, with a nice clean shiftboot to knob interface!
TW FG2 Sold....
"Ridge"Racer is offline
Old 05-12-2008, 10:37 AM   #2 (permalink)
Dont Mess With This Zohan
GETxERxDONE's Avatar
Nichuma Ben Gabriel Ha Levi
nice! looks great man.
Click Sig for Details on the Wreck, it just gets worse.
DIY HFP Front Lip Overlay CHEAP! | DIY HFP Side Skirt installation
DIY AUTO Shift knob Removal | DIY E-Brake Trim removal
License = SUSPENDED Days left = REENSTATED!
GETxERxDONE is online now
Old 05-12-2008, 01:25 PM   #3 (permalink)
BRSi's Avatar
Perfect. Stupid nut looks horrible! Doing mine today. Thanks
BRSi is offline
Old 05-12-2008, 01:27 PM   #4 (permalink)
How does it taste mofo?
xheartcore_boyx's Avatar
Addy
Hmm,i see something in the door storage pocket...installed yet ?
xheartcore_boyx is online now
Old 05-12-2008, 04:28 PM   #5 (permalink)
BRSi's Avatar
Yup it is very nice for a stock shifter, but I don't like the shape of it.
BRSi is offline
Old 05-12-2008, 05:29 PM   #6 (permalink)
I got a mangina!
Justin
jdm clutter, S2k pushstart..................installed.
TW FG2 Sold....
Old 05-12-2008, 05:49 PM   #7 (permalink)
B-Stylz's Avatar
Brian
Thanks for posting this. I removed that ugly nut the 2nd day into ownership. Will be nice to have it sit the way it should finally.
B-Stylz is offline
Old 05-12-2008, 05:53 PM   #8 (permalink)
I party better than you
illusionstwice's Avatar
The original --> "J" <--
Looks good. I would def use this idea if I ever change my shift knob......again.
Oh, and on the "appearence of a short shifter" comment... well it makes the shifter look shorter, in height. When you have a short shifter though, it shortens the throw between gears, not your height of the shifter itself.
Originally Posted by giftd151 View Post
Dude those wheels are sweet. Not only can you drive on them, but you could also use them to make pasta! What will Mercedes Benz come up with next?
illusionstwice is offline
Old 05-12-2008, 07:05 PM   #9 (permalink)
I got a mangina!
Justin
yeah, i know but i dont want the short shifter, i think shortening the throw for someone like me would just cause damage cuz i shift so hard sometimes! i just like the appearance, i think twm is the only short shifter with the option of using the knob to make it lower in appearance, correct me if im wrong, thats the look i was going for, thats all!
And technically, making the knob sit lower would be less taxing on the throw from a mathematical "lever" perspective. I think this diy really makes it sooooooo much more clean in appearance.
TW FG2 Sold....
Old 05-12-2008, 08:43 PM   #10 (permalink)
Ninja Turntablist
ThaJazz's Avatar
Thanks--gonna give it a shot!
ThaJazz is offline
Old 05-12-2008, 08:52 PM   #11 (permalink)
07Nighthawkbp's Avatar
Nate
nice gonna do mines now
07Nighthawkbp is online now
Old 05-13-2008, 02:48 PM   #12 (permalink)
B-Stylz's Avatar
Brian
Not for all for shifters though. Some lower the height by a fair margin.
B-Stylz is offline
Old 05-13-2008, 03:24 PM   #13 (permalink)
vingavina's Avatar
looks good
vingavina is online now
Old 05-13-2008, 04:29 PM   #14 (permalink)
haha. did the same thing.
ebphoto is offline
Old 05-19-2008, 07:17 PM   #15 (permalink)
Chosen's Avatar
Andrew
yea just did mine. cant get the numbrs to sit north and south tho. looks good anyways.
Chosen is offline
Old 05-19-2008, 07:24 PM   #16 (permalink)
I got a mangina!
Justin
really, my threads ended perfectly north and south, what knob are you using? ive tried a mugen, type r and oem.
TW FG2 Sold....
Old 05-19-2008, 08:04 PM   #17 (permalink)
I'd did basically the same thing, but I used a small rubber grommet under the boot to hold it up and another rubber grommet on top of the boot ring. The one on top of the boot rings acts like the stock lock nut and helps to line up the numbers correctly.
You can just barely see it under the knob.
DumbasSi is offline
Old 05-19-2008, 08:47 PM   #18 (permalink)
Chosen's Avatar
Andrew
im using a type r. i got it tho. part of the zip tie was on the last threads so i just moved it a bit and got it.
Chosen is offline
Old 05-20-2008, 07:33 AM   #19 (permalink)
I got a mangina!
Justin
yeah, you have to adjust the ziptie so that it sits just below the threads or it will interfere with the way the knob sits, if there is nothing stopping the knob from tightening down all the way then it should sit with the numbers north and south perfectly.
TW FG2 Sold....
Old 05-20-2008, 12:49 PM   #20 (permalink)
B-Stylz's Avatar
Brian
I think the zip tie method looks better then the gromet method.
B-Stylz is offline
DIY: JDM Civic Type R Shift Knob + Boot installation (2007 Civic Si Sedan) BTRobertson Do It Yourself Articles 33 08-05-2008 06:49 PM
Type-R shiftboot/collar/knob vicSi Inside and Out 6 03-25-2008 11:03 PM
Nerd_1 Updated Mods: Type R shiftboot + Mugen Visors nerd_1 Inside and Out 18
