| View Poll Results: What location is best to stick a blind spot mirror on the drivers side view mirorr? | |||
| Position 1 |
5 | 22.73% |
| Position 2 |
1 | 4.55% |
| Position 3 |
13 | 59.09% |
| Position 4 |
3 | 13.64% |
| Voters: 22. You may not vote on this poll | |||
#10 (permalink) |
Sit in your seat and adjust the mirror vertically so that you can easily see behind you far down the road. Then to get it set right horizontally, move it out until you can't see the back of your car anymore. You already know what the back of your car looks like so you shouldn't need it in the mirror. Once you do that, make sure you see the line in the middle of the road in your mirror so you know it's not set too far out. Do the same with the other mirror and get your rear view set to look straight behind you and you won't have a blind spot. It's how I have mine set, and I can see every vehicle around me at all times, including motorcycles. That way you don't need those ugly bug eyes on your mirrors.
*edit* As far as the bug eyes go, put them in #3 to max the range you get from them. That's where they should be to be installed properly. Any other spot reduces the effectiveness of the mirrors because of the angles between you, the mirrors and the other cars you're trying to see. Last edited by Itchytoe; 05-11-2008 at 07:49 PM. Reason: added info as noted |
| Removing mirror from side mirror housing... | tarh33l10 | Mechanical Problems & Technical Chat | 9 | 06-02-2008 09:14 PM |
| Hybrids and the Blind!!!!! | Cybergypsy | Water Cooler | 16 | 10-04-2007 10:37 PM |
| Removing blind spot mirrors | P1ng | Inside and Out | 11 | 08-07-2007 01:06 AM |
| Blind spot mirror recommendations? | fahdoos | Civic SI | 23 | 09-11-2006 01:42 PM |
| A-pillar blind spot? | madbay | Garage | 8 | 12-13-2005 09:36 PM |
