Old 04-02-2008, 05:30 AM   #1 (permalink)
jbsali's Avatar
Joel
Question Are the two (white Peg holders for the Rear H) removable?
I want it to be flat so that i can place a aluminum transformer emblem on the black. I figure that those two white peg holders are going to be in the way unless i remove them.. can they be removed? and can they be reused if needed? Thanks in advance!
jbsali is offline   Reply With Quote
Old 04-02-2008, 06:41 AM   #2 (permalink)
The Slip
BlaqkAudio's Avatar
James
They're part of the H. When you remove the H, they should come out too, unless you broke the H.
BlaqkAudio is offline   Reply With Quote
Old 04-02-2008, 11:28 AM   #3 (permalink)
Dont Mess With This Zohan
GETxERxDONE's Avatar
Nick
no they arent part of the H, the white pegs go into the holes. then the pegs that stick out on the emblem snap into it
Click Sig for Details on the Wreck, it just gets worse.
DIY HFP Front Lip Overlay CHEAP! | DIY HFP Side Skirt installation
DIY AUTO Shift knob Removal | DIY E-Brake Trim removal
License = SUSPENDED Days left = REENSTATED!
GETxERxDONE is offline   Reply With Quote
Old 04-02-2008, 11:59 AM   #4 (permalink)
PhoR11's Avatar
Bradley
Yes, they're removable and re-usable if you're careful removing them.
If you pull the emblem pegs out first then it's really easy.
If you look at them carefully, they have 2 or 4 (I can't remember) places where the peg flairs out on the inside of the trunk when it goes through the hole in the trunk.
Those little flaired pieces of plastic are all that keep it in place.
Just pinch those points with a needle nosed pliers or poke them inward with a small screwdriver and the pegs should come right out.
The reason to leave the white pegs in is because they have a rubber gasket on them that keeps water from entering the trunk through those holes under the emblem.
If you absolutely need to remove them in order to fit your new emblem, you'll want to do something else like tape and silicone the holes before you put your new emblem on to stop water from coming in.
PhoR11 is offline   Reply With Quote
Old 04-02-2008, 06:00 PM   #5 (permalink)
The Slip
BlaqkAudio's Avatar
James
Oh ok, my bad. I was thinking about the JDM emblem tabs that you have to cut off because they don't line up.
Old 04-02-2008, 06:09 PM   #6 (permalink)
Nick
well, our OEM emblems have the same tabs, but hes talking about the things those tabs snap into
In-dash navi that's removable? I Vtec, do you? I.C.E., Electrical, Security, & Navigation 29 09-05-2007 12:26 PM
Accessory Holders brooklynscat69 Inside and Out 5 09-21-2006 12:56 AM
I Got Two Tickets In Two Months And My Court Dates R Coming. SkyeHack Water Cooler 23 07-30-2006 10:21 PM
