Old 03-27-2008, 03:30 PM   #1 (permalink)
fox
fox's Avatar
Andrew
intermittent wipers
so correct me if i am wrong...
the LX has automatic intermittent wipers that adjust with the speed of your car.
seems nice... but i hate it. it never works for a drizzle. it will wipe to fast, so i find my self leaving them off and moving the stalk from off to on and back to off so that it won't work.
I thought i read that the Si has manual adjustable intermittent wipers...
i may be wrong, and if i am this leads to another question...
if the Si does have the manual adjustment (ie. a thing to twist so the delay is 2sec to .5sec or something) can i get the stalk and the wiring to do it?
and if the Si does not have this, is there any wiring i could do to bypass the current LX wiper system and put a new adjusting switch somewhere else?
fox is offline
Old 03-27-2008, 04:21 PM   #2 (permalink)
fox
fox's Avatar
Andrew
after more extensive searching, i have found some other threads on this, but no one has done it yet...
Intermittent Wiper Stalk for EX?
and this one
Wiper intermittent
as i said, no one has done it yet...
so i guess what i also want to ask does the Si have a single intermittent setting, or is it adjustable like the CSX stalk in the 1st linked thread.
fox is offline
Old 03-30-2008, 10:43 PM   #3 (permalink)
fox
fox's Avatar
Andrew
bump.
fox is offline
Old 03-31-2008, 04:35 AM   #4 (permalink)
Dont Mess With This Zohan
GETxERxDONE's Avatar
Nichuma Ben Gabriel Ha Levi
ok..you should just be able to move it strait up and it will wipe once. but yes the Si and EX have the intermittant wipers id imagine that all the controls are done through the ECU though..so i dont know if it would work
Click Sig for Details on the Wreck, it just gets worse.
DIY HFP Front Lip Overlay CHEAP! | DIY HFP Side Skirt installation
DIY AUTO Shift knob Removal | DIY E-Brake Trim removal
License = SUSPENDED Days left = REENSTATED!
GETxERxDONE is online now
Old 03-31-2008, 03:40 PM   #5 (permalink)
Yes, the Si has a setting for how fast you want it to intermittently wipe.
I highly doubt it's ECU controlled. There is probably a potentiometer in the wiper stalk that controls it. Give it a try, I can't imagine the wiper stalk costing THAT much money. Worst case scenario, you can always sell it to recoup your losses.
DarkSi08 is online now
Old 03-31-2008, 03:42 PM   #6 (permalink)
the blinkers are controlled by the computer..so i figured the wipers are too
Old 03-31-2008, 03:43 PM   #7 (permalink)
06blaksi's Avatar
I believe it is controlled thru the ECU because no matter what delay setting you have, when you come to a stop they only swipe every 30 seconds until you hit 12 mph, then they return to what u have them set at
06blaksi is offline
Wiper intermittent role model Mechanical Problems & Technical Chat 9 05-07-2008 11:42 PM
07 SI won't start - intermittent fred9 Mechanical Problems & Technical Chat 4 04-12-2007 09:27 AM
Wat do intermittent wipers do? Domo* Mechanical Problems & Technical Chat 13 03-16-2007 08:28 PM
95 civic with intermittent stereo. kamikaze84 Garage 1 03-10-2007 07:00 PM
Intermittent Wiper Stalk for EX? kish-81 Do It Yourself Articles 11 08-31-2006 09:34 AM
