Old 02-05-2008, 06:31 PM   #1 (permalink)
jbsali's Avatar
Skunk2 Muffler
I'm going to install this muffler on my car because i don't want to drop a mint on the catback for my LX. Do i have to worry about anything if im installing a axleback? ex. Is the hanger an odd shape? i was just going to get a custom pipe made and just weld the muffler on. I was going to buy the same hanger i used on my 92 SI. It's just a really big hose clamp that came with a bar you put between the muffler and the clamp and when you tighten the clamp the bar would bend to the shape of the muffler. Then you just screw the hanger parts in whichever hole is positioned the closest to where you would hang it. It worked great in my last civic (1992). Will i run into any problems? ALSO... should i go the 76mm or the 60mm? Pros and Cons of both would be great! Thanks in advance!!
jbsali is offline   Reply With Quote
Old 02-05-2008, 07:45 PM   #2 (permalink)
jbsali's Avatar
can anyone answer atleast one of these questions...?
Old 02-05-2008, 07:50 PM   #3 (permalink)
myspace.com/assistant_ar
7002iSciviC's Avatar
Andrew
i installed my skunk2 megapower 60mm on my car with a lil help on my 15 yrs old cousin. it wasnt that bad the main problem was the HANGGERS !!!!!!!!!! those bisH and FAWKING pain cutting them !!!!!!! i have to cut it 4 dam times to get it right lol anyway it shouldn't that hard to do just make sure put your car in gear if its manual and the E BRAKE and put to prevent your car from rolling backward or forward. GL
btw install time 1 hr - 2 hrs it depends of the fawking hanggers
7002iSciviC is offline   Reply With Quote
Old 02-05-2008, 08:12 PM   #4 (permalink)
jbsali's Avatar
What is the difference between the 76mm and the 60mm? I'm looking at keeping the stock size of my axleback and just want to add on the skunk2 muffler. Whish one should i pick? My only worry is the exhaust fluttering/popping/backfiring(?). The noise drove me insane on my older civic! then again the car was 13years old....
what is the difference b/t exhaust, muffler, and muffler tip? irichard Bolt-Ons And All-Motor 9 04-20-2009 10:51 PM
tanabe muffler VS HFP muffler Rphsidan Bolt-Ons And All-Motor 4 08-13-2008 12:28 AM
Differences between 2dr HFP Muffler & 4Dr HFP Muffler? n8ssi Bolt-Ons And All-Motor 8 07-05-2007 03:28 AM
70mm Skunk2 w/quieter muffler? Mattzilla Bolt-Ons And All-Motor 13 05-06-2007 03:28 PM
Oval(stock style)muffler Vs round muffler? nsl Bolt-Ons And All-Motor 5 03-15-2007 06:04 PM
