Old 05-02-2006, 04:20 PM   #1 (permalink)
63.7% Bostonian.
J-Ro's Avatar
Jason
Removing panel under driver's footwell?
Does anyone know how to remove the plastic panel under driver's footwell in the coupe? I turned that little lock thing, but it still won't come out and I don't want to break it...
I feel like I missing something reeeeeally simple... :rolleyes:
Thanks
J
Epic Northeast Meet quotes:
Originally Posted by portabuddy
People sometimes think I'm pregnant, but I'm actually not.
Originally Posted by jrMartinez24
You don't look Canadian. You look like you're from Boston.
Old 05-02-2006, 06:18 PM   #2 (permalink)
BURN's Avatar
Are you speaking of the dead pedal? If so, there are 2 little lock things. The one on top will have to be turned counter-clock and also push a screwdriver in the bottom hole, turn counter clock wise, you should notice that the whole circle peice will move, just a few turns and give it a tug. To put it back in place it is very easy, just push on, should hear a few clicks.
Hope this helped.
BURN is offline   Reply With Quote
Old 05-02-2006, 06:32 PM   #3 (permalink)
the bottom plastic panel requires you to twist that knob, which you have done, and then there are 2 pop clips, so it just pops out.
1zach4 is offline   Reply With Quote
Old 05-02-2006, 07:27 PM   #4 (permalink)
63.7% Bostonian.
J-Ro's Avatar
Jason
That's the one I'm talking about... so are the clips towards the front of the car or the back?
Old 05-02-2006, 08:51 PM   #5 (permalink)
CameronJr9's Avatar
Back and Forth Forever
Check out step 3:
http://collegehillshonda.com/instruc...lumination.pdf
Old 05-02-2006, 10:16 PM   #6 (permalink)
BURN's Avatar
Sorry about my post.
Old 05-03-2006, 07:11 AM   #7 (permalink)
63.7% Bostonian.
J-Ro's Avatar
Jason
Thanks for the illumination instructions! That's what I want to do in the end, but I'm going to use 10mm blue LEDs, and not those bizarre-looking lights in the instructions :)
And don't worry about the post, BURN... it would have been a lot easier to understand what I was talking about if I actually knew what the part was called :)
J
KY Cops/Truck Drivers Bust Aggressive Drivers CameronJr9 South 4 07-06-2008 09:06 PM
Desolate dash panel for foglight switch GregM Inside and Out 23 04-08-2006 07:33 PM
