Old 11-28-2007, 09:08 PM   #1 (permalink)
Hondacivicsi23's Avatar
Michael
Triple Gauge Piller Pod
After reading through numerous threads I found only one person has the triple gauge piller pod from glow shift. But, no pictures have been posted. I also came across a discussion about the side air bags, the side air bag is located above the door not on the piller is this right??
I was considering getting the Vacuum gauge, Volt gauge (for my system), and Water temp. gauge. But....what purpose does the vacuum gauge and water temp gauge serve??
Hondacivicsi23 is offline   Reply With Quote
Old 11-28-2007, 11:11 PM   #2 (permalink)
Daniel
I was looken at that set up when I get S/C.
From what I understand the vac.is something you could use(for what IDK)
But hay look at the purdy lights!!!!lol
Some one let us know.....I was thinken the vac.,A/F oil temp.
Forklift352 is online now   Reply With Quote
Old 11-28-2007, 11:53 PM   #3 (permalink)
liquidr1's Avatar
Dustin
Unless your car is boosted, the vac/boost guage is useless.
liquidr1 is offline   Reply With Quote
Old 11-29-2007, 03:00 PM   #4 (permalink)
Michael
I know the A/F gauge is Narrow Band and our 02 sensor is wide band. Also, I read that if you tap into the 02 sensor it will mess up you A/F ratio.
Old 11-29-2007, 03:16 PM   #5 (permalink)
PhoR11's Avatar
Bradley
You should email a glowshift retailer and make sure it won't interfere with the airbag operation
(even if the airbag is above the window as ImAuthenticFTW has shown)...
*Edited so as not to confuse anyone.
PhoR11 is offline   Reply With Quote
Old 11-29-2007, 03:32 PM   #6 (permalink)
ImAuthenticFTW's Avatar
Mike Wagner
Originally Posted by PhoR11 View Post
I'm pretty sure that there is an airbag located in the front pillar.
And since that Pilar pod clips directly over the top, I'm fairly certain that it would interfere with the airbag operation.
You should email a glowshift retailer and ask about it before you ever think about buying...
once again this info is not true, the aitbag is not in the pillar but above the window, i had links to pictures in the thread the OP is referring too. AIRBAGS NOT IN PILLAR!!!
<img src="http://a332.g.akamai.net/f/332/936/12h/www.edmunds.com/media/ownership/safety/side.airbags/saturn.head.curtain.500.jpg"> </img>
ImAuthenticFTW is online now   Reply With Quote
Old 11-29-2007, 03:39 PM   #7 (permalink)
radiocontrolhead's Avatar
Danny
This is the most ridiculous thread ever. You want extra gauges but have no idea what they're for?
Old 11-29-2007, 03:40 PM   #8 (permalink)
Danny
Someone keeps giving away false information.
Old 11-29-2007, 05:02 PM   #9 (permalink)
rbsjnh's Avatar
WARNING: Honda Zealot
couldn't agree more...unless its a purpose built race car, than that siht is rice....
get some substance instead...
rbsjnh is offline   Reply With Quote
Old 11-29-2007, 07:42 PM   #10 (permalink)
Michael
I researched a little bit and found out the airbag is in the pillar. The picture you were looking at wasnt from a Honda civic.
I also contact GlowShift.....
Samantha: Ok. We tell all our customers that you can not install the items with the side air bags, but in fact the only reason we say that is because if the air bag is deployed then the pod could harm someone
Samantha: If you would like to instal the item on your car, simply disconnect the airbag or simply it alone and install the pod over it.
Samantha: The pod is made from a factory 06 Civic SI and fits the civic 100%
Samantha: As for installing the item with a car with an airbag you install it at your own risk
(from Honda website)
Old 11-29-2007, 10:53 PM   #11 (permalink)
PhoR11's Avatar
Bradley
^^ YAY now I don't look stupid!!!
Old 11-30-2007, 02:55 AM   #12 (permalink)
trickyazn's Avatar
wow theres numerous people who says its not in the pillar and its near the "ohshit" bar is.. now unless theres pics i wont believe anyone.
Old 11-30-2007, 07:17 AM   #13 (permalink)
Mike Wagner
im sorry but even in that picture its coming from up top not the pillar, look closer and you can see it too.
Old 11-30-2007, 10:51 AM   #14 (permalink)
PhoR11's Avatar
Bradley
It doesn't matter where you think it comes from.
The fact is, he contacted glowshift and they flat out said "you probably shouldn't install it without disabling the side airbag unless you want to risk injury if it deploys".
So who cares where it comes from.
Information that can help you make an intelligent decision >>>> semantics.
Old 11-30-2007, 10:56 AM   #15 (permalink)
Mike Wagner
i'm also sorry but have you first hand seen a side curtain airbag deployed??? i have and yes it was in an 8th gen civic and it came from uptop and the pillar was untouched. glowshift make pillars for im sure many other cars and im sure not everyone in the company knows everything about EVERY car they make things for.
you can also looks at this site, http://www.howsafeisyourcar.com.au/curtain_airbags.php
Old 11-30-2007, 11:01 AM   #16 (permalink)
why install gauges if you arent boosting?
kirks07si is offline   Reply With Quote
Old 11-30-2007, 11:04 AM   #17 (permalink)
Mike Wagner
there is a few gauges NA cars could use Voltage Water temp etc etc
Old 11-30-2007, 11:09 AM   #18 (permalink)
but whats the point if you arent doing a full na motor build...to each his own i guess
Old 11-30-2007, 11:11 AM   #19 (permalink)
Mike Wagner
well some poeple with sound systems would still like to montier volatge to make sure their battery isnt dead, as far as the others.....idk
Old 11-30-2007, 11:42 AM   #20 (permalink)
Si2Typ3R's Avatar
Nate
Talking
For the final time... THERE IS NO AIRBAG IN THE FRONT PILLARS None, nada, aboslutely bare metal! If anyone installs pillar pods you will be fine. The Pillars are not designed to come off in the event of airbag deployment.
Si2Typ3R is offline   Reply With Quote
Custom dash Triple GAUGE POD k20guy Inside and Out 72 11-12-2007 01:26 PM
Anyones car have a slight pull to the left? nsl Mechanical Problems & Technical Chat 19 08-16-2007 11:18 AM
GlowShift Molded Gray Triple Pillar Pod chilipepper Forced Induction And Nitrous 23 08-13-2007 05:13 PM
pulling to the right Coop Mechanical Problems & Technical Chat 50 07-23-2007 11:27 PM
Gauge Pod and Gauges 06Ex Inside and Out 24 07-09-2007 11:19 PM
