gaps in HFP kit?
I had my HFP ground effects put on the other day. It fits snug in most places, but in a couple spots, it doesnt. The gap isnt very big, but it is still noticable. Does anybody else with the kit have this issue? Should I worry about this or am I just being paraniod?
Hmmm....mine is very snug all the way around....If you look close you should see that the tape is tight to the body with no gaps....do a search for some pictures on here of some of the members with HFP ... I think you can visually see that it is very snug to the body.
#16 (permalink) |
I had to take the screws out of the inside fender and pull it back....It was a somewhat of a pain but I was able to get the old tape off and clean the fender and inner spoiler surfaces with Iso alcohol....Make sure you do this in warm weather say 65 -70+ ... I think my original problem was because I did this in a warm shop and about a half hour later I drove out into 20 degree F weather.
About 2 days or so later I noticed the gap. Take your time and make damn certain the fender and inner portion of the spoiler (b4 applying the new tape) is really clean. |
#19 (permalink) |
When i purchased my front and rear lip, I was provided in the honda box with these black spacers (about 8 in total) that would be used when you screw in the sides of the lip.
I noticed that the gap was created when the screws went in too tight and caused that space. So once i re-read the instructions, I used the spacers as recommended. Here is the install kit instructions: http://www.collegehillshonda.com/ins...odyspoiler.pdf On the first page shows the spacers for the sedan. I just checked the instructions for the coupe...and it also has the spacers. Hope that helps and makes sense. heh |
| HFP kit + drop? | Cheungman | Suspension and Brakes | 7 | 12-12-2007 01:21 AM |
| What I learned about the HFP Aero Kit!!!!!! | cornerstrike | Inside and Out | 26 | 03-22-2007 10:07 AM |
| hfp shocks and struts w/ eibach pro kit | rippars | Suspension and Brakes | 18 | 02-23-2007 11:48 AM |
| What I learned about the HFP Aero Kit!!!!!! | cornerstrike | Inside and Out | 9 | 09-05-2006 03:03 PM |
