Removing Window Tint Glue
Does anyone have a good method for this. I removed the tint because I got a ticket and kept getting pulled over so I said I was done with it. No I have all this glue left on my window. Can someone please guide me to a good way of removing this.
Time: 1-3 hours
Materials: Warm sunny day Tarp Large plastic garbage bag Undiluted Ammonia Windex (a glass cleaner) Paper towels Fine steel wool Razor blades Tips: The difficult thing about removing tint is that most film is constructed of two layers of tinted polyester. When you try to peel the film off the glass, the top layer will usually pull right off leaving the second layer behind. This second layer will not peel off, it will just flake and tear like a price tag. Step 1: To over come separation between layers you must soften the adhesive so that both layers peel at the same time. This is very important, if you peel the just the top layer, you may as well just use razor blades as there is no way to peel the second layer off without picking at it for a few hours. You MUST try to peel both layers at once. NOTE: You are more than likely to damage one or more of your defroster lines, when this happens, the cut line will not work anymore. Some cars have radio antennas mounted alongside the defrosters made of the same material. If you damage these, your radio antenna will not work! Be careful! Taking it to a tint shop to be done greatly increases the odds of saving the lines, but even a tint shop can not promise to save your lines, sometimes the film is just to far gone. Step 2: First, clear the window of any obstructions, like the brake light, speaker covers etc. Step 3: Next cut open the garbage bag so that it will be big enough to cover the entire window. Spray some water on the outside of the back window and the lay plastic bag over the glass. Cut away excess plastic so that it is now roughly the same shape as the glass. Step 4: Next, lay a tarp over rear deck and seat, spray ammonia liberally on the inside of the back window. (Ammonia is very strong, I suggest you hold your breath during this step) and cover ammonia soaked tint with the plastic bag so that it won't evaporate. Step 5: Park the car with rear window facing the sun for about an hour. The film should now be ready to peel. Step 6: When you are ready to start peeling, leave the plastic in place so the ammonia wont dry. Get the peeling started with a razor blade in a corner where there are no defroster lines. Try to peel film off in one piece. If the ammonia dries as you peel, the glue will get hard again, so spray a bit of ammonia on the area as you peel. Step 7: Once the film is peeled you will need to scrub the adhesive off with ammonia and fine 0000 steel wool. Mop up scrubbed areas with paper towels before they dry. Finish up with window cleaner and paper towels. Removing tint from side windows Soaking is not nessesary here. You may want to use a simple razorblade holder. Cut a notch onto the upper area of the film so that you have a piece to pull. Try to peel the film, it will probably come off in two or three pieces. Spray the remaining adhesive with soapy water, and scrape the adhesive off with a razor blade, avoiding the edges of the glass until last to keep the blade sharp. You may need to use a few blades as they dull quickly. Finish up with window cleaner and paper towels. Inspect for missed glue (its clear and hard to see) Removing tint using a Steamer If you have access to a Jiffy steamer or similar steam machine, you can make quick work of stripping. Apply the steam to a small spot for a few moments and use a blade or the spout of the steamer to peel the area just steamed, when you have enough to hold, just peel slowly as you steam just ahead of the area you are peeling. This will bring both layers of tint off and sometimes the adhesive too, without presoaking for an hour. Customers If you dont know how to correctly strip off old tint, its probably best if you dont try.....It will only cost you more. I had a guy come in about a week ago. He asked for an estimate to strip and retint his 2dr civic. I gave him the price for both. This much for the car and this much/hr to strip. He makes an appt. for me to tint the car, but said he wanted to save some money so he was going to strip it himself. I told him how to do it, but I also told him that if he tries and messes up i.e., doesnt get it all off, just pulls the film and leaves glue, kills his defrosters, scratches the glass, it was only going to cost him more. He said "well it doesnt look that hard" and left. A couple days later he brings it in for me to tint. This guy ruined every piece of glass in his car. On the B/W he killed the defosters, and left glue and tint throughout the matrix. On the 1/4's he scratched the frit all to hell (black boarder around glass for the noobs), and on the doors scratched the shiot out of them as well. After all that I STILL had to charge him to finish the job. In the end this guy didnt save a dime. Instead he ruined all his glass, and probably a whole Saturday doing so. When he picked it up I asked how he did all the damage (I knew he didnt do what I had told him). The guy told me this....."Na man, the way you told me didnt work for shiot. I just took a 4" scraper blade from Home Depot and put that in some Vise Grips. That worked sooo much better" I couldnt believe my ears!!! So you see what I mean everyone? Even if it costs just a little more to have the job done right, wouldnt you rather do that than what this guy did? Not to mention, youre going to make the whole job much easier for the tinter! Which in turn will more than likely get you a better job in the end. A good question about removing tint From SUZIE: Hi, so glad I found your website. I'm one of the fools trying to remove really old, really bubbled, baked on tint from my hatchback window with defroster lines. I've unfortunately already picked and pulled at most of it before I decided to search for help. I have all the stuff need to follow your instructions but I'm a little confused about the plastic bag part. Do I need two bags, one for the outside and one to cover the tinted inside once I've sprayed the ammonia? Please help so I can finally see out my back window. thanks. The reply No, you just need one bag, the bag is to cover the ammonia that is sprayed onto the film (on the inside) so that the ammonia wont evaporate. The bag is first laid onto the outside just to cut it to shape. Unfortunately once the film has been partially stripped this method wont work well. You should still soak it, but dont expect to be able to peel it off (because there is no longer a continuous piece of film). I suggest soaking it as normal, then expose only a small area at a time to pick at the film, then peel back the garbage back a little more and work that area. At this point you are looking at about 3 hours of sweaty hard frustrating work. If you can afford it, have a shop strip the rear window for you, it will save you a lot of aggrivation. Removing residential film Your best bet for removing film from residential glass is to soak them in soapy water instead of ammonia, using the garbage bag method described above. Let them soak for an hour or so, then you will need to use a wide razor scraping tool (about 4" wide razor blade scrapers are available at the hardware store) to remove the film and adhesive. Concentrate on removing all of the film, then spray the window with more soapy water and use a new blade to remove the left over adhesive. Windex will also work well instead of dish soapy water. Straight ammonia should not be used as there would be so much, it would be hard to breath in the area. User submitted tips: Name: Anonymous Tint Removal Tip: Instead of using ammonia try the all purpose cleaner 409. It smells alot better and will preform the same task. Name: Peter Email: anon@anon.com Tint Removal Tip: To remove the excess glue after taking off the film, spray some WD40 then with some fine steel wool give it a good rub then wipe if off with paper towel then clean with proper glass cleaner. Name: min soo Tint Removal Tip: best way to remove film is spray soapy water on the film, put garbage bag over and let it soak for about 10 min facing the sun, then just peel it off. it works great. side window too. Name: none Tinting Tip: My friend and I sorta stumbled across this the other day. If you use a can of De-Ice and wipe fairly hard it will remove the glue with great ease. It works wonders on defrost lines. Name: Anonymous Tint Removal Tip: Use a heat gun to heat up an area of the tint (careful not to burn your hand as the gun will reach very high temperatures). This will in essence melt the glue. Start peeling the heated section & repeat this for the entire window. Use GOO-GONE or GOO-AWAY with a cloth/crudrag (not paper towel) to clean window after tint is removed. Name: jonathan Tint Removal Tip: I have also used simply green instead of ammonia. This also smells much better.THE CHEAPER STUFF DOESN'T EVEN COME CLOSE TO WORKING!!(like Mean Green) Name: Paul Najjar Perth Australia Tint Removal Tip: The steam method is mostuseful on older dyed polyester or laminated films but is not so effective on newer recently applied metal based tints.(such as when the cops have said to remove the dark film)I find the glue will stay behind making more work. I am more inclined to peel the film ever so slowly without the use of any chemicals or heat and I have found that most of the adhesive will come off with the tint. This works particularly well with one piece rears. You may have to just spot remove some minor remnants of glue with detergent and fine grade steel wool to finish off. Name: Anonymous Tint Removal Tip: TO SPEED UP THIS PROCESS, IN ADDITION TO FACING THE REAR GLASS TOWARDS THE SUN, LEAVE THE CAR RUNNING WITH THE DEFROST ON HEAT AND HIGH AND THE REAR WINDOW DEFROSTER ON. I USUALLY ONLY WAIT 10 MINUTES AND THE FILM COMES OFF WITH THE ADHESIVE. IF THE FILM HAS STARTED TO DELAMINATE ALREADY, WAIT LONGER. DON'T FORGET TO LEAVE THE DOORS UNLOCKED SO YOU DON'T LOCK THE KEYS IN THE CAR!!!!!!!! Name: Dan Georges Tint Removal Tip: I have a sugestion to make breathing a whole lot easier. the steps you mentiond are perfect, but instead of using ammonia, try using simple green. dilute a spray bottle 50% water and 50% simple green. spray it on the film, trap it with a plastic bag. 20 min or so in the sun even the ugliest, bubbled tint will come off. then use full simple green on the remaining adhesive left behind and bingo, steel wool (super fine) will melt the rest off. plus it smells much better than ammonia. works for me and i am a 16 year vet. hope it helps. :) Name: Gerardo (Jerry) Tint Removal Tip: Make your life alot easier and let the professionals do the job. It might cost you a little but call and ask shops if they can save the defroster lines on your rear window, no one will promise it but if they now what they are doing they will most likely be able to. You will know just by your conversations. Because the customer is unexperienced you will save yourself the headache and lots of time, eitherway it is only going to cost you a little more than if you have to go out and by all the products to remove the film. Name: David Finch Tint Removal Tip: I used a steamer to take the tint of my Ferrari, and it came off in a minute. Talk about a car u wanna be careful with. Use a steamer like the professionals. It will save time and effort. Name: M. Colford Comments: On removing the tint from the side windows, I would suggest that instead of using straight ammonia, go to some 5 and dime store, and find the cheapest glass cleaner you can. This eliminates the ammonia smell, but there is ammonia in the cleaner. Make sure the cleaner has ammonia in it though. For the rear window, me and a friend used the cheap glass cleaner and a heat gun. Peel part of the tint away in a corner in the top, and shoot some of the cleaner down in between the tint and glass. Then have someone on the outside use the heatgun on LOW aimed at the area that you are peeling at. This loosens the glue, and allows the cleaner in to get to mroe tint. You will spray a good amount of glass cleaner, but it is safe on the defrosters, and there is not a strong smell. |
One, thanks everyone. Windex and a razor did the trick in about 30 minutes. (Total for both driver and passenger window) Second, the tint is pretty dark. (Everytime)
![]() I didnt think it was to dark but the cops did. Oh well. I'm going to get it re-tinted at this joint that will take it off and put it back on if you get a ticket. |
#10 (permalink) | |
Smiley Whore
#11 (permalink) |
Dont Mess With This Zohan
Nichuma Ben Gabriel Ha Levi
ive gotten one tint ticket. if i get another im taking it off. will probably be using your guide 8th civic nut. but since its cold out right now..would a heatgun work ok?
#13 (permalink) |
Are alot of people getting warnings or tickets for insisting they go darker on their car tint? Now its time to pay the piper. Sgt Piper that is. hahaha!
Any 06 or 07 Civic is a looker and they're gonna draw more attention including cops. I dont think you can squeeze under the radar with this car. |
| Window Tint and NAVIGATION?? | Silver8th | Inside and Out | 25 | 07-05-2008 04:03 PM |
| U.S. & Canadian Tint Laws | jc21 | Inside and Out | 35 | 05-19-2008 08:28 PM |
| window tint in winter? | Exeon | Inside and Out | 15 | 12-07-2006 03:24 PM |
| What the legal window tint is in each state | 06RREX | Inside and Out | 3 | 10-28-2006 09:17 AM |
| Blue window tint on a Civic? | King of Canada | Inside and Out | 7 | 05-11-2006 03:11 PM |
