S2000 Push Button Start Install Guide - 8th Generation Honda Civic Forum
Old 02-08-2006, 11:00 AM   2 links from elsewhere to this Post. Click to view. #1 (permalink)
unplugged's Avatar
Parts
# 1 Genuine Honda S2000 starter button
# 1 SPDT relay at 30amps/12 volts
- Mark
2008 Honda Civic SI (stock)
2006 Honda Civic EX (sold)
unplugged is offline
Old 02-08-2006, 10:27 PM   #2 (permalink)
Gone's Avatar
Andy
I'm not sure about anyone else, but that pic doesn't help me much...???
Gone is offline   Reply With Quote
Old 02-09-2006, 12:38 PM   #3 (permalink)
Ryan
Clarification
Hey unplugged and Gone, I have some questions on the diagram that may be helpful to others and myself. The green wires on the diagram from the start buttom and the #86 terminal on the relay are GROUND wires correct? Then the brown wire on the start button needs a constant 12V power source correct? The rest looks pretty self explanitory, #30 terminal gets tapped into the white wire and #87 to the yellow. Hot wire from the relay to the start buttom comes from the #85 terminal. Just confirm I have the diagram interpreted right for me unplugged and post some finished pics of your install if you can.
CANMAN is offline   Reply With Quote
Old 02-09-2006, 01:09 PM   #4 (permalink)
Acorns!
webby's Avatar
I'm interested to see how this turns out myself.
webby is offline   Reply With Quote
Old 02-09-2006, 02:20 PM   #5 (permalink)
Photobucket
Silver8th's Avatar
"Cut here if you don't want to use the key anymore".
Old 02-11-2006, 09:29 PM   #6 (permalink)
unplugged's Avatar
yes, green is the ground wires.
I didn't make it an easy write up because its not something anyone should just do. You should have electrical experience along with taking the risk of voiding the warranty by tapping into factory electrical wiring.. especially something as important as your ignition.
- Mark
unplugged is offline   Reply With Quote
Old 02-11-2006, 09:30 PM   #7 (permalink)
unplugged's Avatar
yes, you can disable the key from cranking the engine and only using the push button. The key will still be needed to be in IG2 to use the push start.
- Mark
Old 02-11-2006, 09:31 PM   #8 (permalink)
unplugged's Avatar
if you can't understand the pic..then doing the job may not be cut out for you. I drew it out as simple as I could but its not for everyone to understand if you don't have previous experience.
- Mark
Old 02-11-2006, 10:19 PM   #9 (permalink)
Acorns!
webby's Avatar
can I ask what you do for a living unplugged? Are you in electronics as a profession or? Seems like you know your stuff when it comes to electrical work.
Old 02-11-2006, 10:46 PM   #10 (permalink)
Photobucket
Silver8th's Avatar
I think I remember him saying he worked at Honda in the parts dept.
Old 02-12-2006, 07:53 PM   #11 (permalink)
unplugged's Avatar
i'm still a college student..but I have been around cars since I was 14 and just learned them inside out. As for electronics..I took 3 classes in high school on it, so i'm familiar with diagrams and circuitry.
The helms books is something good to own on each vehicle your purchase as it breaks out every installation/removal process for the vehicle along with electrical diagrams. Helm still doesn't have one for the civic at the time I wanted to order it..but I will most likely buy it when it is released.
- Mark
Old 02-12-2006, 07:59 PM   #12 (permalink)
unplugged's Avatar
I left there 2 months ago now. Only so much you can take.
- Mark
Old 03-06-2006, 09:01 AM   #13 (permalink)
acetech808's Avatar
Hey unplugged?
Why the relay? Why not wire the switch straight to the yellow and white wires? Since the start switch is likely to be a monentary contact type? The other 2 wires are for the dash light. Just my 2 cents.
acetech808 is offline   Reply With Quote
Old 03-07-2006, 10:56 PM   #14 (permalink)
unplugged's Avatar
because the switch can't handle the power going through. The relay can. That's why its a 30amp relay.
The relay works like this.. The connection to the starter is open. Once a 12v signal is sent to the relay from the switch, the connection is closed for the time the button is pressed, and the engine starts.
YOU MUST USE A RELAY! Its only 4 bucks..so USE IT
- Mark
Old 04-04-2006, 12:45 PM   #15 (permalink)
Where can I find the diagram?? Sounds like a fun first mod for my Si!
oneal is offline   Reply With Quote
Old 04-04-2006, 04:56 PM   #16 (permalink)
Kroze's Avatar
got any pics of the installation?
Kroze is offline   Reply With Quote
Old 04-04-2006, 05:12 PM   #17 (permalink)
I put an Ignited push started in my Legend. It was kewl as crap to have but totally impractical. Everytime I got in a pushed it, though, I had a big smile on my face
By the way, if you dunno what you're doing, please save yourself the trouble and stay away. I wasn't paying attention and grabbed the wrong gauge wiring and ended up melting it to my carpet when I was doing the install. It can be a very dangerous thing.
Old 04-04-2006, 09:49 PM   #18 (permalink)
unplugged's Avatar
yeah its definitely annoying..much easier to just turn the key.. but i figured i'd do it since i had a button laying around..but i took it out after changing the factory radio
- Mark
Old 04-05-2006, 03:08 PM   #19 (permalink)
waross's Avatar
no pics.....thats not real helpful
waross is offline   Reply With Quote
Old 04-05-2006, 03:31 PM   #20 (permalink)
As impractical as it is, I'm going to do it again with my Si...hehe...
LinkBack to this Thread: http://www.8thcivic.com/forums/inside-out/2004-s2000-push-button-start-install-guide.html
DIY: push start button ( wiring diagram) - 8th Generation Honda Civic Forum This thread Refback 02-05-2008 01:03 PM
DIY: push start button ( wiring diagram) - Page 9 - 8th Generation Honda Civic Forum This thread Refback 01-04-2008 09:39 AM
XenonDepot HID Install Guide unplugged Lighting, H.I.D.'s, & Neon 102 01-29-2012 05:31 PM
Front Speaker/Tweeter Install Guide brolewis I.C.E., Electrical, Security, & Navigation 16 05-29-2006 10:11 PM
Rear Speaker Install Guide brolewis I.C.E., Electrical, Security, & Navigation 7 12-29-2005 12:53 AM
