correct way to paint valve cover so it doesnt look cheap - 8th Generation Honda Civic Forum
Old 02-01-2010, 05:05 PM   #1 (permalink)
Chris
i painted my valve cover last year and i want to remove the paint thats on it now cuz its chipn and doesnt look good anymore...i want to remove the paint and re-paint the valve cover but in a way that will last and look nice...any help would be great.
mullaneyR18 is offline
Old 02-01-2010, 05:15 PM   #2 (permalink)
Drew_187's Avatar
Andrew
How'd you do it last year? i.e. steps etc
Drew_187 is offline   Reply With Quote
Old 02-01-2010, 05:18 PM   #3 (permalink)
Chris
washed it, covered holes with paper towels and tape...painted it with blue engine enamel...i didnt prime it cuz someone told me i didnt need to...like a da i listened and didnt prime it...lol...but that was it.
mullaneyR18 is offline   Reply With Quote
Old 02-01-2010, 05:20 PM   #4 (permalink)
Drew_187's Avatar
Andrew
no sanding?
i sanded, washed, sanded, washed, primer coats, then paint coats.
Old 02-01-2010, 05:21 PM   #5 (permalink)
Chris
no, no sanding...y do u sand it? and how many coats do u use with primer and paint.
Old 02-01-2010, 05:25 PM   #6 (permalink)
F1R3B411's Avatar
David
i sanded my engine cover lightly with 300-400 grit then painted it. the sanding helps the next batch of paint connect. mine turned out good. i would think its the same idea with the valve cover.
F1R3B411 is offline   Reply With Quote
Old 02-01-2010, 05:27 PM   #7 (permalink)
UniqueTW's Avatar
Mike.
he's talking about the valve cover not the IM cover.
i roughed mine up with some sand paper. wiped it all off then did about 5 coats of engine paint
UniqueTW is offline   Reply With Quote
Old 02-01-2010, 05:28 PM   #8 (permalink)
Chris
looks great...ill try that...thx for you help
Old 02-01-2010, 05:30 PM   #9 (permalink)
Chris
yea i was talkin about valve cover, but i figured the same process would work...
Old 02-01-2010, 05:38 PM   #10 (permalink)
Drew_187's Avatar
Andrew
Yeah i worked a few levels of sand paper.
I did two coats of primer and if memory serves right, I did 3 coats of my red paint.
came out like so..
Old 02-01-2010, 07:15 PM   #11 (permalink)
RGV-SI-'s Avatar
Trevor Wray
You don't have to use primer with engine enamel but you must sand it down to a metal surface cause that is what the enamel bonds too
RGV-SI- is offline   Reply With Quote
Old 02-01-2010, 07:20 PM   #12 (permalink)
UniqueTW's Avatar
Mike.
mine. also painted the plug cover
Old 02-01-2010, 07:23 PM   #13 (permalink)
midnitesi's Avatar
james
just powder coat it
midnitesi is offline   Reply With Quote
Old 02-01-2010, 07:43 PM   #14 (permalink)
c130turboprop's Avatar
James
heres mine
c130turboprop is offline   Reply With Quote
Old 02-01-2010, 07:45 PM   #15 (permalink)
RGV-SI-'s Avatar
Trevor Wray
Thats really cool!
Old 02-01-2010, 08:29 PM   #16 (permalink)
Carlos
With engine enamel there's no need for primer as its ceramic based, but you do need to wash really well with degreaser, then sand it with 500+ grit sandpaper so that the paint sticks on. Then wash it again after sanding with soap. Then paint, light coat, light coat, medium coat, light coat. and you should be good to go
Bandit_Kaine is offline   Reply With Quote
Old 02-01-2010, 08:31 PM   #17 (permalink)
James
baically how i did my camo job.... well, my friend painted it for me, cause i suck at painting, lol...
Old 02-01-2010, 08:41 PM   #18 (permalink)
sick-k20z3's Avatar
Rusty Shackleford.
damn that black and blue looks sick as hell.
i just sanded mine with 350, then 800 then washed it and sanded with 800 again. i baked mine and no chipping so far.
sick-k20z3 is offline   Reply With Quote
Old 02-01-2010, 08:43 PM   #19 (permalink)
sick-k20z3's Avatar
Rusty Shackleford.
Old 02-01-2010, 08:47 PM   #20 (permalink)
James
i didnt think i would like just a black valve cover but its not to bad....
valve cover paint help davisesteban Inside and Out 3 01-13-2009 12:20 AM
valve cover paint maxxnitro88 Inside and Out 17 02-23-2008 05:16 AM
Help Paint Valve Cover? miles10238 Do It Yourself Articles 4 11-28-2007 07:25 PM
Paint Valve Cover 07Rredsi Inside and Out 25 05-18-2007 03:52 AM
How could I paint a valve cover erupt323 Introduction & Pictures 8 04-19-2007 06:40 PM
