hmm...
this monitor at work is pretty crappy so i cant see it that well but from what i see, it does look removable, i'm pretty sure they wouldn't change the Si's license plate area from the sedans or coupes. which do you have? try taking plyers, grab them and turn. theres no way that those two top ones wont come off. how did the dealer plate stay on then? |
my lisence plate has been on with only 2 screws(the bottom ones) and I already try using stuff to take the top square looking things off but can't they seem to be with the body
And i have a Civic lx coupe. here is a picture close up! ![]() Last edited by Civic Pride; 11-02-2006 at 08:40 PM. |
then your bolts should be the same as mine.
then i am 100% positive that you can take those out, it would be stupid to have the bottom ones hold the plate instead of the top ones. try plyers and do it like this side view -- | >---- -- the bolt is the square thingy and the plyers (will obviously be bigger) grab it like that, grab it tight and turn counter clock wise, other than that... i'm not sure man, it should just twist out without that much power. |
#17 (permalink) |
LOL Have to love myself
Here is a pic of my custom job (Note that i painted the screws balck to match the frame) ![]() And one more question, does the name of the county has to be showing on the lisence plate? if so, injen mess up when making this frame... |
#19 (permalink) |
if you notice the two square things at the top have several lines that intersect in the middle...this is a punch out...if you just start screwing the screws into those, they give easily and have about 1.5" behind to easily accomodate different size screws. I'll give you props though on using the bottom ones...i just didn't want to screw through my AEM plate frame.
| Dumb Laws | C2i0v0i1c | Water Cooler | 56 | 03-19-2008 03:02 PM |
| Noob question... Si shocks/struts | disfilam04 | Suspension and Brakes | 2 | 10-06-2006 12:36 AM |
| Noob Question ! | ...WillSI07... | Civic SI | 2 | 09-26-2006 09:13 PM |
| Front Lisence plate | shawn-o | Inside and Out | 13 | 07-03-2006 04:08 AM |
| new! and a noob question... | hoanger | Introduction & Pictures | 2 | 04-16-2006 08:09 PM |
