2009 Civic Sedan Door Edge Guards - 8th Generation Honda Civic Forum
Old 06-26-2009, 10:21 PM   #1 (permalink)
Hi everyone,
I just recently purchased a 2009 Civic LX-S and am looking to pick up a set of door edge guards. In keeping order with the cars color scheme, I'd prefer the guards to match closest with the stock 16" alloy wheels. That is, it has to be a cool silver/metallic in order for it to help accent the wheels.
However, I'm facing the trouble of finding a picture that isn't stock:
and it's hard to match color descriptions with all of those colors stacked next to each other, so I thought I'd come here and ask you Civic enthusiasts. Will I find these guards cheaper online instead of getting haggled at the stealership for installation? I've seen a pdf floating around that shows how to DIY which I'm more than willing to do. And can any of you provide pictures of the exact guard color I want?
strobeable is offline
Old 06-26-2009, 10:22 PM   #2 (permalink)
HERO's Avatar
They aren't meant to match your wheels man... it's gona look tacky :\
HERO is offline   Reply With Quote
Old 06-26-2009, 10:28 PM   #3 (permalink)
I wouldn't think so. I'd hate to have my entire car blacked out, which I would assume most people would try to do.
And besides, these are just accents, it's not like the strips will ruin the image of the whole car. It's good to have a little variety, methinks
strobeable is offline   Reply With Quote
Old 06-26-2009, 10:33 PM   #4 (permalink)
HERO's Avatar
Well good luck to you. I do believe the colors are close to OEM paint.
Maybe the Alabaster Silver Metallic themed ones would match your rims?
Old 06-26-2009, 10:35 PM   #5 (permalink)
07SI FTW's Avatar
Shaun & Ozzie
07SI FTW is offline   Reply With Quote
Old 06-26-2009, 10:39 PM   #6 (permalink)
Thanks but it's hard to even tell what that is from the pictures O_O.
EDIT:
I totally forgot the color descriptions matched the OEM paints. This helps a lot, thanks. Where can I get them the cheapest online?
Old 06-27-2009, 10:57 PM   #7 (permalink)
Turns out using Alabaster Silver Metallic as an accent to the wheels was a tacky idea I cut out the color swatches from the Civic brochure and slipped them between the door edges in order to test. I came to the conclusion of either matching the black OEM paint completely or to accent a step down the with the graphite gray (Polished Metal Metallic). Something that's not too unappealing to the eye, good looking out 8thcivic.
Old 06-28-2009, 01:11 AM   #8 (permalink)
prestoguy's Avatar
Preston
just color match the color of your car. it will look alot better
prestoguy is offline   Reply With Quote
Old 07-03-2009, 01:22 AM   #9 (permalink)
Does anyone know if the Door Edge Film:
that Honda sells separately as an "exterior accessory" is the same as the film that's on there when you buy your car new?
Old 07-03-2009, 03:17 AM   #10 (permalink)
prestoguy's Avatar
Preston
^ there shouldnt be any film on your car when its new, unless the dealership added it on. if thats the case, then yes, its the same
Old 07-03-2009, 04:14 AM   #11 (permalink)
u kidin me? I took that (dealer installed?) film off to install the door guards! I also screwed up on one of the door's hem sealants. I cut up almost half of the rubber foam so now its yellow innards stick out like a sore thumb. I mean moreso than the others, it looks like a dog chewed it up.
Door edge guards installed [IVI] Inside and Out 15 02-15-2009 04:36 PM
Door Edge Guards mattSi Civic SI 37 02-29-2008 02:22 PM
Door Edge Guards---> wheel-well guards too? Jakobud Inside and Out 3 11-27-2006 07:22 PM
Door Edge guards Berto Inside and Out 9 06-18-2006 03:05 AM
