Removed door ding - 8th Generation Honda Civic Forum
Old 03-31-2009, 03:36 PM   #1 (permalink)
Removed door ding
Hi,
Has anyone removed a door ding from the inside out? Particularly behind the driver? I'm trying to figure out if I can remove the panel below the rear side window in order to gain access to the rear quarter panel laminate.
robtrevino is offline
Old 03-31-2009, 04:19 PM   #2 (permalink)
depending on how big and deep the ding is, you can pop it out with dry ice.
uhtjoogoorih is offline   Reply With Quote
Old 03-31-2009, 04:49 PM   #3 (permalink)
I tried the dry ice and didn't work.
robtrevino is offline   Reply With Quote
Old 03-31-2009, 04:51 PM   #4 (permalink)
SRLNCLT's Avatar
Dry ice? Do tell!!
SRLNCLT is offline   Reply With Quote
Old 03-31-2009, 05:10 PM   #5 (permalink)
The Power of Dreams's Avatar
I had a door ding recently, and the dry ice method did not work, at all. I think it depends on the particular dent (if it's a creased dent, and most dents from other doors hitting your door will be, then forget about it). I had a paintless dent removal guy remove mine. It's nearly invisible and you really really really have to know where it is to see it. He only charged me $35.
The Power of Dreams is offline   Reply With Quote
Old 03-31-2009, 05:13 PM   #6 (permalink)
SRLNCLT's Avatar
^Yeah those paintless dent removal guys are the shiz!!
Old 03-31-2009, 08:15 PM   #7 (permalink)
I think Im going to try that. what do they do? do they do it from the outside or do they remove panels and stuff?
Old 03-31-2009, 08:26 PM   #8 (permalink)
i had a ding in the exact area you are talk about. to get to it he drilled a hole in my door jam. dent is completely gone and the hole has a plug in it. completely happy
civicsifg2 is offline   Reply With Quote
Old 03-31-2009, 10:57 PM   #9 (permalink)
But can you get to it if you remove the panel though?
Old 03-31-2009, 10:58 PM   #10 (permalink)
jdm free's Avatar
AJ
ive used plungers multiple times to pull dents out of cars
jdm free is offline   Reply With Quote
Old 04-01-2009, 09:24 AM   #11 (permalink)
The have a set of metal rods of varying length and thickness. They will used existing holes (water drains, etc) around the car to get to the dent if possible. Sometimes using the window slot. If they can't get to the dent they will drill a hole to access the area behind the dent. They will then plug the hold with a rubber seal. Sometimes this is not possible due to metal support bars and such. They use a mirror on a flexible arm to view the dent as it is being worked on to see that the dent is being pulled out right.
The effectiveness of the dent fix is based on location of the dent some dents are easier to fix then others. Also, if the paint is scratched off in that area, it can't be fixed.
ronin is offline   Reply With Quote
Old 04-01-2009, 09:46 AM   #12 (permalink)
s0opa_Si's Avatar
j00z mad?
um toliet plungers?
s0opa_Si is offline   Reply With Quote
Old 04-02-2009, 12:47 AM   #13 (permalink)
Originally Posted by s0opa_Si View Post
um toliet plungers?
hahahaha
door ding! dumpedsi Garage 4 05-29-2008 04:15 AM
I got a door ding today! roadrunner1659 Dealership Experience 9 04-12-2007 01:12 AM
Just got a door ding on my car! Civic Pride Garage 20 02-19-2007 09:50 PM
Friend put a ding in my door! RaskyR1 Garage 43 08-06-2006 01:31 PM
Door Ding White06 Garage 5 02-09-2006 02:47 AM
