Old 03-28-2009, 05:43 PM   #1 (permalink)
Offical DIY for Grafixpressions JDM Steering wheel emblem
To Start I know I'm in the wrong section but it wouldn't let me post in the actual DIY section becase it said i didn't have enough "permission" ***. But here it is anyways, enjoy!
The most important steps you can follow while doing this DIY is not only taking your time but have patience and don't rush things.
Total hands on time: 30 mins
Wait Time: 1 hr and 10 mins
Materials you need include:
-Clear silicone adhesive: I purchased mine from Wal-Mart in the automotive section
-Goo Gone: also purchased from Wal-Mart I got the extreme but either will work.
-Rubbing Alcohol
-2 clean rags
-Hairdryer (*only if you have to remove and re-apply)
(*Only for those trying to re-do the process not for actual first time installation)
For clean removal of your emblem start from one lifted edge and work the air from the hairdryer in underneath it. It should slowly begin to lift off and eventually just come right off with no effort.
Next try and peel away as much silicone as possible then begin to apply goo gone only enough to remove what can't be pulled off by hand, because I don’t know how it will affect the color of the surrounding trim.
(*START HERE FOR FIRST TIME INSTALLALATION)
Prep the area by cleaning with the rubbing alcohol, I used cu-tips but any type of cloth or cotton ball will work.
After it has dried thoroughly apply the clear silicone adhesive, very little on the H itself, just for the fact it will be touching the overlay first, and distribute an even layer around the H inside the existing chrome rim(*DON'T OVERDO IT OR ELSE IT'S GONNA BE A STICKY MESS*). Allow the adhesive to sit, I waited 5minutes but you could wait as little as 2 mins if you’re really strapped for time. Doing this will ensure a perfect factory placement.
After the silicone has set position the emblem so that the existing chrome outline can be seen all the way around the emblem. Finally, let it sit for at least an hr and come back to it with a damp cloth and clean the area.
(Note: If too much silicone was used and it is clearly coming out around the edges of the emblem use goo gone with a q-tip to ensure detailed removal, and then clean.)
Hopefully this DIY has provided you with the tools to apply your new or existing Grafixpressions overlay to factory standards
Thanks for reading
nighthawk4drsi is offline   Reply With Quote
Old 03-28-2009, 05:49 PM   #2 (permalink)
# 1 Friend Whore
obert's Avatar
Robert
Should of put this in the DIY section. Good job on the reinstall,mine is comming up on the edges also.
Old 03-28-2009, 06:20 PM   #3 (permalink)
rgsoundf's Avatar
Good write-up. I will try to use the Loctite Power Grab tape though. I heard the results were great.
rgsoundf is offline   Reply With Quote
Old 03-28-2009, 06:37 PM   #4 (permalink)
I tried to put it in there originally like I said at the top but it didn't let me becuase I didnt have access to do so. Hopefully an administrator can help me out and either grant me access to post there or just move the thread entirely for me. An thanks the edges were driving me crazy and after I took my time it really came out perfect 10x better than the first time.
Old 03-28-2009, 08:29 PM   #5 (permalink)
8thcivic Sponsor
blue rocket's Avatar
GrafiXpressions.com
thanks for the DIY, i know a lot of people have been looking for one. Mods, please move to DIY section
GRAFIXPRESSIONS.com
[8thcivic.com Related Products!] - [GRFXP.com on FaceBook!]
Summer Sale! Click Here!
2008 Acura TL Type-S
blue rocket is offline   Reply With Quote
Old 03-28-2009, 08:31 PM   #6 (permalink)
#1 Post Whore
07mugencivic's Avatar
ToE kNeE
not bad
Originally Posted by 0720Steve View Post
we should rename : beer: to :tony:
07mugencivic is online now   Reply With Quote
Old 03-28-2009, 08:50 PM   #7 (permalink)
rhyan141's Avatar
HOI-Pinoy141-AKO
v1......nice bro diy
rhyan141 is offline   Reply With Quote
Old 03-28-2009, 08:53 PM   #8 (permalink)
shawnono's Avatar
Shawnon
Do you read?
shawnono is offline   Reply With Quote
Old 03-28-2009, 09:23 PM   #9 (permalink)
Thanks man...and that **** does WONDERSSSS lol
Old 03-28-2009, 09:28 PM   #10 (permalink)
dt07Si's Avatar
Dave
Idk if I would use silicone but I'm sure it works.
After my v1 emblem from GRFXP didn't stick I got a v2 emblem from them and I cut out pieces of 3M double sided adhesive that fit in each opening of the H badge (covered up the black sections). The pieces of double sided tape created a level surface for the emblem to adhere to and the fact that it is sticky helps also. I installed it months ago and have never had a problem...
dt07Si is online now   Reply With Quote
Old 03-29-2009, 06:07 AM   #11 (permalink)
^You can do it that way but the sponser from grafixpressions said that the reason they stopped including the double-sided tape in the pacakage is because it had a tendency to not stick to it after a while. But let us know how it works on in the real long run of things...
Old 04-02-2009, 08:50 PM   #12 (permalink)
072civic's Avatar
do you think that using crazy glue will work to mount this?
072civic is online now   Reply With Quote
Old 04-04-2009, 03:36 PM   #13 (permalink)
^I really don't suggest it just because if you ever want to take it off for any reason ur steering wheel is going to be ruined...but I guess it could work if you decide to go that route tell us how it turns out
Old 04-04-2009, 04:07 PM   #14 (permalink)
072civic's Avatar
i ended up using the silicone worked great thanks i masked around the Emblem helped alot would have been a real big mess if i didnt
Old 04-04-2009, 04:12 PM   #15 (permalink)
Grey2.0SI's Avatar
Michael
i just ordered the new emblem (v2 i guess) and the tape doesnt stick long term??
what if i use the 3m red double sided tape i got for my ballast mounts
Grey2.0SI is offline   Reply With Quote
Old 04-04-2009, 04:16 PM   #16 (permalink)
Tim620X's Avatar
Tim
Just did mine today. Today is pretty crappy out though, cold and rain/snow mix. I wanted to wait till it was a little warmer but I couldn't lol. It looks good but one of the sides didn't stick completely flush against the steering wheel so I imagine I'll prob. have to re-do it.
Tim620X is offline   Reply With Quote
Old 04-06-2009, 12:13 AM   #17 (permalink)
No problem man I'm glad it worked out for you
I guess you could try it I didnt try another way so I can't really say if something will work or not
Yeaaa same thing happened to me the first time around just take your time with it and make sure u press down on it once you got it on there to make sure it sticks to it
Old 04-07-2009, 09:42 PM   #18 (permalink)
NotJawknee's Avatar
Jawknee
will goo gone remove all of the glue left over from the silicone?
NotJawknee is offline   Reply With Quote
Old 04-08-2009, 09:25 AM   #19 (permalink)
^Yea you just have to keep working at it with a rag and it will all come off
Old 04-18-2009, 07:41 PM   #20 (permalink)
bchinfoon's Avatar
Bryan
Thanks for this DIY.
Mine looks like it's not quite centered but I think that's because I took the picture from an angle.
bchinfoon is online now   Reply With Quote
Who's Got a Grafixpressions Steering Wheel Emblem? volksi Inside and Out 421 10-25-2009 01:02 PM
DIY JDM steering wheel emblem........ mycvksi Inside and Out 14 06-12-2008 02:11 AM
