warranty/valve cover question - 8th Generation Honda Civic Forum
Old 03-16-2009, 11:05 PM   #1 (permalink)
Arrow warranty/valve cover question
i was wondering instead of baking a valve cover to change the color of it with the high temp paint can you just use the high temp spray paint? also if you take your valve cover off will it void any warrantys? same with the intake manifold because i was thinking about polishing it
chiv is offline
Old 03-16-2009, 11:30 PM   #2 (permalink)
Zeuceone's Avatar
High temp paint will work. Depends if the issue causing the warranty work had to do with you removing the cover, ie. Dropping a bolt in the engine. Other than than if re installed properly uou will be ok.
Old 03-16-2009, 11:33 PM   #3 (permalink)
High temp paint is fine....i used it to paint my value cover off my old civic and it worked awesome...and just like what he ^^^ said just be carefull...
[IMG]
2006SI is offline   Reply With Quote
Old 03-16-2009, 11:37 PM   #4 (permalink)
same with the intake manifold too? as long as i don't do anything to mess my engine up by removing it it has nothing to do with the warranty
chiv is offline   Reply With Quote
Old 03-17-2009, 01:36 AM   #5 (permalink)
well yea same idea, if you are careful you should be alright but if you take it off you might need to get a new exhaust manifold gasket.....
dont paint the manifolds, they get way to hot and even the high temp paint really cant stay on there too long....just my opinion tho...
Old 03-18-2009, 08:24 PM   #6 (permalink)
ya i was planning on polishing it not painting it
Valve cover...anyone? TXcivic Civic Coupe And Sedan 4 02-16-2009 12:40 PM
need help with valve cover metal_gear350 Civic SI 6 03-08-2008 08:01 PM
will my warranty cover? futhermucker Dealership Experience 6 04-17-2007 06:18 PM
