181 - 200 of 227 Posts
Firstly I am from Australia and this is done on a RHD. Secondly since deltatechx's diy will work I won't be posting any detailed DIY. The two problems that deltatechx had was the ac not turning on and the recirculation motor not working properly. As I have already mentioned in the above post to solve the ac signal you will need to change the evaporator sensor becoz they run on different resistance. It took me like three sleepless nights going through various wiring diagrams and troubleshooting steps from the factory service manual to figure that out (since even in the factory service manual it tells you both HVAC and Climate Control evaporator sensors runs on the same resistance but in fact they are different and I almost changed the MICU instead).
Now to solve the recirculation motor problem, you do not need a new blower assembly to make it fit (you will still need the motor) but you will need both the motor arm (the climate control one is longer) and the pivoting arm (its a straight arm on the climate control instead of boomerang shape on the HVAC) change both of these arms together with the motor and everything will work.
In addition I used a outside temp sensor off a 06 Odyssey and the temp reading seemed accurate so if you could find one from the wreckers that should save you some cash (maybe the sunbeam sensor would be work too but I cannot confirm this).
OK here it is, this is not a easy mod and require quit some work, it may not worth the effort unless you can find the parts from wreckers or ebay.
Things you will need:
1. The Climate Control Module
2. Recirculation Motor with arms and Pivoting Arm
3. Sunbeam Sensor
4. Outside Temp. Sensor
5. Evaporator Sensor
6. In Car Temp/Humidity Sensor and the Vacuum Pipe
7. Heater Sensor (If you are using a hybrid module)
8. Few Meters of Electrical Wires and Electrical Tape
9. Soldering Iron and soldering wires
10. Wire Tapping Connectors
11. A 0.9mm flat screw driver and a small hammer (If you managed to get the connectors with the climate control module like I did)
Steps:
1. Remove the audio panel to gain access to the wiring harness (You can check the audio DIY if you don't know how to).
2. Unlock the 32p connector that came with the climate control module and use the 0.9mm screw driver and knock out every wiring pin except pin no. 24,25,26,31,32 depending on RHD or LHD the wiring colors will be different you can check the diagram on the above post.
3. Again unlock and knock out every pin from the 24p connector, Its better to knock and plug each pin to the 32p connector as you go so that you don't confuse yourself with the wiring colours (Check the diagram above to see which ping goes where if the diagram confuses you then you can check deltatechx's thread).
4. Remove the empty sunbeam sensor cap on you car and replace it with the sunbeam sensor, but remember to feed the wiring through while you are fitting it because it will be impossible to reach it from the bottom of the dash. After that solder or using a cramp connector and wire ping 2 on the sunbeam sensor to ping 24 of the climate control connector. Run the ping 1 wire to somewhere close to the climate control connector and just leave it for now.
View attachment Gauge Control Module Replacement.pdf
View attachment Sunlight Sensor Replacement (With Climate Control).pdf
5. Find a place near the front grill to secure the outside temp sensor, and run both wires through to the cabin ( I ran the wiring through the side guards and through a hole just near the front passenger door, you will need to take the wheel dust cover to see it). Once you got them through wire ping 1 to ping 25 of the climate control connector and leave ping 2 wiring aside from now.
6. Now do the same with the in-car temp sensor, run ping 1 to ping 26 of the climate control connector and leave ping 2 aside for now.
7. Remove the 3 screws and remove the tach module and find ping 21 (Pink) and tap a wire to it and run it to ping 32 of the climate control connector.
8. Follow these steps and remove the blower motor.
View attachment Blower Unit Removal and Installation.pdf
9. Now you got the blower motor off you need to change over the recirculation motor and pivoting arms. These pictures will show the difference between the climate control ones and the HVAC ones. Note that the ones fitted on the blower motor is the climate control ones and the motor arm is longer and that the pivoting arm is different too.
10. Now with the blower motor out of the way you can fit the evaporator sensor, loosen the screws around the extension cover (the one where the blower transistor sits on) so that you can run the wiring of the sensor through. I simply just fitted the new evaporator sensor on and did not bother to change them because I didn't want to spend money to regas my ac if I remove the evaporator core, so what I did was just fitted the new sensor to the other side of the core where you can gain access to without any further removal. After you have changed the motor and sensor fit the blower motor back on and plug all the connectors back on except the recirculation motor connector.
11. Now you can go to a wrecker and cut out some similar connectors so you can knock those wiring pins out and use them to wire the recirculation motor connector (these pings are bigger so you cannot use the old wiring pings that u knocked out from the 32p climate control connector). You will need 3 extra pings here. First knock out all 3 existing pings out of the connector and plug the orange wire to ping 1, the red wire to ping 2 and the 3 extra pings to ping 3, 5, and 7. You can tape and leave the purple ping or just plug it in to ping 4 which is empty anyway. Once you have done that solder some wires to the 3 extra ping wires and run them to the 32p connector, wire ping 3 to ping 31 of the climate control connector, tap ping 5 to ping 7 of the climate control connector which is a black wire and finally tap ping 7 and all the other pings that we left aside from the sunbeam, in-car temp, outside temp to ping 21 of the climate control connector which should be a red wire ( You can use tap connectors or simply slice and solder all of them together).
12. drill a hole and fit the in-car temp sensor vacuum pipe (I haven't done this yet I will post some pictures once I have done it).
13. Plug in the Climate Control Module and test the system and it should all be working :dancing:
14. Put all the interior pieces back and you are done :D
If you are using a hybrid module you will need to wire the heater sensors as well, you can check deltatechx's thread to find out the wiring diagrams for it. http://www.8thcivic.com/forums/i-c-...al-security-navigation/103900-adding-auto-c-controls-my-lx-diy-coming-soon.html
Ok looks like I cannot upload any more pictures. So you will have to refer to the component pdf to see where the in-car temp sensor vacuum pipe goes.
Excellent write up!! I've been planning to figure this out using a few servcie manuals, but you've done a lot of legwork. When I do this, I'll match up what you have against the LHD vehicles (I'll be doing it into a 4 door Si), so everyone else can use the info.
Great job! :D
Two big thumbs up for discovering the different resistance of the evap temp sensor! This will allow me to unpack my stash and finally get it installed.
These part numbers might help.
Civic Hybrid (MX)
heater temp sensor: 80550-SNC-A41
Evap temp sensor: 80560-SNA-A01
Sent from my SGH-T989 using Tapatalk 2
The Acura CSX and Civic Type R have them red by default, as well as some other models of Si from other countries. I purchased a USDM Civic Hybrid control module in blue. When it arrives, I'll be disassembling it to see about tinting it red. I retinted the EL gauge conversion in my 93 Prelude to several different colors over the years. Not hard, just tedious.
Civic Hybrid (MX)
Here's some others. If anyone needs parts numbers for this or cross-referencing vehicles, I work in Honda Parts. Post up here or send me a PM, I'll do what I can for you.
Recirculating Motor: 79350-SNE-A41
Humidity Sensor: 80590-SNC-A02
Aspirator Hose A: 80541-SNA-A40
Aspirator Hose B: 80542-SNA-A40
Sun Beam Sensor: 80510-SDA-A41
Aspriator: 80534-S84-A41
I did some research and here's some compatibility for parts if users want to search for used items. Keep in mind, the parts have to come from a compatible vehicle that was equiped with ACC from the factory.
Recirculating Motor: 08-11 CR-V
Aspirator Hose B: 08-11 CR-V
Sun Beam Sensor: 03-07 Accord, 05-07 Accord Hybrid, 08-11 CR-V
Aspirator: 98-12 Accord, 05-07 Accord Hybrid, 08-12 CR-V, 00-12 Odyssey, 06-08 Pilot, 06-12 Ridgeline, 10-12 Crosstour
Edit: I did a little more research and found that the Evap temp sensor is the same part number for all 8th Civics. There can't be a different resistance on the same part number. It's possible that from the factory Hybrids came with a different part than normal Civics, but now there's only one part number option. Can anyone shed some light on this?
... Edit: I did a little more research and found that the Evap temp sensor is the same part number for all 8th Civics. There can't be a different resistance on the same part number. It's possible that from the factory Hybrids came with a different part than normal Civics, but now there's only one part number option. Can anyone shed some light on this?
Maybe this will help.
06/07 EX FG1: 80560-SVA-A02
08/11 EX FG1: 80560-SWA-A01
06/11 MX (Hybrid): 80560-SNA-A01
We absolutely need the Hybrid MX sensor to make this work.
Got it! All Civic sedans come with the MX evap temp sensor. When I put my vehicle into Honda's Parts Catalogue by VIN, it showed that I already have that sensor. It was completely throwing me off. I just overlooked the model applications! So I'm set, ordered everything but the evap temp sensor, and I have two ACC panels coming my way!
Does anyone have a lead on CSX climate control modules? With this going into my Si, the Hybrid module won't match being blue. I'm assuming the blue portion is made into the LCD portion. I'll be able to disassemble and know for sure next Friday.
You'll need to find a CSX Type S if you want red. ...good luck with that... There's several CSX AAC units listed on LKQ.CA but no Type S's that I saw.
The color of the display is a colored film on the lens itself, it'll peel off. It's easy enough to get to so it's definitely doable to change colors. A double layer of red colored vellum might just do the trick.
From what I could tell it was made into two pieces that made up the LCD portion. If you can walk me through removing the blue, I have sheets of acetate that I could use to make it display red.
I completely disassembled a spare AAC unit I had in the garage this morning.
The blue is on the back side of the glass and is adhered by what, I do not know - it's definitely not meant to come off.
Although changing the color looked like a relatively easy mod, I'm going to recant my assessment and offer this instead: hold out for a CSX Type S unit.
