Are you planning on just removing the bottom portion of the grille and leaving it that way?
If so that won't work...the grill is help in by screws on the bottom and top. If you want to just take out the grille and separate the bottom portion... 1. Pop your hood and remove the black plastic piece surrounding your hood latch. 2. Remove the bolts that are attaching the grille to the radiator support (2) 3.Then you should be able to flex the bump forward enough to reach behind the grille (if you have the right ratchet set) and loosen and remove the 10 or 11 screws holding the grill together. |
#12 (permalink) |
Teach me how to take pics
^ you tell him bear
![]() P2R TBS/TBGs / Fujita SRI / Skunk2 10th Anv. Knob/Radiator Cap / TWM SS/ Auger Boot TWM Cable/Base Bushings / StrutKing DP Cover / JDM Dipstick / Cleared Head/Tails / ![]() My Car Build Thread - Amilia |
#14 (permalink) | |
thanks bear |
#15 (permalink) |
step one : take a few pictures to remember how your car looked before
step two : have alcoholic beverage chilled on the side step three: bust out the dremel or other cutting tool (honestly i used a sharp pair of scissors... then later i busted out the dremel and smoothed it down) step four : do work! step five : step back and admire handywork step six : open ice cold alcoholic beverage and enjoy btw i only cut out that section because i hit a piece of 16wheeler tread on the freeway going 60mph so most of those plasic things were just hanging off. it doesnt look that bad if you only cut the vanes and not the whole thing. It'll look weird at first but it'll grow on you. I recommend (sounds ghetto but better than getting rocks in your condenser or radiator) using some mesh (i.e. chicken wire the really close kind that looks like the stuff you use on a screen door) to protect those pieces. |
| after lowering the springs, bottom seat one hole wont stay on bottom | 20civic07 | Mechanical Problems & Technical Chat | 4 | 03-04-2008 09:30 PM |
| How to remove Si emblem on the front grille? | asdf | Introduction & Pictures | 19 | 02-28-2008 10:12 AM |
| Rear Bumper bottom piece? | kgeier82 | Inside and Out | 13 | 01-22-2008 11:24 PM |
| How to remove front bumper | BlackMAMBA | Mechanical Problems & Technical Chat | 8 | 07-10-2007 02:41 PM |
