Windows squeaking after tinted???? - 8th Generation Honda Civic Forum
Old 06-19-2008, 10:13 AM   #1 (permalink)
hondaonchrome's Avatar
Lonny
When i roll down and up the windows i have this annoying squeak, does anyone know how to fix this????
Thanks,
Lonny.
hondaonchrome is offline
Old 06-19-2008, 10:24 AM   #2 (permalink)
Dan
Sounds like they might have tucked the seals on the bottom and the lower one is stuck.
Take it back to them.
Otherwise, you could just take the door panel off, flip the seal back up, and put the door panel back on.
darkdan is offline   Reply With Quote
Old 06-19-2008, 11:12 AM   #3 (permalink)
Lonny
I pulled the top seal back up...is there another 1 in there?
hondaonchrome is offline   Reply With Quote
Old 06-19-2008, 07:13 PM   #4 (permalink)
black07coupe's Avatar
its not the seals.. mine squeek too because the window is thicker. just keep your windows clean and they wont squeek. mine never make the sound right after a wash.
black07coupe is offline   Reply With Quote
Old 06-20-2008, 12:00 AM   #5 (permalink)
Lonny
I will have to try cleaning them....
Old 06-20-2008, 08:50 PM   #6 (permalink)
Dan
Yes, there are two seals. The bottom one cannot be pulled back up very easily without removing the door panel.
LOL. The window is thicker. Window tint is typically 1 mil to 1.5 mils (thousandth of an inch).
Old 06-21-2008, 02:50 PM   #7 (permalink)
Brandon
^correct, i just got my windows tinted last week and i noticed the squeaking. Then i carefully looked and there was another seal not flipped up. So I grabbed a wire coat hanger and wrapped it in tape and pulled it back up. Problem solved
th4itanium is offline   Reply With Quote
Old 06-21-2008, 08:43 PM   #8 (permalink)
yah mine squeked too. bring it back to the tint guy and he'll either use a 'prying' tool or he'll take the door panel apart
k__dam is offline   Reply With Quote
Old 06-21-2008, 10:54 PM   #9 (permalink)
rileyrat's Avatar
I simply pulled the top portion of my door panels out by hand, properly positioned the seals and put it back in. Putting it back together wasn't too bad once I found the trick of pushing up and in at the same time.
rileyrat is offline   Reply With Quote
Old 06-21-2008, 11:24 PM   #10 (permalink)
quiet3's Avatar
Q
mine squeaked for a while but it eventually stops if you don't want to take the door off. i never took the panel off to fix it because i had no time.
quiet3 is offline   Reply With Quote
tinted windows armarms Inside and Out 13 05-15-2008 12:46 AM
Windows getting tinted menotakoala Inside and Out 15 03-30-2008 03:36 AM
got my windows tinted civic4ever28 Inside and Out 15 09-02-2007 01:00 PM
Tinted Windows in OH 337 Mid-West 15 09-12-2006 04:27 PM
NHB Si tinted tails, cleared headligts, windows tinted 60103 Introduction & Pictures 11 06-06-2006 12:35 AM
