Old 05-16-2008, 11:53 PM   #1 (permalink)
amp grounding
Quick question, my car still make a high pitch wine, I was wondering if it is because some things aren't grounded properly?
I now have the AMP/CAP, power wire from battery to cap then to amp and ground wire from amp to cap and then to car metal point.
[IMG][/IMG]
The grounds (2) are separate wires but on the same bolt
The powers (2) are separate wires but on the same bolt
twisted2corpse is offline
Old 05-16-2008, 11:57 PM   #2 (permalink)
Checoman's Avatar
as long as the grounds for the amp and cap aren't on the same bolt/screw you're good to go ..otherwise change it
Checoman is offline
Old 05-17-2008, 12:01 AM   #3 (permalink)
how would i change it
Old 05-17-2008, 12:12 AM   #4 (permalink)
Checoman's Avatar
The power is no problem,since they have to be serial in order for the cap to put power on the amp when needed , in this case you will have to drill another hole to have separate grounds =S ...
Like this
Checoman is offline
Old 05-17-2008, 12:18 AM   #5 (permalink)
Thanks, could this be why the car is making high pitch wine noise when accelerate?
And does how i have the currently wire hurt anything?
Old 05-17-2008, 02:25 AM   #6 (permalink)
you'll be fine having your ground going from cap-amp-ground.....
What guage wires are you running for your ground and Power?
The wines coming out of your sub? only when you accelerate?
blackouthx is offline
Old 05-17-2008, 04:04 PM   #7 (permalink)
all power and ground 4 awg, the wines is only when you accelerate. When wired car aftermarket radio I used the same switched wire to wire the direct wire for my radar, if that could have anything to do with it. What you think? Thanks
Voltage Stabilizers & Grounding dp. I.C.E., Electrical, Security, & Navigation 2 04-27-2008 03:03 PM
Buddy Club Condenser Kit & Ebay Grounding Kit bioevolve Bolt-Ons And All-Motor 27 02-21-2008 03:10 PM
Relay and grounding joenguyen Lighting, H.I.D.'s, & Neon 8 05-31-2007 07:53 PM
Grounding Kit spideryk Garage 0 04-04-2007 12:02 PM
grounding kit ? CivNick Bolt-Ons And All-Motor 19 12-18-2006 08:15 PM
