I personally have an engineering background so I use my Multimeter and Ohm's Law :) Basically, if You know the load resistance and target power, then you can calculate the necessary voltage. You throw in a CD with a 50hz tone, set all settings to flat on your radio, diconnect the subwoofer from the amp, and turn the volume on the head unit up to 75%. Stick your multimeter on the speaker terminals on the amp, and adjust the input gain until you get the voltage you calculated.
As far as calculating the voltage, it's pretty easy. You know that (Power = Voltage * Current) and you know that (Current = Voltage / Resistance). If you put those two together, you know that (Power = Voltage * Voltage / Resistance). Move things around to calculate Voltage and you get (Voltage = SQRT(Power * Resistance)) where SQRT is the square root. As an example, my amp is rated at 425Watts RMS and my subwoofer is wired in parallel as a 2 ohm load. so Voltage = SQRT(425 * 2) = 29.15 volts. This may seem complicated, but it really is pretty easy and it tunes the amp's input gain perfectly. Never turn the input gain up for more bass. It is not a bass knob. It is meant to match the impedance of the pre-outs so that the amp puts out the rated power. A bass boost knob is what is used to increase the bass ![]() |
Yes, that is true. I personally set my LPF to 80Hz and tune to 50Hz but you could tune it higher or lower as well. Here's a good web page that explains the impedance changes due to frequency for anyone who is interested.
Amplifier Output Impedance Why It |
#9 (permalink) | |
#10 (permalink) |
To be totally honest, I just choose a frequency within the speakers range. 50Hz for subwoofer since it is playing 80hz and below. for midrange, I would choose something higher. If you really wanted to get into it, you certainly could do all the calculations for variable impedance and stuff based on the resonating frequency of the speaker. I honestly don't think your going to notice all that much of a difference in sound but I could be wrong. I haven't actually gone through that much trouble before haha.I just calculate the needed voltage based on the speakers rated impedance (2 ohms in my case) and throw in a test tone of a frequency that is in range.
#11 (permalink) |
40 hz for sub, and for the midranges, i tune with 1k hz. Weither thats good or not i dunno, but my test tone cd only has those tones on it.
The only thing i never liked about using a DMM to tune, is that some amps are not really rated at what it says. Most amps dont come with "birth sheets" so its kinda hard to know if you actually setting the gains to high or low. Plus most subs are not exactly 2 OHMs, but 1.8 or 2.1. Same with subs rated at 4 OHMs. The best way to tune is with an oscilloscope. With that you can easily see with a speaker or sub starts to clip. Unfortunitly, most people, and somtimes even car audio shops, dont have these laying around. |
| Need place where to tune | Demo22 | Forced Induction And Nitrous | 2 | 04-08-2008 01:02 PM |
| My greddy kit is getting a tune.. stay tune... :D | 07CivicSiRacer | Forced Induction And Nitrous | 36 | 04-03-2008 12:04 PM |
| Test&Tune ( THIS FRIDAY! 02/29/08 ) | Whocares05050 | Florida | 30 | 03-04-2008 06:03 PM |
| What does it mean to Tune your car? | llckll | Bolt-Ons And All-Motor | 10 | 09-11-2007 04:50 PM |
| M.I.R test & tune sunday may 27th | udumkid | Mid-Atlantic | 74 | 06-19-2007 02:04 PM |
