Old 05-12-2008, 05:54 PM   #1 (permalink)
Simple magic solution?? PAC AOEM-HON17 ???
I'm researching but finding little.. This little guy might be the ticket...
From all I'm seeing, the civic premium oem head unit sends balanced outs to the outboard oem amp... If normal RCA outs can be generated from those Diff Balanced outs, a guy could use any amp diff inputs or not.. such as a KAC-X4R kenwood amp with all the DSP crossover, eq, time-alignment etc a guy could want for tuning.
http://www.pac-audio.com/instructions/OEM-1.pdf
I shot an email to PAC directly asking about it. Hopefully we might have a cute little product to make simple amp upgrades with tunability to factory head unit easy... and inexpensive.
bsbabcock is offline
Old 05-13-2008, 01:27 AM   #2 (permalink)
Let us know will ya!
toxin is offline
Old 05-13-2008, 09:39 AM   #3 (permalink)
We'll see..
I posed the question to their tech support specifically mentioning the Honda's oem head unit inputs and the resulting outputs from the PAC unit.
Two of those DSP digital kenwood amps would drive two-way active frontstage, rear fill and sub, ALL completely tuneable w/ active crossovers, para-eq and individual time alignment adjustments... Just add better speaker drivers and then pull your hair out tuning forever. :) Or bribe a friend I work with on Buwalda's team to help with an RTA. hehehe
Old 05-13-2008, 11:57 AM   #4 (permalink)
I have a Harness and active interface converter for the premium system that lets you connect any aftermarket amp. If you have an amp with balanced inputs you can skip the converter and plug the harness right in. The active converter is flat with very low distortion numbers. The harness attaches to the factory harness and also provides the remote wire and line outs.
I have been doing these for over a year mostly for the TSX but the Premium Civic system uses the same set up. A bunch of Civic guy’s are already using my harness and converter with the premium system.
jeff
mercman is offline
Old 05-13-2008, 12:35 PM   #5 (permalink)
I'm using it with my JL 500/5 and it's great. I just like having the option of using unbalanced amps in the future too.
toxin is offline
Old 05-13-2008, 01:38 PM   #6 (permalink)
"it" meaning the PAC AOEM unit or Mercman's (Jeff's) kit?
Old 05-13-2008, 04:15 PM   #7 (permalink)
I was just looking at that PAC harnes too...It looks like a good option...Let us know if you find out anything.
happytorito is offline
Old 05-13-2008, 05:28 PM   #8 (permalink)
Mercman's harness. Sorry for not being clear. I don't need the PAC since my JL has balanced inputs.
toxin is offline
Old 05-18-2008, 11:51 AM   #9 (permalink)
Amp and speaker upgrade for FA5
Hi, I would like to upgrade my component speakers powered by an aftermarket amp and hopefully put them in the stock positions. I want to keep the stock head unit. I've heard from the forums that the stock HU doesn't need any sound modulation, but would require a harness to connect to a compatible amplifier. Where can I get a stock HU to aftermarket amp wiring harness? I'm thinking of a single 5 channel amp to power everything. Now I guess I'll need a harness to connect the stock hu to the amp. Where do you guys think I should mount the amp? And what components should I get that can easily fit into the stock housings? Thanks guys.
John
UnMechanic is offline
Old 05-18-2008, 02:02 PM   #10 (permalink)
I would say get a JL Audio Clean Sweep or a Rockford 3 Sixty. I am running a Kenwood KAC-X4R with "shielded" RCA's, and using 2 line level converters and I am still getting a lot of noise when I go into "re gen" mode. I am getting a new head unit and I know this will get rid of all the noise. If you want to keep the stock head unit, go with one of the two processors listed above.
Jayhawker is offline
Old 05-18-2008, 02:39 PM   #11 (permalink)
Mercman where can I purchase the wiring harness to connect the stock HU to an aftermarket amp? I'm planning to connect it to a rockford fosgate amp, which I believe accepts balanced diff inputs
Old 05-18-2008, 07:03 PM   #12 (permalink)
Just Drop me a PM
jeff
mercman is offline
Old 05-19-2008, 09:31 AM   #13 (permalink)
I suspect it's your loc's.
"re gen" mode????
Old 05-19-2008, 01:29 PM   #14 (permalink)
Do you have the premium or standard sound system HU?
With the premium system there is no need for sound processors or noise eliminators. Noise with the factory system integration can be avoided by using the proper connection techniques.
jeff
mercman is offline
Old 05-19-2008, 04:27 PM   #15 (permalink)
Duce2k's Avatar
I know of a guy in another forum that used mercman's harness and connected it to a blanced input Audiocontrol four.1 EQ, the Audiocontrol eq's have differential inputs and outputs which are switchable to unbalanced depending on your amp, by using one of these you can use any amp whether it accepts balanced or unbalanced inputs
Duce2k is offline
Old 05-20-2008, 11:04 PM   #16 (permalink)
does anyone have a pic of what mercman's adaptor/harness looks like? i need one of them ASAP. if anyone knows a quick way to get a hold of mercman please let me know too. thanks!
olsonoski is offline
Old 05-21-2008, 08:25 AM   #17 (permalink)
"re gen" mode????
I have a Hybrid.
Mercmans quote "Do you have the premium or standard sound system HU?"
No, I have the basic radio.
Like I said though, once I get the new head unit, all of my issues will be gone.
Old 05-21-2008, 09:53 AM   #18 (permalink)
PM him.
Old 05-21-2008, 11:11 AM   #19 (permalink)
yep. i got a hold of him. thanks.
hey has anyone actually tried the PAC device? any feedback on how its working for them?
Old 05-21-2008, 01:25 PM   #20 (permalink)
Duce2k's Avatar
I have his harness but I haven't installed my system yet, I still need to get my front components and another amp. I'll probably take pics of the install and post them up.
Duce2k is offline
work your magic!!!! FG2NME Photoshop 10 03-29-2008 09:51 PM
Simple photoshoot of a simple car :) Fully Flared Introduction & Pictures 11 09-19-2007 10:35 PM
Ministry of Magic Soundboy Movies & Music Reviews 0 06-05-2007 09:49 PM
Magic? Si 07 Water Cooler 0 01-27-2007 07:24 AM
Help me use Black Magic please asndragonboii Detailing 13 10-17-2006 08:50 PM
