Old 05-09-2008, 10:12 PM   #1 (permalink)
Debo's Avatar
Derick
Loc?
well i hooked up a system today in my friends 2007 2 door SI. There is a problem with the JL audio 10w1 over heating. He has the factory non-nav HU so we ran a loc off the 2 rear 6.5's and un-hooked the 8" sub. the amp is a fosgate 300w @ 4 ohms with the gain at the hafe way point. what i do not ubderstand is the sub got so hot it was smoking. any thoughts on what the problem could be? I have done many sound systems with no problems. this is the 1st time this has happened to me.
TIA.
Debo is offline
Old 05-09-2008, 10:37 PM   #2 (permalink)
Kroze's Avatar
your wiring is wrong. check and recheck everything. make sure all the positive go to positive and negative go to negative.
do you have an inline fuse that's more than 30 amp (more than 30a is a no no for the 300watt amp)? the fuse should cut off if you have an inline fuse.
Kroze is offline
Old 05-10-2008, 12:36 PM   #3 (permalink)
Debo's Avatar
Derick
the fuze is a 25 the ground is solid the remote is ran to the fuze block by the driver side door to the factory radio. the loc is wired correct so i might be running to much power from the amp.
Debo is offline
Old 05-10-2008, 01:47 PM   #4 (permalink)
Kroze's Avatar
the fuse should cut off before the amp started smoking.
Kroze is offline
Old 05-10-2008, 02:05 PM   #5 (permalink)
Debo's Avatar
Derick
the sub was smoking not the amp.
Debo is offline
LOC Gain Settings Gas Is Expensive I.C.E., Electrical, Security, & Navigation 10 03-03-2008 01:25 AM
Wiring LOC? 08CivicSiGG I.C.E., Electrical, Security, & Navigation 2 01-21-2008 11:02 AM
Some LOC help please AbstraKt I.C.E., Electrical, Security, & Navigation 2 02-10-2007 11:55 PM
LOC help SiC17 I.C.E., Electrical, Security, & Navigation 13 09-07-2006 12:54 PM
What LOC to use. rba46 I.C.E., Electrical, Security, & Navigation 5 07-08-2006 12:58 PM
