Old 05-09-2008, 10:44 AM   #1 (permalink)
Navi Question...
Is $600 for a like new OEM Honda Navigation from a 2006 Civic Ex 2dr a good deal?
Included is the GPS antenna, the mounting bracket, an I-pod adapter with cables (so you can control your I-pod through the touch screen interface), the instruction booklets, and the anti-theft lock code card that came with the system.
It has no scratches or dings. Only used for 6 months....
What do you guys think?
8thgenSilverEx is offline
Old 05-10-2008, 12:36 AM   #2 (permalink)
Produce Wizard
jlannoo's Avatar
I don't think thats a bad price. Make sure though if you are going to attempt an install that you get the right nav unit for your car.
EX Sedans require the regular sound NAV unit
EX Coupes and all Si models require the Premium Sound Nav unit
The unit will Say Premium right on the front if it is one.
Jamie - 2008 NHBP Si coupe -
jlannoo is offline
Old 05-10-2008, 09:30 AM   #3 (permalink)
came out of a ex 2dr
i currently drive the same ride
Old 05-10-2008, 09:35 AM   #4 (permalink)
dobiejoe's Avatar
Joe
How are you going to wire it in? Its not plug and play. the whole harness behind the dash is diffrent.
dobiejoe is offline
Old 05-10-2008, 09:37 AM   #5 (permalink)
i have friends that are really good with this kind of stuff.....
i've seen it done, so i'm not worried....
but i'm kind of just thinking in forgetting the idea.....
Old 05-10-2008, 06:05 PM   #6 (permalink)
Produce Wizard
jlannoo's Avatar
From what I understand from folks that have looked at the pinouts for both the Nav and non-Nav connectors is that You can make it work with only a few extra wires. I mean the wires are probably in different places but you can easily add say a +12 here or the move the VSS wire to there or for example run your own reverse signal wire. It would be crazy to buy a whole new dash harness and a headache! :)
jlannoo is offline
Parts List for OEM Navi install for non navi si???? btrackit I.C.E., Electrical, Security, & Navigation 0 03-25-2007 03:19 PM
Installing Navi into non-Navi (mic, wheel ctrls) bung_goo Civic SI 1 10-24-2006 10:33 PM
Installing Aftermarket Navi/DVD into non-navi si help needed 06Fg2 I.C.E., Electrical, Security, & Navigation 3 06-15-2006 11:42 AM
