Old 05-08-2008, 05:14 PM   #1 (permalink)
Power Door Locks/radio
I have a 2007 Civic Si Sedan, with an after market radio. I was putting a new cd player in earlier today and the 12v constant wire/memory wire had no voltage.. So i just took the easy way out for the moment and hooked up to the red accesory wire/ignition. Just for short term. I checked the radio fuse but i wasnt sure if that would control the constant 12v wire.. well that wasnt it. Then on top of that i found that my Doors wont lock unless the car is on from the inside. I looked at the door lock fuse and it looked fine. Do these two things have anything to do with each other??? ANy help will be greatly appreaciated. Any thing i can check? if the car is not on the doors will not lock from the inside. Nor from the Key at any time. So i really need to know if theres anything i can do.. thanks for any help
jr8801 is offline
Old 05-08-2008, 09:46 PM   #2 (permalink)
i know on the early EJ chassis the keyless entry was built into the radio and when you installed an aftermarket radio in the car it came with this crazy bracket that you had to bolt to the frame in the dash and slide the stock radio into it in the dash then put the aftermarket one in there.
greysquirrel is offline
Old 05-09-2008, 07:47 AM   #3 (permalink)
I already had an after market radio in t here and the keyless worked fine and i did not unbolt anything unusual i dont think.
Any other suggestions or more info on the subject above?
jr8801 is offline
Old 05-09-2008, 09:05 AM   #4 (permalink)
volvo9's Avatar
Andrew
it's a fuse under the hood. labeled backup or something like that
volvo9 is offline
Old 05-09-2008, 03:15 PM   #5 (permalink)
THanks thats what it was
I really appreciate the help!!
jr8801 is offline
Old 05-09-2008, 03:18 PM   #6 (permalink)
Kill Your Self Krew
Zeuceone's Avatar
dam beat me to it. yup that fuse always blows on everyone.
is Missy a squirter?
Zeuceone is online now
Keyless entry on a DX (no power locks) WHITEcoat I.C.E., Electrical, Security, & Navigation 5 06-10-2008 11:12 PM
Installing power door locks in a DX Kroze Do It Yourself Articles 9 05-09-2008 09:27 PM
No power, no locks...what's wrong? BlueSi4 Mechanical Problems & Technical Chat 7 05-06-2008 01:58 PM
Programmable automatic power door locks Mari0 Mechanical Problems & Technical Chat 2 04-23-2008 09:50 AM
02 SI Door Locks Wont work johnjester Mechanical Problems & Technical Chat 0 04-08-2008 07:08 PM
