Old 05-07-2008, 06:21 PM   #1 (permalink)
Factory speaker wire
Anyone know what size the factory speaker wire is?
Who has run new speaker wires into their doors (properly, through the grommet, unlike the silly DIY on here)? How much of a pain in the ass was it?
toxin is offline
Old 05-07-2008, 06:34 PM   #2 (permalink)
PrEgO CaNe's Avatar
Brendan
not sure on the size of wire if i had to guess 12 gauge maybe, but i ran 8 gauge wire in through the grommet to both doors and it was a PITA. i was very close of just giving up, but i wanted it done properly and to look good. so in the end it was worth it. all i can say is have fun!
PrEgO CaNe is offline
Old 05-07-2008, 07:02 PM   #3 (permalink)
You're running EIGHT gauge speaker wire???
The factory wire is certainly not even close to 12-gauge. It is more like 18-22, but I was wondering if anyone knew for sure. If it were really 12-gauge, running new wires would be a complete waste of time. 12-gauge speaker wire is major overkill for just about anything.
toxin is offline
Old 05-08-2008, 07:56 AM   #4 (permalink)
PrEgO CaNe's Avatar
Brendan
shit man my bad i got that all wrong, i don't even know what i was thinking. i ran 12ga through the doors and the factory i think was 18. sorry for the mistake. if your not planning anything real big don't bother replacing.
Old 05-08-2008, 10:14 AM   #5 (permalink)
bikinpunk's Avatar
Erin
What kind of power are you looking to run?
18 gauge actually has it's place even with high powered setups. Remember, we're looking at AC voltage out of the amps, rather than DC.
If I had to guess, I'd say the factory wire is 18ga.
bikinpunk is offline
Old 05-08-2008, 10:41 AM   #6 (permalink)
Razvan
Would it be ok to just splice the factory wires near the headunit, and run them to the amp on the sides of the car? Instead of replacing the whole wiring.
ro.sniper is offline
Old 05-08-2008, 10:44 AM   #7 (permalink)
bikinpunk's Avatar
Erin
In that case, you're practically running as much wire from the headunit to the amp as you would straight out of the amp to the speaker.
Old 05-08-2008, 12:27 PM   #8 (permalink)
I'm planning to have 100w on tap for each door speaker.
If the factory is 18ga, that's probably good enough for me.
http://www.bcae1.com/images/swfs/spe...rassistant.swf :)
Thanks guys.
toxin is offline
Old 05-08-2008, 12:35 PM   #9 (permalink)
Razvan
Is that a bad thing? I'm good at installing I just don't really know best practices.
Old 05-08-2008, 12:38 PM   #10 (permalink)
I don't think regardless the power I could ever be convinced of running anything larger than a good quality 16guage to any speaker.. Even a sub. I've heard 16 and 18 guage runs in good home systems which due to the quality of the cable and the better terminations, literally spank thick 12g lamp-chord. BUT, I do NOT condone spending silly money on it... Canare 4S11 at about a buck per foot is one of my favorites for 4-conductor biwire runs, for example.
Also, just running a single strand straight from amp to driver without any plug-terminals in any guage is going to be marginally to far better than having a bunch of harness-plug points between A and B... Even if you stay at 20 guage. That's probably your biggest benefit, I'd say.
Here ya go.. Kimber 16g 4-conductor.. good for two or four drivers..
Kimber Kable - KWIK-16 In-Wall 16-Guage Speaker Cable-Audio Advisor
bsbabcock is offline
Old 05-08-2008, 01:37 PM   #11 (permalink)
bikinpunk's Avatar
Erin
For only $12.38 each when QTY 50+ purchased - 16AWG Enhanced Loud Oxygen-Free Copper Speaker Wire Cable - 100ft | 16AWG Loud Speaker Cable
Game over.
Old 05-08-2008, 01:39 PM   #12 (permalink)
Liked your fake-trunk-floor amp install also dude.
Old 05-11-2008, 09:21 PM   #13 (permalink)
runeknight95's Avatar
Derek
Is this Ok?? it was my plan, seems easier than running new wires.
Did we get an answer what gauge is the speaker wire, 07 civic here, I am also planing to run 100 RMS per channel x4
Using this AMP
Alpine Electronics of America, Inc. - MRP-F600
runeknight95 is offline
Old 05-11-2008, 11:31 PM   #14 (permalink)
I ran all new wire and just didn't use any of the factory stuff. I used 12 gauge wire and 16 gauge for the lower powered stuff everything turned out great, the 12 gauge was tough getting in panels and through doors though.
twisted2corpse is offline
Old 05-11-2008, 11:52 PM   #15 (permalink)
Toxis's Avatar
Even Women Aren't Safe
running all new 12awg Stinger speaker wire with 100w per driver. Overkill? Probably but why not?
Toxis is offline
Old 05-12-2008, 12:07 AM   #16 (permalink)
BEWARE THE REP!!!!
ImTheVoiceOfGod's Avatar
Post-Whore
I dont know if you already did it, but if not, here is a little trick to make running to the doors easier:
Find the wire where it enters the grommet leaving the cabin, go back about 1 foot or so of wire, cut the olf wire, connect the old wire to your new with a butt connector
pop off the door panel (You can find someone else to tell you how to do that), find the wire where it attaches to the speaker, and pull.
Simple. I know some people are probably thinking Im an idiot for explaining this, but some people will try to just shove the wire through and make it harder than it really is.
ImTheVoiceOfGod is offline
Old 05-12-2008, 02:44 PM   #17 (permalink)
VoiceOfGod, is that what you did? And it works? Did you have to pop off the grommet, or does it pull right through?
toxin is offline
Old 05-12-2008, 02:46 PM   #18 (permalink)
BEWARE THE REP!!!!
Post-Whore
I havent done it, But I was thinking about doing it for a while, but ended up getting lazy, I didnt see any reason why you would need to pull off the grommet, it looked pretty straight forward.
Old 05-12-2008, 06:21 PM   #19 (permalink)
Toxis's Avatar
Well good luck doing that on the driver's side. There's a molex plug that will not allow other wires to fit through. I had my installer cut a new run with some wire loom and had it sealed off. He needed to run some real thin wires for my window module of the alarm and it wouldn't fit through the OEM sleeve.
Toxis is offline
Old 05-12-2008, 08:54 PM   #20 (permalink)
Derek
Is the wire 18 gauge already or??
which wire on the factory amplifier on fg2/fa5 is the power wire? 20civic07 I.C.E., Electrical, Security, & Navigation 14 04-26-2008 02:00 AM
routing speaker wire next to power wire??? randylasar I.C.E., Electrical, Security, & Navigation 3 02-20-2007 01:53 PM
Jacking into stock sub speaker wire Gaijin I.C.E., Electrical, Security, & Navigation 4 01-25-2007 11:50 AM
NOOB QUESTION. can speaker wire be used to power LED? irichard I.C.E., Electrical, Security, & Navigation 6 05-11-2006 09:00 PM
Speaker wire color code waleylim I.C.E., Electrical, Security, & Navigation 2 03-08-2006 10:20 PM
