Old 05-12-2008, 10:32 PM   #21 (permalink)
Originally Posted by toxin View Post
VoiceOfGod, is that what you did? And it works? Did you have to pop off the grommet, or does it pull right through?
I pulled off the molex plugs and cut a small hole and ran 12 gauge wire through the same area were the factory speaker wire goes it was touch took 2 hours for both door, completed and doesn't even look as if i didn't anything completely flawless job. You wouldn't even know that there is 12 gauge speaker wire in there, the crossovers are mounted under seat since they are pretty big.
twisted2corpse is offline
Old 05-13-2008, 01:25 AM   #22 (permalink)
Toxis's Avatar
Even Women Aren't Safe
pics?
Toxis is offline
Old 05-13-2008, 01:49 AM   #23 (permalink)
Originally Posted by Toxis View Post
pics?
don't have any, could take one but it looks like nothing done and it is there.
Old 05-13-2008, 02:52 AM   #24 (permalink)
Toxis's Avatar
did you go through the molex plug or around it? I haven't looked at it directly but I'm guessing there's some empty spots you drilled out?
Toxis is offline
Old 05-13-2008, 08:09 AM   #25 (permalink)
basically what i did was un-plug the 2 molex connectors pull out the cables as far as could (not much to work with), then under were the connectors are there is a place were I wire could go through if needed, I then fished the 12 gauge wire through there and then through the thin tubing until inside the door.
Old 05-13-2008, 12:09 PM   #26 (permalink)
Toxis's Avatar
ok, I'll have to try it on the pass side since that's not done yet.
Toxis is offline
Old 05-13-2008, 03:02 PM   #27 (permalink)
runeknight95's Avatar
Derek
Is the stock speaker wire 18 or 20 or even 22?
runeknight95 is offline
Old 05-13-2008, 05:39 PM   #28 (permalink)
I think we're in agreement that it is in fact 18-gauge.
I think I'm just gonna order the amplifier bypass harness from Crutchfield so I don't have to **** with the molex. :)
toxin is offline
Old 05-13-2008, 06:01 PM   #29 (permalink)
Derek
Good stuuf man, good luck. Im just going to wire the amp into a harness and attack it directly to the car.
Old 05-14-2008, 01:22 AM   #30 (permalink)
Toxis's Avatar
Good luck with the limitation of power toxin. 12awg all the way!
Toxis is offline
Old 05-14-2008, 07:02 AM   #31 (permalink)
I did prevoiusly use the factory speaker wire, which is thin as hell. Now with 12 awg all the way I notice much better quality and by means of more power!
Old 05-14-2008, 09:00 AM   #32 (permalink)
I still say the biggest benefit is from eliminating all the terminal plugs between amp and driver. All those connection points I'm betting cause the most signal degradation.
bsbabcock is offline
Old 05-15-2008, 01:15 AM   #33 (permalink)
Toxis's Avatar
and not the speaker wire's limitation of power transfer? Not saying you're wrong but speaker wire gauge can and will degrade the signal. Adding resistance isn't a good thing.
Toxis is offline
Old 05-15-2008, 02:11 AM   #34 (permalink)
what are you talking about? I'm Confused?
Old 05-15-2008, 10:23 AM   #35 (permalink)
Oh I agree..
The "quality" of the wire itself is indeed important. Not to say that the wire itself isn't a big factor. The quality of the wire and condition is very important actually.. Even more so than just gauge alone I think... I was pleasantly amazed at the HUGE difference when I upgraded to some tributaries SP6BW which is a 4-conductor 16G (I think), 50% silver plated OFC 4 conductor, biwired.
The previous wire was standard Monster 12g 2-conductor which was thicker, but I'm sure there were strand-count differences as well as the extra silver in the tributaries (which is far better conductor than even the best copper). The difference in $3/foot used by a high-end A/V business for wiring home theaters with $50k speaker setups verses $1 foot off a road-shop spool.
But again, I reach my diminishing returns with spending silly money on esoteric high-end wire as stuff like that wire above can be had relatively inexpensively and deliver excellent quality.
In some cars though with these harnesses and break points in possibly several locations, my original point was that eliminating all those harness connections I can only see as a very very good thing for getting nice clean power to the drivers, even if it's just a decent 16 gauge run. Takes less effort I'd imagine for the amps to push that signal through a bunch of plug ends, verses straight shot through wire strands. Kind of like the difference between the el cheapo clip/pinch posts on the back of cheap home speakers verses good twist-down style posts on the high-end jobs.
It's all the efficient transfer of electrons. :)
Old 05-15-2008, 03:37 PM   #36 (permalink)
Ok thanks
Old 05-15-2008, 03:42 PM   #37 (permalink)
hehe.. sorry.. was some serious coffee this morning. :)
Old 05-16-2008, 11:26 PM   #38 (permalink)
Toxis,
Those are general statements. Have you done the actual math on 18g wire?
toxin is offline
Old 05-16-2008, 11:29 PM   #39 (permalink)
Toxis's Avatar
what kind of math?
Toxis is offline
which wire on the factory amplifier on fg2/fa5 is the power wire? 20civic07 I.C.E., Electrical, Security, & Navigation 14 04-26-2008 02:00 AM
routing speaker wire next to power wire??? randylasar I.C.E., Electrical, Security, & Navigation 3 02-20-2007 01:53 PM
Jacking into stock sub speaker wire Gaijin I.C.E., Electrical, Security, & Navigation 4 01-25-2007 11:50 AM
NOOB QUESTION. can speaker wire be used to power LED? irichard I.C.E., Electrical, Security, & Navigation 6 05-11-2006 09:00 PM
Speaker wire color code waleylim I.C.E., Electrical, Security, & Navigation 2 03-08-2006 10:20 PM
