Old 05-03-2008, 07:04 PM   #21 (permalink)
fg2!kid's Avatar
エリク eric
oh! hahahah no shit thanx
fg2!kid is online now   Reply With Quote
Old 05-03-2008, 07:17 PM   #22 (permalink)
volvo9's Avatar
Andrew
Originally Posted by fg2!kid View Post
sweet yea some pics would be great so your saying to do a wire harness just like whiterice dont i need to use female connecters ?
Yeah, if you set up the whiterice adapter with female ends then grab 2 of these, so one of them will be for the left speakers and one of them will be for the rights
Then grab one of these to plug into the 2 y splitters you plugged into the whiterice adapter. So then you will have aregular male headphone plug as the input. You can now give the amp turn on wire 12v with the ignition on and plug the ipod in, you should have sound.
Now you have 2 choices, the cable is short as hell now so you can either extend it with a male to female extension cable out the bottom of the dash somewhere, or cut the end off the cable and wire it into the factory aux input jack.
Old 05-03-2008, 08:05 PM   #23 (permalink)
fg2!kid's Avatar
エリク eric
ok i have the plug in the secound pic i guess ill make another trip to radioshak and get two of the other plugs
is it ok to put the right front and right rear speaker wires together but while keeping the + and - apart and doing the same with the left
Old 05-03-2008, 10:26 PM   #24 (permalink)
fg2!kid's Avatar
エリク eric
its not working no sound
fuse #35 is good
ok well i got every thing hookd up minus the switch for the amp but i dont see why i need a switch for the amp i check with my DMM and the amp has source voltage with no key in the ignition so its hot at all times whats the deal ?
Old 05-04-2008, 02:41 PM   #25 (permalink)
fg2!kid's Avatar
エリク eric
Old 05-04-2008, 02:53 PM   #26 (permalink)
Ich liebe Deutschland
splew's Avatar
Andrew
Uhh... this might sound stupid but why the hell do you want to ditch your factory system to play your ipod? Why don't you just go to radio shack ( or and electronics store) and buy a double male end headphone jack and plug you ipod into the auxiliary port of your sound system (thats what I do and it sounds great). Or you could go the fancy route and get honda's ipod adapter. I think the adapter will even allow you to control the ipod via the steering wheel controls but i'm not sure.
splew is offline   Reply With Quote
Old 05-04-2008, 03:10 PM   #27 (permalink)
fg2!kid's Avatar
エリク eric
if i am going to use my i pod i know ill never need the radio and ithink it would look cool too and have some carbon fiber where the navi screen would be
Old 05-04-2008, 03:30 PM   #28 (permalink)
splew's Avatar
Andrew
Oh, okay, if thats what you want to do then that sounds cool, but you might want to think about that a little before you do it. You never know when you might want to listen to a cd. Also you might want the radio for listening to traffic reports or if you want to get a satellite radio. If you have alredy thought all that through then it sounds like a cool idea but if not you might regret it.
Old 05-04-2008, 03:56 PM   #29 (permalink)
fg2!kid's Avatar
エリク eric
hmm well i tryed to make better connections but still no sound can some one shed some light on this switch for the stock amp i need to make
Old 05-04-2008, 04:10 PM   #30 (permalink)
fg2!kid's Avatar
エリク eric
i checked the amp power wire with ignition on and it has 14.30 volts
switch? why ?
Old 05-04-2008, 04:35 PM   #31 (permalink)
fg2!kid's Avatar
エリク eric
MUAHAHAHAHAHAH its alive !!!!
got it to work!!!! all the answers i needed were right in this thread reading owens me hahah sweet ...
Old 05-04-2008, 05:37 PM   #32 (permalink)
volvo9's Avatar
Andrew
Awesome, good work!
Found another picture on my computer of the wires for the aux in jack. I don't have anything labeled but here is a picture of the wires you need.
The yellow and the green are the left and right, but I don't know what order. If you really want to figure it out you can but I don't really think it'll mater since you won't have balance or anything.
The brown wire is the ground wire, it's not hooked up yet in the picture but you can see the bare wire where I stripped back the insulation and the wire next to it waiting to be connected.
I used rca jacks to connect it to the aux in on my z2, but you can just cut the end off of the cable you are using to connect it to your ipod.
Old 05-04-2008, 06:31 PM   #33 (permalink)
fg2!kid's Avatar
エリク eric
ok thanks i think iam just going to leave it the way i have it set up i am going to order the navi cover kit thing from honda tomarrow when i get the carbonfiber on ill take pics and post them up
Old 05-04-2008, 06:46 PM   #34 (permalink)
fg2!kid's Avatar
エリク eric
after i cleaned up put all the panels back on closed the doors on the car and hit the botton on my key to lock the car it didnt work so i checkd to make sure the doors were closed all the way and they are the trunk button does not work eather i also tryed my spear key and it still didnt work
....crap .... i used my key a few times to lock the car when the radio was out and it worked fine
also when i shut the car off at idle the rpm neadle does not go down to zero hahahh it stays up at what rpm i shut the car off at
Old 05-04-2008, 08:39 PM   #35 (permalink)
volvo9's Avatar
Andrew
Don't worry,you just blew a fuse. I think it's going to be one under the hood, don't remember which one but it's for the accessories. If you still had your stock radio in then you'd noice it didn't work either.
Old 05-04-2008, 11:15 PM   #36 (permalink)
SkunkSpray's Avatar
Well I just bought this deck
Alpine Electronics of America, Inc. - iDA-X200
Its Ipod only no cd's unless you add a changer, Hooked up my sirius too it and my Ipod what more could you need lol. Lotsa options and SQ is great.
Might be something to look at if ya wanna go just Ipod.
SkunkSpray is offline   Reply With Quote
Old 05-05-2008, 12:44 AM   #37 (permalink)
fg2!kid's Avatar
エリク eric
yup it was a fuse in the under the hood fuse box that little basterd !! it was a 10amp fuse with the label "back up" every thing works now
thanks everyone !!!
Old 05-08-2008, 11:13 PM   #38 (permalink)
fg2!kid's Avatar
エリク eric
update first post
Old 05-09-2008, 12:48 AM   #39 (permalink)
Kill Your Self Krew
Zeuceone's Avatar
Everyone always blows that backup fuse and can't find it. Lol
is Missy a squirter?
http://killyourself1.myminicity.com/tra build my city.
Old 05-09-2008, 02:09 AM   #40 (permalink)
fg2!kid's Avatar
エリク eric
it was the secound fuse i looked at
My Radio Locked! How to Retrieve Your Radio Code! jonlingat I.C.E., Electrical, Security, & Navigation 10 06-02-2008 01:42 PM
Ipod integration with stock radio control and display grbrjdawg I.C.E., Electrical, Security, & Navigation 34 05-22-2008 08:05 AM
I'm new to Ipod....your opinions on the Honda Ipod car-link?? spear85 Technology 17 10-13-2006 04:30 PM
2006 Civic LX Radio with XM or Sirus Radio TiVoNinja I.C.E., Electrical, Security, & Navigation 3 06-19-2006 10:52 AM
