Audio Install Help?
I need help?
I have an amp/cap/receiver/upgraded speakers. Trying to do a full switch in Honda LX 08. I know how to wire the 4 guage wiring kit and install the speakers. I will be using 3 pair rcas one for each channel, but how do i get speaker wire to the amp? Can i tap off the rear speakers? if so how? also for finding the remote wire how would i find the right one that turns on and off when car on? Also I have a rador with direct wire cable that I would like to install, were to a tap to get 12v power to turn in on? I couldnt find it in the fuse area? Thanks any help would be great! Last edited by twisted2corpse; 05-02-2008 at 02:36 PM. |
#2 (permalink) | |
As far as the remote turn on, run this directly from you reciever to the rear of your car. There is a DIY for how to hardwire the Valentine 1 in the DIY section. I would follow the same instructions for your radar. |
#3 (permalink) | |
the rador is not showing pictures for install. |
#6 (permalink) | |
thx |
there are some diy with pictures around think, but basically you just route new wire to your door speakers and tweeter up front then when they are connected you simply run the wire back(not next to the power cable by the way) to your amp and connect it there.
Then you can run the rca's from your amp up (and keep these away from the power wire too especially just run them up the passenger side underneath the plastic runners) to your head unit and just plug them in. heres one I found--- Front Speaker Install |
#8 (permalink) | |
#10 (permalink) |
you avoid the factory wiring all together. You run wire like you did for your power wire. Except dont run it next to your power wire and ya it runs basically from your amp to your speakers. And then the rca's run from your head unit to your amp.
The rca's send signals to your amp, then your amp takes them and amplifies them to send them through the speaker wire to your speakers. |
#11 (permalink) | |
#12 (permalink) |
If you want to tap into the factory wire, you can. However, I usually advice others just to bypass it altogether and run wire to the speaker directly from the amp.
Do what you want with the x-over. I put mine under the seat when I had passives. Just do what works for you. There's not wrong place to put them, really. As long as they're inside your car, you'll be fine. ![]() |
#13 (permalink) | |
and the receiver when i get the harness i wont need to wire the speakers since be running new wires right? thanks |
#15 (permalink) |
ok I think i can do this install now. as for the power wire keep that away from the others on one side. And the rcas, remote wire, speaker wires on other side. Were did you do the wires? Also for the Remote were did you tap into to get it. I just dont want amp staying on all the time. and the receiver when i get the harness i wont need to wire the speakers since be running new wires right? thanks
| Honest Audio Install Place in OC? | DrR10n | I.C.E., Electrical, Security, & Navigation | 8 | 05-22-2007 12:11 AM |
| audio install question | bumgardnerlx | I.C.E., Electrical, Security, & Navigation | 7 | 11-25-2006 12:20 PM |
| Questions about audio install..... | nuked99 | I.C.E., Electrical, Security, & Navigation | 14 | 10-02-2006 11:20 PM |
| My Audio Install | CNUco2007 | I.C.E., Electrical, Security, & Navigation | 10 | 09-13-2006 08:59 PM |
| install the audio controls | gabip | Do It Yourself Articles | 1 | 03-11-2006 08:47 AM |
