Old 04-12-2008, 07:23 PM   #1 (permalink)
ATL Squad# 24 \o/
senfinger's Avatar
Stephen
Problems Installing Avic-D3 and NEED HELP NOW...
Everything is working great but on AC-2 (Ignition switch) and cranked I hear a hissing noise through all of my speakers. I used the OEM AMP with Whiterice's RCA to D3 solution to use the stock amp. I have been working on this for 12 hours now. It still hisses even when I turn the radio off. The only time it doesn't is on AC-1 the amp still works and everything sounds the way I wish AC-2 and cranked would sound... PLEASE HELP if you have anything to add. I have re-wired everything twice.
Thanks,
Stephen
THERE WERE 2 PEOPLE ON THE MAIN WHITERICE MOD THREAD w/ the same issues and no fix came to light.
D.I.Y. the long-awaited amp integration harness by Whiterice!
senfinger is offline
Old 04-12-2008, 07:26 PM   #2 (permalink)
ATL Squad# 24 \o/
senfinger's Avatar
Stephen
I have installed the D3 in a STI and a Mustang GT w/a premium stereo utilizing the stock amps with no issues.
Thanks in advanced for any help!
Old 04-12-2008, 08:59 PM   #3 (permalink)
ATL Squad# 24 \o/
senfinger's Avatar
Stephen
Yep, so it only hisses when it's in the on position but not when it's running on accessory.
I may install a little switch in the little plastic piece that pops out under the dash radio piece to turn off and on the amp when I'm not listening or take it to best buy tomorrow. I was hoping to hear some guidance before taking it to the geek squad (Never had to do that) = P
OR no tweets or sub normal /amp bypass ikes...
Old 04-12-2008, 09:11 PM   #4 (permalink)
ct20's Avatar
my advice would be to NOT take it to best buy...Too many horror stories for me to ever take anything there...this is just my opinion, maybe you know someone there. If not, my next piece of advice is to take it to a pro shop to have someone who knows what they are doing to have a look to see what the problem is. Not trying to be a smart a$$, just giving you advice on what I have seen/read.
ct20 is offline
Old 04-12-2008, 09:14 PM   #5 (permalink)
ATL Squad# 24 \o/
senfinger's Avatar
Stephen
Nope. I understand what your are saying; they twistie cap everything he he = P
Old 04-12-2008, 09:26 PM   #6 (permalink)
ATL Squad# 24 \o/
senfinger's Avatar
Stephen
Something just dawned on me lol would running the oem amp wire from a constant 12 instead of my current setup over the Avic-D3 Amp Remote Line make any difference in sound? (Since the D3 is impossible to completely turn off)
Just wondering trying to think of everything... Also, the sound doesn't go up and down from revving which leads me to believe the ground is more then good (On the chassis behind the radio)
Any ideas = P
Old 04-12-2008, 10:28 PM   #7 (permalink)
ATL Squad# 24 \o/
senfinger's Avatar
Stephen
1 hour bump! = P Any ideas>...
Anybody else with the Whiterice setup and 0 hissing issues?
Thanks!
Old 04-13-2008, 12:31 AM   #8 (permalink)
ATL Squad# 24 \o/
senfinger's Avatar
Stephen
Well... I'll wait till tomorrow- I'm done with it for tonight! Hopefully some night members can help me out and or give me some ideas- Thanks
Old 04-13-2008, 10:15 AM   #9 (permalink)
ATL Squad# 24 \o/
senfinger's Avatar
Stephen
I guess no one has any ideas... Looks like there is another person with the same issue above; even when going back to stock. I'm afraid this mod may have caused issues to the stock amp. About to head out and install the oem radio to see what happens.
Originally Posted by DrR10n View Post
ok so i had an avic-d3 in my si and decided i didnt want it anymore so i put the factory stero back in...now the speakers it hiss a little when the engine is running or the ignition is in the second position. i had the same issue when the avic was installed but it was much worse. im no audio pro so does anyone have any ideas on how to fix it? thanks!
Old 04-13-2008, 12:22 PM   #10 (permalink)
IIIII's Avatar
i just installed the Pioneer Z2 on friday and i am also getting a hissing noise when in ac2 but nothing in ac1. And i am using whiterices rca speaker cable mod.
IIIII is offline
Old 04-13-2008, 12:50 PM   #11 (permalink)
ATL Squad# 24 \o/
senfinger's Avatar
Stephen
I talked with a guy a circuit city. Going in at 3 they are going to take a look at it. They said they should be able to fix it or make it less noticeable. The also are going to put in my steering wheel PAC SWI... YEAH...
Will update this post when I get back. Hope to hear some good news. It scares me when a 100 something people look and don't comment LOL who knows when dealing with a D3 on a Civic OEM Amp premium system they all are very different. (And I trust my track record of about 5-6 flawless installs) he he he.
Old 04-13-2008, 10:48 PM   #12 (permalink)
ATL Squad# 24 \o/
senfinger's Avatar
Stephen
Everything is good now!!! Circuit City put in a a small (Golf ball sized) ground loop insulator!!! Absolutely no hissing at all and 0000000 sound problems!!! So nothing is wrong with the OEM Amp from this mod it work perfect!!!
No issues and all speakers are firing! YEAH!!! lol
Old 04-14-2008, 09:46 AM   #13 (permalink)
IIIII's Avatar
can you give me more info on this? What model are they using and how is it installed? I need to get this done also.
IIIII is offline
Old 04-14-2008, 09:49 AM   #14 (permalink)
ct20's Avatar
Glad they got everything taken care of...Sounds like the ground loop isolator did the trick...congrats...
ct20 is offline
Old 04-14-2008, 04:44 PM   #15 (permalink)
ATL Squad# 24 \o/
senfinger's Avatar
Stephen
It is their (Circuit City's) smallest ground loop isolator. (There are tons of different makes and models outside of CC.
Also... Please make sure that you have the same issues.
1) Whiterice's mod with a fact/oem amp
2) No buzzing on AC-1
3) Buzzing starts on AC-2
4) Buzzing doesn't whine when cranked and pressing down on the accel.
Should be the fix for the above issue! Mine is perfect and sounded badass on the way into work. So happy now = P
Let me know if you need anything else!
Old 04-14-2008, 04:47 PM   #16 (permalink)
ATL Squad# 24 \o/
senfinger's Avatar
Stephen
I know thanks! I was pissed until it was fixed that easy- Nothing like clear sound minus the hiss LOL
Old 04-14-2008, 04:51 PM   #17 (permalink)
IIIII's Avatar
Yep, exact same issue....going to see about picking up the parts today. One more question did they install 2 Gound Loop Isolators? 1 for the front set of RCA's and 1 for the rear RCA's?
IIIII is offline
Old 04-14-2008, 05:00 PM   #18 (permalink)
ATL Squad# 24 \o/
senfinger's Avatar
Stephen
I believe they did both sets. I was watching like a hawk but more on a bad install/and or them scratching the inside of my car lol (I usually do all of my own work) lol = P
Old 04-14-2008, 09:53 PM   #19 (permalink)
IIIII's Avatar
IT WORKED!
Picked up 2 Tsunami Ground Loop Isolators from Circuit City 14.99 each, installed both and no more white noise/buzzing.....awesome. Now i dont have a headache when i get to my destination! And the sound is great now!
IIIII is offline
Old 04-14-2008, 11:04 PM   #20 (permalink)
ATL Squad# 24 \o/
senfinger's Avatar
Stephen
Awesome dude glad I could help some peeps out!!! = P
installing avic d3 tomorrow, in need of some help! 1sole I.C.E., Electrical, Security, & Navigation 17 12-03-2007 07:18 AM
So im installing my avic d3 in my ex right now and i need some help 1sole Do It Yourself Articles 6 11-16-2007 11:54 AM
Avic N3 vs. Avic Z1 vs. Avic D3 07blackonblack I.C.E., Electrical, Security, & Navigation 8 08-20-2007 05:52 PM
For those with the AVIC-D3... nastynogales I.C.E., Electrical, Security, & Navigation 6 04-27-2007 10:13 AM
Installing a Pioneer AVIC-D3 in 07 Si Sedan BotoBoi808 I.C.E., Electrical, Security, & Navigation 1 04-05-2007 04:46 AM
