well i dont know why u would need the location for that wire, it probably comes off the main harness. but i know that voltage is going to be the same as the batteries volate which usually is around 12v. explain what your trying to do and i might be able to help you.
Left front window(up/down) Yel(4dr) or Red(2dr)-Green in Driver window switch in door
Right front window(up/down) Orange-Brown in Drivers kick, door harness Left rear window(up/down) Green-Purple in Drivers kick, door harness Right rear window(up/down Lt.Blue-Red in Divers kick, door harness Give me a second to find out Polarity |
#7 (permalink) | |
are the wires the same for the coupe? |
The only difference in the two door and four is the front left wire as posted above. The first color will be the up wire and the second color will be the down wire. When the window goes up, the down wire rest at ground and and when the window goes down the up wire rest at ground. This is a rev polarity set up.
| MSD Nitrous window Switch | GORDATA | Forced Induction And Nitrous | 7 | 08-29-2007 07:58 AM |
| Throttle Positioning Switch Location | saskwatch420 | Forced Induction And Nitrous | 2 | 08-17-2007 08:54 PM |
| Window Switch Causing Speakers to snap / pop | cation | Mechanical Problems & Technical Chat | 1 | 08-15-2007 08:37 AM |
