So ...
I took my radio out (not unplugged, just out of the dash) and checked all of the wires and none of them appear to be a remote turn on. I paid special attention to all of the blue wires. The light blue wire had power to it even when the power was turned off. So my next question is ... Does anybody know a good spot to get accessory power from? |
This thread might help,
Audio Wire Diagram
Not sure myself, but you can use one of these:
http://cgi.ebay.com/PAC-TR-4-LOW-VOL...QQcmdZViewItem One wire to ground, one to the rear speaker, one to 12v and one to amp. I have one, let me know if you're interested. |
#13 (permalink) |
Moderator
problem is...well with NAVI...the HU never goes off!!
even if u turn the audio off..u will still get a signal...that sucks cuz ur amp stays on and u get that low hissing sound...and believe me i've tried everything from, clean sweep, lc8, all noise reduction thing recommended...none work. it stays on and provides a signal cuz the navi needs to speek...even if it's not in use....go figure... for the regular head unit i don't know if it will be different... i wish there was a way to turn off the amp when audio power was off....unfortunately it looks like there is not... if anyone figures this out be sure to let me know...i'll monitor this thread also.
#14 (permalink) | |
Can't really see it because it's small and my camera sucks. But the red portion on the switch says ON and black says OFF. Handy and compact. Would be perfect for your situation because you can hide it very easily. ![]()
#15 (permalink) | |
#16 (permalink) |
Easiest place for me to tap into accessory power was into the power line of the 2nd cig lighter that's in the center console. I tapped into it underneath about where the cup holders are. so essentially you have to take the center console apart. not very hard, take your time.
I used that tapped power wire to power my trigger, which in turn triggers my amp to turn on. If you're using the stock head unit I'd suggest buying an audio control LC8 or JL audio cleansweep. I'm having underpowering-the-amp issues by tapping into a speaker line and sharing the signal. |
#18 (permalink) |
Pulling the stock HU out really isn't hard! I was very very afraid of pulling my brand new car apart, but I didin't break anything, No harm Done! It's super easy to do.
Just tap into the Purple Wire w/ Silver Stripe on main radio harness, w/ a T-Tap. I used a multimeter to make sure it's the amp turn on. |
#19 (permalink) | |
#20 (permalink) |
Someone please correct me if I'm wrong. But I don't believe you can get to it from the panel under the HU.
Do a search, but I've seen a guy on the forums also finding that wire somewhere in the fuse box and tapping from there, that might also be an option. |
| DIY: Turn Signal Mirrors | CameronJr9 | Lighting | 124 | 09-22-2008 09:41 AM |
| Help, Amp wire from stock deck | mykicks007 | I.C.E., Electrical, Security, & Navigation | 14 | 07-11-2008 12:21 AM |
| buzzing and turn signal sound in stereo with amp | 06TechCivic | I.C.E., Electrical, Security, & Navigation | 14 | 06-09-2006 09:01 AM |
| AMP IT UP CARSHOW | PICHY | North-East | 0 | 09-22-2005 05:23 PM |
