Old 02-28-2008, 10:51 PM   #1 (permalink)
Gas Is Expensive's Avatar
Mitch
LOC Gain Settings
For those of you using a converter, how did you go about setting all of the levels? Did you just set the LOC gains to the max, and then adjust the amp gains from there, or what?
Gas Is Expensive is offline   Reply With Quote
Old 02-29-2008, 12:31 PM   #2 (permalink)
Yes. LOC Gains are normally kept maxed out.
lostdaytomorrow is offline   Reply With Quote
Old 02-29-2008, 09:58 PM   #3 (permalink)
Mitch
Thanks
Old 02-29-2008, 10:21 PM   #4 (permalink)
Tronixx's Avatar
Yep for whatever reason, I have to have the gain turned up on my LOC pretty high, about 3/4. In other cars I've had it wasn't like this, but I haven't noticed it hurting the sound quality or anything like that so far to have it turned up. When turned down I can barely hear my sub.
Tronixx is offline   Reply With Quote
Old 03-02-2008, 12:20 AM   #5 (permalink)
lensam69's Avatar
I swear to god, this has got to be my biggest pet peeve....
You can do it by ear, but the correct way to do it is with a multimeter.
If you have your amp's manual handy, take a look at what the input sensitivity voltage is. This will be given as a range (eg. 0.5V - 5V). Your target will be in the middle of this range (3V in this example).
Follow the procedure detailed in this page:
How to set the gains
Instead of measuring the amp's output, you'll be measuring the LOC output (with the amp unplugged) and your target voltage would be somewhere in the middle of that previously mentioned range (remember to look up your particular amp specs).
If that's too much, you can alway do the good ol' 3/4 volume by ear setup.
lensam69 is offline   Reply With Quote
Old 03-02-2008, 04:14 AM   #6 (permalink)
Mitch
Well, the gain on my amp is clearly labeled 0.5V - 5V. So, to clarify, you're saying that I should set the LOC's gains to 3V and then adjust my amplifier's gain from there?
Old 03-02-2008, 12:22 PM   #7 (permalink)
If that's what he's saying, then he has no idea what he's talking about. But, I don't think that's what he's saying. He is referring to how to set the amplifier's gain in that post.
Old 03-02-2008, 12:34 PM   #8 (permalink)
Mitch
Well then he STILL has no clue what he's saying, because he completely failed to give an appropriate response to the question I was asking.
I want to know how to set the line-out converter's gains, not the amp. Read before responding please. Thanks.
Old 03-02-2008, 12:37 PM   #9 (permalink)
Bulli Kid's Avatar
GReg
i set my LOC 50/50
Bulli Kid is offline   Reply With Quote
Old 03-02-2008, 12:46 PM   #10 (permalink)
Mitch
OK, so it sounds like nobody really knows how to properly set the gains on a line-out converter.
Old 03-03-2008, 01:25 AM   #11 (permalink)
lensam69's Avatar
I'm here...
I try to stay away from the computer on weekends.
The gains on the LOC are there to make it easier to match their output to the input sensitivity of the amp.
The procedure (as described on the link) is exactly the same as if you were setting the gain control for the amp. Calculate your target voltage (I like to go half the range of the amp's input because it gives you headroom), defeat all equaliztion in the head unit, use the appropriate test tone depending on what channel you're setting up. (low 80Hz for subs, mid 1000Hz for components), and adjust until you reach your target!
I do believe I answered the original question.
It's the same procedure for any device along the audio chain.
First you set your LOC's then you set your amps.
Hope that clarifies it.
LostDay: You don't max something out without looking at the input requirements at the other end.
Wiring LOC? 08CivicSiGG I.C.E., Electrical, Security, & Navigation 3 08-23-2008 02:26 AM
LOC Install question with non-premium sound redguym I.C.E., Electrical, Security, & Navigation 15 02-28-2008 08:23 PM
Factory Headunit + LOC + Aftermarket Amps & Speakers pdrizzle I.C.E., Electrical, Security, & Navigation 7 01-28-2007 01:51 AM
Amp settings help, please! SiC17 I.C.E., Electrical, Security, & Navigation 8 09-16-2006 12:00 AM
Aftermarket Speakers, Amp, LOC? HELP jc21 I.C.E., Electrical, Security, & Navigation 4 07-08-2006 11:31 PM
