Install Guide: TWM Short Shift Kit 2006+ Honda Civic / Civic Si
use this DIY and remove the entire center console. im sure that there has to be a wire attached to it. |
#6 (permalink) | |
Ok next question, now that ive found the wire. Is there any way to bypass the parking brake wire so that my screen will still play? Ive read another thread that says you can just ground the two wires to negative chassi. How correct is this or is there another suitable solution?
it depends what unit you are using. alot of them you can just ground the wire that is supposed to go to the parking brake.
if your using a pioneer unit...this site will help www.avic411.com |
#9 (permalink) | |
| *Merged* Parking brake handle issues/replacement | MyFordAtenzaSucks | Garage | 147 | 09-19-2008 09:24 PM |
| Accidently driving Civic EX with parking brake on | jyong11363 | Suspension and Brakes | 12 | 06-01-2007 08:41 PM |
| Parking without parking brake (AT) | amirh | Mechanical Problems & Technical Chat | 4 | 12-20-2006 11:12 PM |
| Brakes (06' Si) Parts-list: | Torredo | Suspension and Brakes | 3 | 12-07-2006 01:59 AM |
| Anyone with parking brake problems? | Silver06 | Garage | 7 | 12-16-2005 01:18 AM |
