Old 08-14-2007, 07:31 PM   #1 (permalink)
NewYorkJon's Avatar
Jon
Question Sub-comparsion question
I have 2 12" JL Audio W1's with a JL Audio 400 watt amp
I was thinking about selling them and buying 1 10" Kicker L5, I just wanted to know if the Kicker SUB will sound better then the 2 JL Audio Subs.
I am also considering selling the 2 12" Subs, because of the weight issue.
Any info is appreciated
NewYorkJon is offline   Reply With Quote
Old 08-14-2007, 09:09 PM   #2 (permalink)
NewYorkJon's Avatar
Jon
-bump-
Old 08-14-2007, 11:15 PM   #3 (permalink)
NewYorkJon's Avatar
Jon
Anyone know if it is a better set-up?
Old 08-15-2007, 12:01 AM   #4 (permalink)
Anthony
This is a personal taste issue. My personal taste due to running a S12L7 with 700 watts is that Kicker sucks. Just my opinion. I didn't like the sound quality and spl was definitely not there.
I would say sell the 2 W1's and buy a good quality sub designed for you taste.
If your into SQ I can't help you with a recommendation.
If your into SPL go to Resonant Engineering. www.reaudio.com
I would recommend the sx series as it is resonably priced and is loud as hell.
But th RE series is still better than an L5 in my opinion.
2007SiSedan is offline   Reply With Quote
Old 08-15-2007, 12:02 AM   #5 (permalink)
simomo's Avatar
Jonathan
go with the JL subs man....better quality and better sound...and the L5 takes a lot of air space so you will not be saving on weight too much maybe only a pound or two...
simomo is offline   Reply With Quote
Old 08-15-2007, 12:34 AM   #6 (permalink)
NewYorkJon's Avatar
Jon
....Even though the kicker has more power and it is only one sub, and it is lighter.
BTW: I just had my JL Audio component speakers installed with a kicker 4-channel amp and it sounds great.
Old 08-15-2007, 05:31 PM   #7 (permalink)
bikinpunk's Avatar
Erin
Just use the "right" box. That matters more than anything.
bikinpunk is online now   Reply With Quote
Old 08-15-2007, 07:45 PM   #8 (permalink)
get a w3. problem solved. i have two =) and it out bumps an L5.
amigochief is offline   Reply With Quote
Old 08-15-2007, 10:18 PM   #9 (permalink)
JL is just an overpriced brand!
What are you looking to accomplish? Higher SPL? more SQ? SQL? Most of the time it isn't the woofer, its the enclosure. What type of box are you running? Ported? Sealed? What type of port? Slot or round?
I had 15 inch Pyramid Super Blue woofers be louder than most at some DB comps. Everyone is always like WTF! Then you have to explain to them box design and how important maintaining voltage into the amps is.
But if it were me, I'd sell the JL's and buy 1 Image dynamics 12" IDQ.
achapman is offline   Reply With Quote
Old 08-16-2007, 12:15 AM   #10 (permalink)
NewYorkJon's Avatar
Jon
They are 2 12" JL Audio W1's in a sealed box. The Amp is a 400 Watts
I was thinking of buying the 1 10" Kicker L5 because it weighs less and it has alittle more power then the 2 W1's
Old 08-16-2007, 01:17 PM   #11 (permalink)
So you want it to sound better or louder?
Is the box mono? Or 2 separate chambers?
Old 08-16-2007, 06:00 PM   #12 (permalink)
bikinpunk's Avatar
Erin
I can't stress how important the box is, so again:
Make sure you use the right enclosure.
So...I think the big question here is what about your current setup do you not like?
A few things to think about are space (one sub takes up much less than 2), cost, what you're looking to achieve, and the likelihood that you'll want to upgrade later.
I try to get what I think will keep me happy for a long time so I won't wind up spending more money later.
Old 08-16-2007, 08:48 PM   #13 (permalink)
NewYorkJon's Avatar
Jon
It sounds good, I just wanted to get something that sounds just as good, but weighs less.
rev limiter question 20civic07 Civic SI 27 07-25-2007 04:26 PM
Last question about 18" HFP on non-si + Tire PSI question amdhunter Wheel And Tire Upgrades 2 06-26-2007 05:11 PM
help with a question about getting a wing for my EX Filippelli Inside and Out 7 05-09-2007 11:08 PM
Quick ground clearance question BionicElite Suspension and Brakes 0 04-24-2007 11:06 PM
