Old 07-28-2007, 12:49 AM   #1 (permalink)
Options to send bass from trunk forward into Cabin?
Hi folks,
I'm going to install a sub in my trunk. You guys have any recommendations to deliver the sound from the trunk to the cabin? I looked at the backseat, it has a good layer of metal on the backside. I thought about removing rear fills, but I carry passengers on a regular basis. Any suggestions? Thanks.
jjohan35 is offline   Reply With Quote
Old 07-28-2007, 10:23 AM   #2 (permalink)
bikinpunk's Avatar
Erin
3 things:
1. Remove rear speakers so the pressure in the trunk can escape.
2. Deaden your trunk. That will keep the pressure from leaking out of your trunk or causing flex (which causes reduction in spl).
3. Put your subwoofer right up next to your trunk lid, facing the trunk lid if you can. This will help eliminate any wave cancellation since the backwaves and forward waves will be overlapping and "together" rather than separated and canceling each other.
bikinpunk is online now   Reply With Quote
Old 07-28-2007, 10:33 AM   #3 (permalink)
Englishe30's Avatar
Mark
Port your trunk perhaps
Englishe30 is offline   Reply With Quote
Old 07-28-2007, 01:45 PM   #4 (permalink)
Anthony
jjohan35, do you have a factory sub on the rear deck?
If so, remove the factory sub if you want high spl. No need to remove the rear fill speakers. If you are going for high SPL then I would recommend dynomatting the trunk. I have one 10" in mine and have no rattling. And I still have my factory sub in tact. Sounds extremely nice. The 10" gives enough rumble to fill the cabin and match the factory mids and highs.
In a sedan or coupe for that matter, I would only face the sub to the rear of the trunk. Allow a minimum of 6" in between the rear of the trunk and the face of the sub.
Another way of testing is to buy a small prefab enclosure with a single ten for $100 bucks as a test sub. Use that enclosure to test where you want to face the sub. In my sedan I got a cleaner response from facing the sub to the rear.
2007SiSedan is offline   Reply With Quote
Old 07-28-2007, 03:07 PM   #5 (permalink)
bikinpunk's Avatar
Erin
Do you mean Maximum? Otherwise, the further away from the trunk the subwoofer is, the more potential for cancelation there will be.
Old 07-28-2007, 04:06 PM   #6 (permalink)
Anthony
I have never seen a rear facing sub cancel in a Sedan or Coupe or Hatchback for that matter. Maybe I should rephrase that, if you are running a ported enclosure you want the port a minimum of 6" from the wall to maximize the port. Most peeps put the subs and port on the same plane.
Old 07-28-2007, 04:14 PM   #7 (permalink)
Anthony
http://www.clubknowledge.com/mr_b/2.htm
Old 07-28-2007, 04:20 PM   #8 (permalink)
Anthony
Originally Posted by DYohn the12volt.com
It is a physical fact that lower frequencies need to travel farther to acheive maximum SPL, so that moving a sub forward in the car and then facing it to the rear maximizes the cabin gain at lower frequencies. But do you have to do that? No. Put the woofers in your car and experiment. Move them around and see what sounds best.
Old 07-28-2007, 04:46 PM   #9 (permalink)
He drives an LX if I remember correctly.
Remove the rear fill speakers.
lush is offline   Reply With Quote
Old 07-28-2007, 04:52 PM   #10 (permalink)
bikinpunk's Avatar
Erin
A few things about that site:
I agree about the "rear fill" section. Unless you run 5.1 there's no reason to run rear speakers. Proper front-stage will trump all that ambient noise (I do mean noise) the rear speakers are playing.
Originally Posted by Mr. Brownstone
"Car audio stores jumped on the bandwagon and immediately sold you a speaker for every dip in your system, and a signal processor (eq) for every lump. An RTA was the best moneymaker in car audio since the 1F digital capacitor. We'll go there later. "
I agree.
"Placing your subwoofer enclosure in the trunk of your vehicle facing the rear of the vehicle minimizes on cancellation. When 2 independent waves meet, they cancel or sum their amplitude depending upon what phase they are in."
This is what I'm talking about.
Ideally, a flat response from 20Hz-20kHz would be desirable
Definately do not agree. An RTA is a useful tool to find out where your problem areas are in your car due to it's geometry, but leaving music with a flat response isn't "ideal". Ideal would be what the listener likes.
__________________________________________________ ______________
Back on topic, this is what I was referring to as for cancellation:
Here's a good drawing to understand how sound waves travel and what causes cancellation (these are assuming rear facing subwoofer):
This picture shows a subwoofer box positioned further away from the rear of the trunk
See how those reflected waves don't match up with the waves being put out by the subwoofer? This is an out-of-phase system, and kills response.
This is a more nominal response:
The two waves are now in sync, giving a more in-phase response.
I've actually tested various positions with a pink noise track and laptop based RTA on a 1/24th scale. Every car's different, but the same principle applies.
Old 07-28-2007, 08:25 PM   #11 (permalink)
Yes I have an LX sedan. Thanks lush for the keen memory. I wish I could make my own hole in the rear deck.
I removed my rear fills when I had a two door celica back in the day since the backseats were pretty much non existent. But I'm driving passengers regularly with the Civic. I don't think removing rear fill is an option at this point. I have to carpool with employees.
I guess the discussion of subwoofer placement isn't that much an issue since I'm planning to get the custom fiberglass enclosure from audiosolutions due to space issues.
Old 07-29-2007, 10:32 AM   #12 (permalink)
I'm not finding this to be a big issue after all. With an SPL meter sitting on the center console, I measured a 6db increase at 40Hz with the passenger-side rear seat folded down. My sub has more than enough output to make up for this difference and I have a remote sub-level control up front (EX sedan with factory head unit).
4dr_bob is offline   Reply With Quote
Old 07-29-2007, 10:47 AM   #13 (permalink)
RPM
RPM's Avatar
Bobby
Heres what was done to my Trunk and yes it is ported.
RPM is offline   Reply With Quote
Old 07-29-2007, 12:41 PM   #14 (permalink)
You can take a air saw/dremel to your rear deck if you would like. It's thin, maleable metal for the most part. I've done it on many cars looking for the same option. Don't make it too big - it could flaw the frequency the port is tuned too.
Old 07-29-2007, 01:01 PM   #15 (permalink)
bikinpunk's Avatar
Erin
RPM, that's a clean install. Nice work.
Did you do it yourself or have a shop do it? I'd like to see process pics if you have them.
Old 07-29-2007, 01:57 PM   #16 (permalink)
RPM
RPM's Avatar
Bobby
I had a good friend of mine do it for me he's done systems for me in the past in my other cars.we took out the spare tire out and used that space for storage so i can put my junk in my trunk haha..but ya all kidding aside its a clean install and it pounds hard and sounds very clean & crisp.
Old 08-28-2007, 11:36 PM   #17 (permalink)
CJ
Instead of putting a sub in the trunk, get a shallow mount sub from a brand such as Pioneer or Kicker and putting it either in your backseat or under your seats.
LeezYy BabYy is offline   Reply With Quote
Old 08-29-2007, 09:08 AM   #18 (permalink)
bikinpunk's Avatar
Erin
That's a good idea. With these type subs being easily available, it's at least worth checking into.
