Nav OBDII Access Question
So I am starting my Hack the Nav project. One of the projects I will attempt is a screen that shows you the parameters you select, like Coolant Temperature, from the Can Bus/OBDII stream. I noticed in the diagnostic screen that there seems to be some tire calibration settings. I'm hoping this means that the Nav receives the OBDII stream, as that would make my life much much easier. Has anyone gotten that far into the system to know if we would have access to something like that. And if you did do you know what model the gateway chip is?
-Mike 07 SSIP http://www.CygnusX1.net/Civic |
![]() Join Date: Feb 2006
Back and Forth Forever
I believe you're the first person to attempt anything like this. We have a few software gurus, but no one has been brave enough to try re-programming. While you're in there rooting around, see if you can figure out a way for the Navi to display RDS song information from radio stations.
I'm definitely subscribed for more updates.
#3 (permalink) | |
The nav units probably don't have any signal or source from the OBDII system. I would think it might be possible if there was a way to interface it with the nav through a direct input. |
#5 (permalink) | |
| Basic Wiring Question of OEM NAV in Non-Nav Si | yodaboy | I.C.E., Electrical, Security, & Navigation | 2 | 07-11-2007 11:45 AM |
| Hi guys, quick nav system vs. sunlight question. | Order | I.C.E., Electrical, Security, & Navigation | 10 | 05-11-2007 09:43 AM |
| NEED HELP! Factory Nav Owners Only! | CaliGuy | I.C.E., Electrical, Security, & Navigation | 16 | 04-04-2007 06:42 PM |
| How NSA access was built into Windows - security issue | webby | Technology | 4 | 01-14-2007 01:00 PM |
| NAV Question | heffergm | Civic SI | 12 | 12-13-2006 03:35 PM |
