Old 07-09-2007, 12:28 PM   #1 (permalink)
Basic Wiring Question of OEM NAV in Non-Nav Si
I just had a "simple" question regarding the installation of a OEM Nav into a Non-Nav Si.....
If I don't care about the whole microphone/steering wheel/voice setup (as I don't even use it in my wife's Nav Civic - Yes Civic family), will the OEM nav just plug in and play? I figure the power, speakers, and basic steering controls (volume and channel) still work the same
I've got the GPS antenna, headunit, and bezel/brackets ready to go, but just wanted to make sure that Honda didn't swap hot wires in the two different wiring harnesses (would be an expensive mistake). I guess the more obvious question is if all the connectors are the same shape/size/configuration as well?
yodaboy is offline
Old 07-09-2007, 03:31 PM   #2 (permalink)
sk33ny's Avatar
Aaron
arnt they different harnesses?
Edit:
He installs a new harness.
DIY:Si Navi RetroFit...
(Second link is the actual install)
sk33ny is offline
Old 07-11-2007, 10:45 AM   #3 (permalink)
NIGHTHAWKSI's Avatar
Ian
its a differnt harness...it seems you do already have everything except for the navi instrument panel harness...
if you ge thtat it will all be plug and play...but be sure to set out a FULL day put the new harness in as it has some tough spots to get to.
NIGHTHAWKSI is offline
Tweeter Wiring Question Southsider I.C.E., Electrical, Security, & Navigation 6 05-04-2008 01:50 AM
Question on OEM fogs and mud guards... mattSi Civic SI 22 07-09-2007 01:46 PM
Audio Wiring Question CNUco2007 I.C.E., Electrical, Security, & Navigation 12 12-12-2006 07:31 AM
OEM rim question Sprecher Wheel And Tire Upgrades 3 09-26-2006 10:20 PM
OEM Intake question CZ-75 Civic SI 3 08-28-2006 07:27 PM
