Old 06-09-2007, 03:34 AM   #1 (permalink)
CRZYAZN's Avatar
Upgrading audio system in a LX Coupe
Hey, hows it goin eveyone?
First question is, does anyone know how much RMS the battery and alt can take before having to upgrade those components? Cuz, what I want to do is either run a Audiobahn A16000V Amp with Immortal 10" or Audiobahn 8000V with Eternal 10".
Secondly, for the speakers in the back, can I use the existing wiring or will I have to run aftermarket?
thnx, Lawrence
CRZYAZN is offline   Reply With Quote
Old 06-09-2007, 06:59 AM   #2 (permalink)
I ran 800w in my 1986 Toyota Camry with a stock alt and cheap batteries. I never had a problem concerning my electrical system. I suppose if your lights start dimming with every bass hit, you probably have a problem.
The rear stock speakers are fine with whatever it originally came wired with.
rawdawg is offline   Reply With Quote
Old 06-09-2007, 07:20 AM   #3 (permalink)
Why not just buy a capacitor and not worry as much about your battery and alt.?I ran something like 2000 watts RMS in my old car and never had a problem with diming lights and whatnot..I did have a half farad capacitor though.I would think that you could use the factory wiring unless you are pushing alot more power through them then you could get a larger gauge.
bossman is offline   Reply With Quote
Old 06-09-2007, 11:39 AM   #4 (permalink)
CRZYAZN's Avatar
ya, I kinda figured it may work with factory wiring, but the thing that baffes me is that the stock speakers are plug ins...so can I just cut the plug and re-wire it?? Also, reason why I worry bout the battery part is that the battery looks a lil small compared to traditional batterys.
Thanks Lawrence
Old 06-09-2007, 12:32 PM   #5 (permalink)
mike11202's Avatar
dude don't get audiobahn.. if your spending that kind of money on crap than u might as well spend the same amount on some quality stuff
whats your budget?
btw don't run past 1000rms watts off your stock alt
Audiobahn wont do the rated power anyway
mike11202 is offline   Reply With Quote
Old 06-09-2007, 12:34 PM   #6 (permalink)
mike11202's Avatar
You can keep stock wiring.. but if your going aftermarket speakers u will only need fronts ONLY
I have a 2007 lx coupe myself
Old 06-09-2007, 11:23 PM   #7 (permalink)
CRZYAZN's Avatar
well...to start I have an Ultimate T3-1000D amp that the company rates it at 1200RMS at 2 Ohn or 1000RMS at 4 ohm, but supposedly its underated to be 2600 RMS at 2 Ohm, and 1800RMS at 4 Ohm...my budget is around 400-450 with S&H. Ya, a buddy of mine is running an Audiobahn AW1006T and it sounds pretty good, but it was a Hatchback though...
Also, should rears give better sound cuz after I stuck an aftermarket HU, a lot of the sounds from the back.
Old 06-10-2007, 03:45 PM   #8 (permalink)
Alt. is 90 amps. It can probably handle anything from 800 watts and down.
lostdaytomorrow is offline   Reply With Quote
Old 06-10-2007, 09:25 PM   #9 (permalink)
mike11202's Avatar
^^ Yeah I'm running my type R 10" at 450rms and components at 200rms x 2
both amps are underated so i am guessing between 850-1100rms
the voltage drop is VERY minor it usually goes from 14.2 or 13.8 to 13.6
All on stock alt and optima D34 deep cycle battery
how much of a pig is your car? weight list webby Garage 20 05-01-2008 01:30 PM
New Civic Coupe LX - 140 CRAP SOUND SYSTEM :( Need help to change hondapower Civic Coupe And Sedan 30 10-16-2007 05:21 PM
8thCivic Meet - 4/28/07 - NY,NJ,PA,CT Qshooter151 North-East 727 05-01-2007 06:16 AM
8th Gen NY/NJ Meet- March 17th mohouse North-East 684 03-20-2007 07:41 PM
Audio Question...EX coupe Stereo to LX sedan PugManTerror I.C.E., Electrical, Security, & Navigation 12 10-06-2006 05:18 PM
