Old 05-23-2007, 02:20 PM   #1 (permalink)
Shaun
Speaker size/System questions in 07 Si Coupe
Does anyone know what size the Si Coupe speakers are? I had a 2002 Accord before the Civic and pulled my system out of it (6.5 alpine type-s speakers in front, 6X9 Alpine Type-R speakers in the back, 2 10 inch alpine subs powered by a v12 600 watt amp and a 240X4 kenwood amp for the speakers, i also have an alpine head unit). My main question is whether or not the speakers will fit and also if it there is a way to install a system with the stock head unit. Also does anyone have any pictures of the dash with an aftermarket head unit and dash kit installed? i really would like to see how it looks. Thanks
infamousmodi is offline   Reply With Quote
Old 05-23-2007, 02:27 PM   #2 (permalink)
CNUco2007's Avatar
Eric
6.5" speakers all around, i think the tweeters are 1", and the sub woofer is 8" :), yes you can run after market speakers off stock head unit. If you do a search for radio installs, you'll come up with quite a few :) Hope this helps.
CNUco2007 is offline   Reply With Quote
Old 05-23-2007, 07:52 PM   #3 (permalink)
If you'd like to use your amps with the stock head unit, all you will need is a Line Out Converter (LOC).
lostdaytomorrow is offline   Reply With Quote
Old 06-27-2007, 02:20 PM   #4 (permalink)
dominicanto17dr's Avatar
Ok. My question is if you use a LOC lets say for example you want to install aftermarket subs and an amp, wont you have to wire from the stock woofer? which means you dont get to use the stock woofer anymore cuz you wired it with the LOC? Does it go the same for the rear speakers if you want to add extra speakers and amps in the car?
dominicanto17dr is offline   Reply With Quote
how much of a pig is your car? weight list webby Garage 20 05-01-2008 01:30 PM
Looking to buy Civic coupe have some questions skippy911 Driving Experience 23 03-14-2007 11:50 PM
Few questions for people with 06 coupe EX's or Si's reelbigfish241 Mechanical Problems & Technical Chat 11 08-15-2006 07:51 AM
LX coupe questions SapphireRaven Civic Coupe And Sedan 8 07-15-2006 12:51 PM
Has anybody removed the rear speaker tray on a coupe? galaxycivic Do It Yourself Articles 6 05-20-2006 12:21 AM
