Old 05-17-2007, 01:33 PM   #1 (permalink)
Unhappy NEED HELP!!! desperately!!!!!! pleasee helpp!!!
i have a situation i installed everthing.. used the rca to bypass the amp.. everything went well.. but then when i was trying to close the dashboard.. my hu shut off.. and now it wont turn on anymore. And also i cant lock my car doors using the honda key remote.. what might be the problem?... fuse probably!?!.. need help desperaetly!!!!!! please helppp!!!!! thank you
njzkillahsin is offline   Reply With Quote
Old 05-17-2007, 01:52 PM   #2 (permalink)
xSi
Xavier
check your fuses to see if any burnt out
xSi is offline   Reply With Quote
Old 05-17-2007, 01:53 PM   #3 (permalink)
which one do you think it is?..
Old 05-17-2007, 01:55 PM   #4 (permalink)
Question which one?
Old 05-17-2007, 02:01 PM   #5 (permalink)
Drywin's Avatar
Josh
PG 271 In your Owners Manual. Check number 5 or 35 on you interior fuse Box
Drywin is offline   Reply With Quote
Old 05-17-2007, 02:52 PM   #6 (permalink)
bikinpunk's Avatar
Erin
35 it is, in mine.
7.5amp fuse.
bikinpunk is offline   Reply With Quote
Old 05-17-2007, 06:23 PM   #7 (permalink)
Garrett
When i blew a fuse that caused the power locks to stop working it was one of the underhood fuses.
The power locks worked when the car was on, but when the car was off neither the remote nor the button on the door would function.
i forget what the fuse under the hood was labeled as, but it had nothing to do with the locks or the radio. Made it very tricky to track down.
notacop is offline   Reply With Quote
Old 05-17-2007, 07:10 PM   #8 (permalink)
Dead battery?
lostdaytomorrow is offline   Reply With Quote
Old 05-17-2007, 07:32 PM   #9 (permalink)
Devin's Avatar
Devin Flannery
Bingo. Reverse light fuse under the hood.
Devin is offline   Reply With Quote
Can Somebody Photoshop Some Rims On My Car Pleasee!!!! mikes-si Photoshop 7 05-15-2007 01:01 AM
HELPP with deciding! andywho Forced Induction And Nitrous 3 11-10-2006 12:37 AM
